Arduino OLED Gauge Pod
bajallama
Post by bajallama »
Thought I would share a cool little project I have been working on. All said and done I have less than $40 into it including a used Honeywell Pressure Transducer. I'm still working on the final appearance but so far it's turning out pretty neat! I think I saw something like this on the forums before but it was too expensive or something??
Iterations:
Laminar
Re: Arduino OLED Gauge Pod
Post by Laminar »
bajallama wrote:Thought I would share a cool little project I have been working on. All said and done I have less than $40 into it including a used Honeywell Pressure Transducer. I'm still working on the final appearance but so far it's turning out pretty neat! I think I saw something like this on the forums before but it was too expensive or something??
Does this just take the signal from a sensor and display its scaled value? I haven't seen any of those on here (because if it stands on its own and doesn't feed or take anything from the MS then it's not super relevant to this board), but maybe you're thinking of this CAN gauge that includes a 1.5" OLED display, LEDs, ambient light sensor, a buzzer, microSD socket, PWM driver, stepper motor driver, 9 DoF sensor, temp and humidity sensor, baro sensor, and GPS module. I think the features justify the cost. Or maybe this one; both of these interface with the MS through CAN, though, which your device doesn't appear to do.
bajallama
Post by bajallama »
Yes as of now that is all it does but a CAN shield is in the future. I'm really all new to programming, but have been using MS for about 8 years now. I actually have not seen those yet but the first one I had seen a previous version. That gauge is really cool and is done very well but really don't need those options. The screen, Arduino Nano and PVC cost me less than $16.
grom_e30
Post by grom_e30 »
with not a lot more hardware you can pull data from the ecu via serial as well
bajallama
Post by bajallama »
grom_e30 wrote:with not a lot more hardware you can pull data from the ecu via serial as well
Is there a limit to the length of wire to where the data traveling through the serial bus is effected? I was looking into that if I wanted to remote mount the screen...
grom_e30
Post by grom_e30 »
you need to build a ttl-rs232 adapter but that gives you proper serial level connection so using a 6ft serial cable between your gauge and the ecu will be fine. iv got a mega2560 pulling the full 498 bytes data stream from my ms3 and displaying certain info on a 3.2 lcd screen and that works pretty well
Zaphod
Post by Zaphod »
grom_e30 wrote:iv got a mega2560 pulling the full 498 bytes data stream from my ms3 and displaying certain info on a 3.2 lcd screen and that works pretty well
Please show us!
fun is not a straight line
Sven
grom_e30
Post by grom_e30 »
be kind.
