Crank Sensor Mounting for SBF
Posted: Sun Sep 04, 2016 6:35 pm
Thought I'd post this to go in tandem with the cam position sensor post for small block Fords.
A lot of the SBF guys will pick up an Explorer balancer along with other assorted parts to make fitting a crank sensor easier. With my combo I need to run an SFI balancer, different pulley, etc, etc. I could have fabbed something up or bought either a new or used MSD, Moroso, etc crank trigger kit and used the sensor bracket. But most of those kits are expensive. So I found a cheap Ebay knockoff of the MSD crank trigger kit (honestly I bet they are the same parts!) for 125.00.
Below is what I did.
Here it is mocked up, looks like I'll need a couple of 1.25" aluminum spacers, order appropriate ARP hardware, and have it all powder coated I ditched the sensor that came with the kit for a Cherry sensor (GS100502). I still need to drill the wheel for the pulley mounting bolts, but overall this was quite a bit easier than I thought it would be.
Ignore the sharpie marks I hadn't read that far in the manual yet I also need to fit my timing pointer.
