Logging Humidity, possibly later using it for air density
I have found some cheap 0-5v arduino humidity sensors. I am wondering if I could pipe that data into a spare analog input and for now monitor that value, possibly later on use it for air density correction or at least display a Density Altitude reading combined with itself, temperature, and barometric pressure.
Re: Logging Humidity, possibly later using it for air densit
Interesting. I think that humidity can change also a bit the timings due to antidetonants properties of water, but i not know how much...
Enrico
Opel/Vauxhall Corsa GSi MS2
Subaru v4 EJ20 MS3
Subaru v4 EJ20 MS3
