How To - MS Onboard Bluetooth Cheap Ebay module (HC-05)
Re: How To - MS Onboard Bluetooth Cheap Ebay module (HC-05)
Postby grom_e30 » Thu Dec 14, 2017 12:11 pm
you connect it inside before the signals go through the msx232 circuit, the 5v ttl signals from the processor are stepped up to rs232 signals +12/-12v by the max232. the rs232 signal would prob kill the 5v ttl bt module if you connected it directly to the serial port without using another max232 to step the signal back down.
grom_e30
Postby racingmini_mtl » Thu Dec 14, 2017 12:59 pm
But you can get cheap modules on ebay that already have the max232 and the DB9 connector.
racingmini_mtl
Postby MegaMicra » Thu Dec 14, 2017 1:11 pm
Thanks for the info guys. So going off what you both have said, it might work if I connect one of those ready made max232 modules to my hc-05 Bluetooth module. It's only a couple of quid to try it. If not I'll just buy one of the proper Bluetooth ones.
Sent from my WAS-LX1A using Tapatalk
MegaMicra
Postby racingmini_mtl » Thu Dec 14, 2017 2:15 pm
What I meant is that there are Bluetooth modules with everything integrated: max232, DB9 and HC-05 (or equivalent). That's much easier to deal with than separate RS232 module and Bluetooth module.
EDIT: Like this: https://www.ebay.ca/itm/DB9-RS232-RF-Wi ... 2108777586
racingmini_mtl
Postby MegaMicra » Sat Dec 16, 2017 8:14 pm
Ah right I see. I could just reprogram the baud rate etc to work with my MS3X and then use the HC-05 that I've already got for the raspberry pi. Thanks for the info and link.
MegaMicra
Previous
Return to Other Development
