CAN integration with a DIY device
Anyone have a forum link or documentation on integrating a custom CAN device with MS? Say I wanted to read what the CLT level was in MS, how would I go about doing that in general? Does MS broadcast a message with all variables available? Or would my CAN device need to query MS for it?
Re: CAN integration with a DIY device
Enabling the "Dash broadcast" on the Megasquirt and then having your device listen for that broadcast is strongly recommended.
The CAN protocol documents are available from the "Manuals" link.
Awesome! Thanks James! I'll post back here if I have more questions.
Well, 2 years later!
I finally got around to having the time to working with the CAN bus more, and got an arduino uno communicating with my MS2.
Here's the message of interest:
That equates to this message:
So if I'm interested in the coolant field, I concatenate data 4 and 5 to construct the hex number 3cd, which in decimal is 973, which when divided by 10 is 97.3! The coolant level I see in msdroid! success!
Now I just need some code snippets in C to concat 2 hex numbers. Anyone have any?
Code: Select all
5E8 8 3 C6 19 9C 3 CD 2 7F
Sorry, I think I've answered my own question. If anyone has a better way, please let me know:
Code: Select all
Serial.print(((canMsg.data[4]<<8) + canMsg.data[5])/10);
You might want to use a bitwise OR instead of addition and perhaps cast to 16bit. In C language, I would be doing this:jsdevel wrote:Sorry, I think I've answered my own question. If anyone has a better way, please let me know:
Code: Select all
Code: Select all
uin16_t value;
value = (((uint16_t)canMsg.data[4] << 8) | (uint16_t)canMsg.data[5]) / 10;
With arduino you also can use « word », which use cast too
https://www.arduino.cc/reference/en/lan ... /wordcast/
Code: Select all
uint16_t value = int (word(canMsg.data[4],canMsg.data[5]))
Is 'word' always 16-bit regardless of the CPU used? (The link seems to imply this is the case) Using uint16_t removes any ambiguity about the number of bits in the cast.Manu wrote:With arduino you also can use « word », which use cast too
https://www.arduino.cc/reference/en/lan ... /wordcast/Code: Select all
Using 'word' as a 16-bit value on a 32-bit CPU (or an 8-bit CPU) is not what I would call a good practice. That may be obvious for most Arduino developer but to me that's a very platform-dependent term. But it may be that I'm a too ancient developer (started programming more than 40 years ago).
I think that « word » is an arduino command (only)...
Thanks James! How would you go about separating out the decimal portion? I've noticed that it's dropped after division.jsmcortina wrote: The casts may look messy, but otherwise you are relying on the compiler to make an implicit type conversion which does not always work as expected!
Thanks Manu! I'll definitely check that out.Manu wrote:I think that « word » is an arduino command (only)...
Right now I'm working on displaying the data on some OLED displays
I've made a mistake in the command. This is the right one, for example it get RPM from MS CAN protocol :Manu wrote:Code: Select all
Code: Select all
REG = (int)(word(frame.buf[6], frame.buf[7]));
Thanks James! How would you go about separating out the decimal portion? I've noticed that it's dropped after division.jsdevel wrote:jsmcortina wrote: The casts may look messy, but otherwise you are relying on the compiler to make an implicit type conversion which does not always work as expected!
It depends what you want to do with it. Inside the MS2/3 firmware we use the raw number and the code "knows" that it is *10.
You _could_ use floating point, but depending on the capabilities of your microcontroller that might consume a ton of cycles. Don't use floating point unless the MCU has a floating point module.
The MS2/MS3 MCUs do not have hardware floating point capability so we use solely integer maths.
I finally got it working!!!
Created a video for proof: https://www.youtube.com/watch?v=BliEJyVSeB4
Currently using 2 OLED displays. I ordered a multiplexer on aliexpress and plan to have a total of 4 - 6 displays
Thank you everyone for your help and support over the years!
