Additional Knock Control Required?
Postby benckj » Thu Nov 17, 2016 6:25 pm
Has anyone installed additional knock control such as J&S Safeguard and integrated into MS?
I've heard through the grapevine that the MS system is not the best software for detecting and controlling knock should it occur. Not a direct criticism as other EMS systems are equally as bad according to Tuners/Users.
http://www.jandssafeguard.com/safeguard.html
Comments good or bad?
jim
MSPNP v2 with 3.57 firmware
Toyota MR2 98 3sgte
TD05sl2-18g (billet wheel & high flow turbine)
A2W IC
WI with 50/50 meth/water
benckj
Re: Additional Knock Control Required?
Postby MalcolmV8 » Fri Apr 07, 2017 8:10 am
Jim,
I've been a long time user and even reseller of the J&S anti-knock boxes. They work fantastically well and I've had it save various engines multiple times over the years as I tinkered and pushed things to their limits with boost, water / methanol injection, nitrous etc. I have all the faith in the world in them. I'm now converting over to the MS3-Pro myself and have the same question as to how well the knock control works within the MS3-Pro?
Did you ever move forward with this? Did you experiment both ways? Any results or feedback to share?
Malcolm
MalcolmV8
Postby benckj » Fri Apr 07, 2017 9:01 am
I'm still tinkering with my MS2 to gain control and some confidence with knock before I adjust my Ignition tables. Hard to get a handle on the pot adjustments without spending another couple hours on the dyno. Trying road running using VEAL and data logging runs.
Jim
Toyota MR2 98 3sgte
A2W IC
benckj
Postby MalcolmV8 » Fri Apr 07, 2017 10:25 am
OK thanks for the update.
MalcolmV8
Return to Other Development
