Gearshift counter
jeffmarsh750
Gearshift counter
Post by jeffmarsh750 »
Anybody have a good Idea on how to build a small gearshift counter, that when I push the shift button on a bike it will change voltage outputs to the MS so I can use the gear position inputs. Don't want to use wheel speed as sometimes the speed sensor spikes and I think that will confuse the MS. For drag race only, only has to remember upshifts.
Fastest MS powered vehicle on the planet ! 6.60@208mph
Re: Gearshift counter
Before rejecting it, did you already try the VSS/RPM method for gear detection? It works ok on my 12sec car with a manual gearbox.
ol boy
Post by ol boy »
I'm a little late into this.. I'm a fan of picaxe processors. There is the 08M2 which is an 8 pin DIP layout. It has a DAC 5 bit output. Or you could do a PWM to low pass and start at 20% (1 volt= gear 1) then go to 40% (2 volts = 2nd gear) up to 5 volts for 5th gear... If you have more than 5 gears then divide by 1/2 volt for each gear... Is this what your trying to do?
http://www.picaxe.com/
The IDE is free to down load and the chip sets are a few bucks. For your app a small copper proto board would work. Still 5 volt power from the MS mother board or the tps output.
Later Ryan
jeffmarsh750
Yes, Yhank you. Will try one but will also try the internal setup as well with the VSS and ratio inputs.
Fabius72
Post by Fabius72 »
jsmcortina wrote:Before rejecting it, did you already try the VSS/RPM method for gear detection? It works ok on my 12sec car with a manual gearbox.
wow, thank you James for the trick!! It works very well for me too!!! I didn't know that method, very simple and functional :yeah!:
I have just tried creating in MLV a "Gear" Custom Field with this formula:
(([VSS]/[Field.RPM] > 0) && ([VSS]/[Field.RPM] < 0.009)) ? 1 : (([VSS]/[Field.RPM] > 0.008) && ([VSS]/[Field.RPM] < 0.017)) ? 2 : (([VSS]/[Field.RPM] > 0.016) && ([VSS]/[Field.RPM] < 0.022)) ? 3 : (([VSS]/[Field.RPM] > 0.021) && ([VSS]/[Field.RPM] < 0.026)) ? 4 : (([VSS]/[Field.RPM] > 0.025) && ([VSS]/[Field.RPM] < 0.030)) ? 5 : 0
was an experiment, but tried and works.
Fabio
Yamaha V-Max V4 paired odd-fire 1200cc engine - ITB - COP
MS2/Extra Pre 3.4 beta 11
Sequential spark & fuel - ITB Algorithm
