4d systems screen display for Megasquirt: http://youtu.be/m4I-gXoJ_xM
Got this working today. I need to sort out the ign advance as the led digit value and the needle value didn't match.
4d system display
4d system display
Re: 4d system display
Does it work through USB or CAN? Looks pretty cool though.
Nissan Skyline R34 RB26DETT ran MS3/MS3X w/ factory Hitachi CAS (sold)
Nissan Silvia S14 RB25DE ITB/NA ran MS3/MS3X w/ factory Mitsubishi CAS (disassembled)
Datsun 240z RB25DE ITB/NA with MS3/MS3X
Using tx/rx UART pins from MS2. The display sends out an ascii "A" and then receives the 209 byte stream for data. I Oscoped it last week and was seeing 45ms period between requests and the return stream and the time to process and display the new values. So somewhere in the 20 to 22hz range. Did a 30 minute drive to work this morning without a hickup.
ol boy,
I hate bringing old threads back to life, but I'm interested in what 4D Systems display you used for your project.
I'm starting to make progress on my S10 and thought this would look nice on the dash reading the information from my MS2.
Cheers,
Andy
Cheers,
Andy
Andy
1996 Chevrolet S10 2.2L, 5spd, MS2
It the 4.3 inch version. This was years ago. I'm sure there gen 4 displays are even better. Most are now capactive touch. Of you looking for a dash then get what ever fits your dash.
Sent from my SCH-I535 using Tapatalk
