CANbus to Instruments etc. working
acab
Re: CANbus to Instruments etc. working
Post by acab »
Does that code right in ms2_extra_can.c for 500kBit/s?
Code: Select all
    /* Set timing for .5Mbits/ sec */
    CANBTR0 = 0xC2;  /* SJW=4,BR Prescaler= 3(24MHz CAN clk) */
    CANBTR1 = 0x1C;  /* Set time quanta: tseg2 =2,tseg1=13
                        (16 Tq total including sync seg (=1)) */
I found some info about it in Application Note AN3034. And correct is:
Code: Select all
CANBTR1 = 0x58; /* Tseg2 = 6, Tseg1 = 9 (Tseg1 + Tseg1 + Sync(=1) = 16 => 8 Mhz / 16 = 0.5 Mhz */
Or i make mistake?
Post by jsmcortina »
I believe that there are a number of different settings that can achieve the same result from my recollection of reading the datasheet. Have you scoped the outputs from the two settings and compared them?
What is leading you to question the existing setting?
racingmini_mtl
Post by racingmini_mtl »
And you still haven't posted what your problem is with the alpha code. Is there a reason why you don't want to help debug the code? That is a really annoying attitude; if everyone did that, the development would have been a disaster.
acab
Post by acab »
racingmini_mtl wrote:And you still haven't posted what your problem is with the alpha code. Is there a reason why you don't want to help debug the code? That is a really annoying attitude; if everyone did that, the development would have been a disaster.
I post it later in topic with bugs of alpha code. In shortly - all coils work in same time.
What about CANBTR0 and CANBTR1?
On oscilloscope i can see something on CAN (packets). But i cant sniff it on my CAN-USB dongle. If i understand - problem in speed of CAN.
Peter Florance
Post by Peter Florance »
I've modified (badly) the MS3 Beta code to drive a BMW (Seimens) instrument cluster based on data on this thread.
http://forums.bimmerforums.com/forum/sh ... ?t=1887229
The BMW dash seems to use 500kb/second.
It does work, despite my poor programming skills.
http://www.youtube.com/watch?v=U7GoQ28ghKY
One question, the tachometer wants a minimum 20msec update rate. I modified the ini file to allow 20msec rate.
Any issue with a transmission rate that high on MS3?
Thanks!
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
Sounds good Peter. 20ms should be ok. Check your "mainloop time" - this is the time in microseconds that each mainloop pass is taking. So long as the mainloop time is significantly less than 20ms you'll be ok. I've only seen it anywhere close (10ms?) when testing the code with all options enabled and a 60-2 and high rpms.
acab
Post by acab »
This is my Alfa Romeo Dashboard
Its work, but i have some questions about CANBTR0 and CANBTR1.
[quote="acab"but i have some questions about CANBTR0 and CANBTR1.[/quote]
Did you read my answer?
acab
Post by acab »
jsmcortina wrote: Did you read my answer?
Yes, i read your post...
But i didnt know, wich settings are right.
Peter Florance
I did not have to change the CAN data rate to work with BMW; which is 500K
Peter Florance
PF Tuning
acab
Post by acab »
Peter Florance wrote:I did not have to change the CAN data rate to work with BMW; which is 500K
Hmmm, strange.
I think my CAN transiever in MS2 is bad :oops:
Peter Florance
Hmmm, strange.
Can your Arduino read it?
Peter Florance
PF Tuning
It is rare for the CAN transceiver to be faulty. You haven't answered this previous reply.
jsmcortina wrote: Have you scoped the outputs from the two settings and compared them?
acab
Post by acab »
I have CAN-USB dongle. I cant connect and sniff data ;(
jsmcortina wrote:It is rare for the CAN transceiver to be faulty. You haven't answered this previous reply.
Not yet... Can you explain about it?
Peter Florance
should look like this; CANH is blue, CANL is red
Edit, if hotlink doesn't work, it is here:
http://www.picoauto.com/showpicauto.php ... form_1.jpg
Peter Florance
PF Tuning
acab
Post by acab »
Tnx for post, Peter!
I attach oscilope and i see waweform... But i think i cant get right speed of CAN BUS;(
Peter Florance
jsmcortina wrote:Sounds good Peter. 20ms should be ok. Check your "mainloop time" - this is the time in microseconds that each mainloop pass is taking. So long as the mainloop time is significantly less than 20ms you'll be ok. I've only seen it anywhere close (10ms?) when testing the code with all options enabled and a 60-2 and high rpms.
Right now the gauge shows 23 ms at 7300 rpm (60-2 & cam)
If I turn off CAN broadcasting, it doesn't really change from 23 ms.
At 1000 rpm mainloop is about 12ms, with or without CAN broadcast turned on.
Peter Florance
PF Tuning
Peter Florance
Oops, I can't read.
It is 2.3ms
Sorry!
:oops:
Peter Florance
PF Tuning
NArcher
Post by NArcher »
For some reason, I do not have the 120 ohm resistor in my MS3 (V3.0 board, followed all instructions in the manual). My rpm gauge is lagging behind by about 1 - 2 seconds. Is it because the resistor is missing? The gauge cluster has the resistor installed and as I understand it, you need a resistor on each side of the bus to act as a terminator. I will check this for myself later, just wanted to get confirmation.
NArcher
Post by NArcher »
Sorry, another CAN question.
I have an ABS computer that I would like to receive the data from and pass to the vss to get speedo to work. Which part of the code do I have to modify to make this work. I am [also] a poor programmer :cry: but am continuously learning! :RTFM:
