Knock module for MS3 (beta test)
Re: Knock module for MS3 (beta test)
Postby TTC » Wed Jul 25, 2012 1:50 pm
Anything I should do in particular atm since im currently building my ms3 msx combo to prep for this unit? I'm using the msx for all my fuel/ign outputs so my Fidle and native fuel and spark on the ms3 board are empty. The led's are setup as per the instructions.
TTC
Postby MegaScott » Wed Jul 25, 2012 4:27 pm
TTC wrote:Anything I should do in particular atm since im currently building my ms3 msx combo to prep for this unit? I'm using the msx for all my fuel/ign outputs so my Fidle and native fuel and spark on the ms3 board are empty. The led's are setup as per the instructions.
If you have not dedicated D14 D15 D16 (LED output circuits on the MegaSquirt board) to drive other outputs, you should be able to add the Knock Module at any time simply by soldering the module in place with the jumper wires and the associated wiring from your knock Sensor(s) to the MegaSquirt.
Of course (duh) given as well that you are running MS3 firmware that supports this particular module since it requires special comms on the processor SPI bus to talk to the module.
MegaScott
MS/Extra Guru
Postby Mhm » Tue Jul 31, 2012 4:37 am
I want to keep some spare DB37 pins open for when the knock module becomes available.
How many DB37 pins should I reserve?
Mhm
Postby Matt Cramer » Tue Jul 31, 2012 6:17 am
Mhm wrote:I want to keep some spare DB37 pins open for when the knock module becomes available.
One on the main board for each knock sensor.
Postby Mhm » Tue Jul 31, 2012 7:02 am
Thanx, I assume the other side of the sensors would be connected to ground.
Mhm
Postby Matt Cramer » Tue Jul 31, 2012 8:18 am
Mhm wrote:Thanx, I assume the other side of the sensors would be connected to ground.
Correct.
Postby Nofalls » Thu Aug 02, 2012 7:49 am
My calendar says August 2nd. Any word on the boards being up for sale Matt? :D
-Mark
Nofalls
Postby Bainzy » Fri Aug 03, 2012 6:38 am
What are the chances of these working well with an OHV type engine (eg. Triumph, A/B Series etc)? If these modules work despite the engine having quite a bit of valve train noise then I'd love to try one in my Spitfire 1500.
Triumph Spitfire 1500 - MS3 + MSX running on EDIS
Bainzy
Postby GT6MK3 » Sun Aug 05, 2012 8:47 pm
Any further word on supply of these?
C.
GT6MK3
Postby savagerocco » Tue Aug 07, 2012 4:24 pm
From what I hear, the test car they were using to verify the changes on the chip is broken, plan "B" is in the works. Guess I can wait a little longer for verification and quality.
Brent Savage
life behind the zion curtain
90 audi RS2 20VTQ 6sp MS3, MSX COP and Sequential and now MAF
87 Scirocco 2.0 ABA 16v EIP tubular cast MSII COP
86 Audi 4K20VTQ MSII
90 Audi 90 sedan 3.6l DOHC V8TT (project car)
89 VW cabbie (bitch basket) 2.0 ABA Turbo MSII
savagerocco
Postby prof315 » Wed Aug 08, 2012 3:46 am
According to DIYAutotune's Facebook page the knock modules and real time clocks should be available for sale at the end of this week or early next week.
The Professor
92 Corrado 2.0L ABA on MS3Pro. Support the developers! Sandy Linfert 11/4/91- 5/13/13
prof315
Postby Mhm » Wed Aug 08, 2012 4:17 am
Good news!
Mhm
Postby BCM » Wed Aug 08, 2012 5:54 am
Count me in for an order. I am going to install, wire, and configure this as soon as I can get my hands on one so I can do some datalogging at a track day the end of the month. I have been fighting det problems in my race car all year so this should be big for me.
A couple questions - Is there a recommended sensor? Or, Matt, will you guys be selling them? If not, I'm going to make sure I have two on hand as soon as I can get them, I can probably just get a generic sensor from RockAuto. Also, trying to think through this, if I want to trigger an external indicator light that indicates when knock is getting detected, would that be possible now using spare outputs?
A couple suggestion based on the screenshots and what I've read here. I see windowing based on RPM and MAP, but not TPS. I am running Alpha-N, so adding in a TPS option would be good, if not done already. Also, individual cylinder retard would be a nice option in the future.
Thanks for all the work on this, hoping to be a production tester very soon...
Brendan
My 1990 BMW E30 M3: viewtopic.php?f=104&t=40404
NA 2.3L 4-Cyl S14, MS3/MS3X, COP, Sequential
BCM
Postby Matt Cramer » Wed Aug 08, 2012 6:00 am
BCM wrote:A couple questions - Is there a recommended sensor? Or, Matt, will you guys be selling them? If not, I'm going to make sure I have two on hand as soon as I can get them, I can probably just get a generic sensor from RockAuto.
We have been using a broadband Bosch knock sensor ourselves, but one tuned for a particular engine could potentially be beneficial. We aren't selling knock sensors at the moment but may add them in the future.
Trigger it when KnockRetard > 0.
Postby BCM » Wed Aug 08, 2012 7:25 am
Thanks Matt. Is there any reason you couldn't use two sensors on an I4 engine, or is it just not necessary? I have a good spot I could mount a sensor between both cylinders 1/2 and 3/4, so was wondering if it'd be beneficial to do that...
Brendan
BCM
Postby prof315 » Wed Aug 08, 2012 9:24 am
BCM wrote:Thanks Matt. Is there any reason you couldn't use two sensors on an I4 engine, or is it just not necessary? I have a good spot I could mount a sensor between both cylinders 1/2 and 3/4, so was wondering if it'd be beneficial to do that...
VW 1.8Ts do that from the factory.
The Professor
prof315
Postby Acki » Wed Aug 08, 2012 9:52 pm
Yeah. This engine knocks at idle with Original ECM.
Two sensors on one bank - you have to use time frames (wrong wrote) and trigger the signal according the cylinder which works (you have to run full sequential that the MS knows the cylinder 1) and you have to prevent for interferences. When you have a overlap of the signals (at high revs).
It's more difficult to use this. Or?!
Acki
Postby Mhm » Thu Aug 09, 2012 3:57 pm
How would one know what/which knock sensor is suitable for a particular motor if it never came with any knock sensors.
Mhm
Postby Matt Cramer » Fri Aug 10, 2012 5:50 am
Mhm wrote:How would one know what/which knock sensor is suitable for a particular motor if it never came with any knock sensors.
You could either run a broadband knock sensor or a narrow band sensor from an engine with the same bore size.
Postby OliverH » Sun Sep 16, 2012 12:45 pm
How about knock and EGT control? I just bought an EGT+ CAN board from jbperf. If knock retards the ignition EGT will rise and more advance/ more fuel will be good to control EGT. How will they both (knock/ EGT) interact?
Is it possible that knock control will also use "over fueling" to get control of knock?
Is a wide band knock sensor capable to detect knock in all rpm ranges? Which kind of knock we talk about?
And what about knock contol on boost?
MS V3.00 DIY, MS3, MS3X, JimStim & StimX.
OliverH
PreviousNext
Return to MS3 Development
