Need CAN output altered for project, will pay!
dwiddowmaker
Post by dwiddowmaker »
Greeting tuners and programmers,
I am working on using Microsquirt in an application not widely discussed or used, marine. It will be controlling LSx platform engines, but I need the microsquirt to communicate over a NMEA 2000 backbone as opposed to the standard CAN. Electronically CAN and NMEA 2000 are compatible, and NMEA 2000 uses the J1939 protocol with a few different packet transmission options.
While I have a pretty good understanding of these protocols, I am not a programmer. I assume that some minor communication configuration will need to be done, as well as altering definitions and format for the data broadcast.
https://en.wikipedia.org/wiki/NMEA_2000
https://en.wikipedia.org/wiki/CAN_bus
If you are familiar enough with these systems you are confident a solution is possible, please contact me.
Thanks,
Corey
