I have a Ford 434 cubic inch EFI motor in my '53 Ford F100. It uses an EEC-IV controller. I have used this for several years, and it's well tuned. Recently I converted the ignition to EDIS. I installed D585 coils. The motor starts & runs good, but the timing doesn't advance properly. The coils fire too soon at low RPM, due to the long dwell time from the EDIS8 module. I have not been able to reduce the dwell from that unit.
I need an ignition controller that will interface with the EEC-IV, and drive 4 D585 coils. I am considering building my own, but will purchase an off-the-shelf unit, if there is something available that will work.
Please offer any suggestions.
Thank You,
Dan Lee
EDIS8 & D585 Coils
Re: EDIS8 & D585 Coils
That's a very strange combination.
Use EDIS8 with EDIS coils.
OR
Use D585 coils with a Megasquirt ECU (e.g. MS3 or MS3-Pro.)
OR
The problem is that the EDIS8 uses 40 crank degrees for dwell. At idle that's about 10 milliseconds. The D585 Coils fire at 6 milliseconds. I have to reduce the dwell from the EDIS8. I'm considering purchasing a Megasquirt Stimulate board to generate the crank signal & using a microcontroller to generate the PIP. I can keep the dwell to about 5 milliseconds or less.
I will need some way to simulate the SAW.
Will the Megasquirt Stimulate board simulate the SAW?
You need a Megasquirt ECU.
I don't understand how you can use 4 LS coils to run a V8, so I assume you mean 8 of them.Dan Lee wrote:I have a Ford 434 cubic inch EFI motor in my '53 Ford F100. It uses an EEC-IV controller. I have used this for several years, and it's well tuned. Recently I converted the ignition to EDIS. I installed D585 coils. The motor starts & runs good, but the timing doesn't advance properly. The coils fire too soon at low RPM, due to the long dwell time from the EDIS8 module. I have not been able to reduce the dwell from that unit.
Thank You,
Dan Lee
Regardless, why would you use coils with built-in ignitors and EDIS? There's all sorts of incompatible happening here.
I have read that you can use 8 newer Ford COP coils wired in pairs, and keep the EDIS module happy. IF what I read is true, that would be your best solution.
Cheers, Brady
Audi 4kq MS1E,
Audi Quattro, 034 IIc
Audi 200qa20v
Audi 5ktqa
Datsun 240Z
Audi 4kq MS1E,
Audi 200qa20v
Audi 5ktqa
Datsun 240Z
