Microsquirt PCB mounting question(s)
Raymond_B
Post by Raymond_B »
Hi all, I am trying to make an EEC-IV adapter to do two things.
1. Provide a simple way to adapt the existing EEC-IV harness to my Megasquirt MS3/3X
2. Provide a mounting location for the Microsquirt PCB for trans control
My idea is to make a simple PCB to go inside an EEC-IV case which mounts the EEC-IV connector and then connects trans related items to the Microsquirt, but also provides a connector out to go the the Megasquirt. I **think** I have all the measurements for the EEC-IV connector, but I am not sure of the relation of the 50 pin and 10 pin Microsquirt header placement. Would it be breaking any rules to get that info? I don't want to reverse engineer anything just make a nice clean setup for my truck.
Here is the idea, hopefully it's not a dumb one :)
http://www.buildpics.org/
dontz125
Re: Microsquirt PCB mounting question(s)
Post by dontz125 »
There's nothing secret about the MicroSquirt Module's pinout or mounting dimensions - it is designed and intended to be used by anyone who so desires on their own carrier board. The dims are in the Module Developer's Guide, on page 5.
Raymond_B
Post by Raymond_B »
Awesome, thank you. The closer I look, the more I do not think I even need the J1 10 pin connector for trans control anyway since it is mentioned as "Additional processor I/O brought out on J1 5x2 header (J1): " in the Microsquirt docs. I should have mapped everything out before asking.
dontz125
Post by dontz125 »
I had to double check the manual and the pin list for both the uS and the uSM - none of the pins on J1 are used on a cased uS, and so would not be included in the Transmission Controller code.
