Feature request : Rev Limiter + EGT feature adds + Timer
dochka
Post by dochka »
Hello,
There's 2 major additions i'd like to see improved and they are :
1. In the hard rev limit, the "soft limit zone/hysteresis(rpm) : to make it possible to be lower than 100, better if can be set to 0;
Guys are always asking me if i could "speed" the cut-off (rev limiter), they like a machine gun rev limiter..
2. In the EGT settings, to have an Ignition and Fuel curves correction based on EGT temps, just like the "MAT based timing retard"
3. A turbo timer, is this possible, I mean program the ecu to shut the engine after a set amount of time
Thank you
JoseMiguel
Re: Feature request : Rev Limiter + EGT feature adds + Timer
Post by JoseMiguel »
The turbo timer request has an electrical limitation as the ecu needs to be constantly powered anytime the engine is running, which means you can no longer wire the ecu to the ignition switch, and by not doing so, other more difficult problems arise.
