Rev match downshifting
I had another feature idea cross my mind as I was practicing heel toe downshifting (and failing). What if we could program it to rev the engine when I am pushing on the brake and clutch at the same time. For a mechanical throttle it could use a solenoid or actuator. Or perhaps use the idle control circuit somehow. If vss is enabled the ecu could target an rpm for the down shift. A similar function to idle control could be used. Or maybe a solenoid that opens the throttle plus a rev limiting method to match the rpm. Or maybe I just need to practice at heel toe more!
Re: Rev match downshifting
This was discussed just a few weeks ago.
This requires throttle by wire. I suggest practicing heel-toe more. It isn't that difficult on most cars. Practice just rev matching downshifts first, then once you have that, move to heel toe.rabid wrote:I had another feature idea cross my mind as I was practicing heel toe downshifting (and failing). What if we could program it to rev the engine when I am pushing on the brake and clutch at the same time. For a mechanical throttle it could use a solenoid or actuator. Or perhaps use the idle control circuit somehow. If vss is enabled the ecu could target an rpm for the down shift. A similar function to idle control could be used. Or maybe a solenoid that opens the throttle plus a rev limiting method to match the rpm. Or maybe I just need to practice at heel toe more!
I have applied this strategy in V8 engine with 2 DBW. I have sequential-gear and 1 actuator for up and down shift.
When I press down shift, DBW open the throttle for "x"% and "x"time. The actuator insert down gear. Work very well, and the driver change gear without press the clutch
I am testing code I put in ms3_misc.c. It sets the rev limit to whatever the next gear down rpm is while the clutch is pressed.
This is in the do_launch function
This is in the gearpos function
Also I removed code from do_revlim_overboost_maxafr to prevent conflict. So this stuff is pretty ruff, only works with my settings, and the gear detection doesn't always go to correct gear. Sometimes is down shifts 2 gears instead of one. I don't know why yet. I'm still working on the details plus you still have to press the throttle to make this work. Maybe if I end up liking the changes I will add something to "blip the throttle" and inputs to better detect when I mean to use this code.
Code: Select all
if (pin_launch && ((*port_launch & pin_launch) == pin_match_launch))
if (!(outpc.status2 & STATUS2_LAUNCHIN)) // gone from no-press to being pressed
outpc.status2 |= STATUS2_LAUNCHIN;
/////////////////////////////////////////////////////////////////////////////////////////////////////////mod code below
if (outpc.rpm <= ram4.flats_arm)
if((outpc.gear >= 2) && (outpc.vss1 >= 5))
outpc.gear = outpc.gear - 1; //down shift
else
outpc.gear = outpc.gear + 1; // up shift
if ((ram4.launch_opt & 0x80) && (outpc.rpm > ram4.flats_arm) && (((ram4.vss_opt0 & 0x03) == 0) /* VSS off */
|| ((ram4.vss_opt0 & 0x03) && (outpc.vss1 > ram4.flats_minvss)))) /* or VSS on and condition satisfied */
flagbyte21 |= FLAGBYTE21_FLATS_ARM;
else
flagbyte21 &= ~FLAGBYTE21_FLATS_ARM;
else
outpc.status2 &= ~STATUS2_LAUNCHIN;
///////////////////////////////////////////////////////////////////////////////////////////////////////////mod code below
RevLimRpm1 = ram4.RevLimNormal2 - ram4.RevLimNormal2_hyst; // reset rev limiter
RevLimRpm2 = ram4.RevLimNormal2;
Code: Select all
if (outpc.status2 & STATUS2_LAUNCHIN)
unsigned int RevLimDownshift = (unsigned int)((ram4.gear_ratio[outpc.gear - 1] * (unsigned long)outpc.vss1 * gear_scale) / 10000);
if (RevLimDownshift < RevLimRpm2) // make sure down shift rev limit doesn't exceed normal limit
RevLimRpm2 = RevLimDownshift;
RevLimRpm1 = RevLimDownshift - 500;
return; // prevents code from detecting gear during forced up or down shift in launch code.
I haven't worked on this idea in a month. The biggest issue was with the occasional gear miscalculation. I figured it was the clutch switch bouncing and causing multiple gear subtractions. Now I figured out why. The actual gear calculations are called every 10ms. I moved everything to the gear function and created a counter to delay the gear downshift code to be sure the clutch switch was pressed solidly. So far it hasn't missed the intended gear position and works very well. Now I need a way to rev the engine. A throttle kicker, idle valve, air solenoid. For now my right foot works and this makes it much easier to rev match a down shift.
This is at the beginning of the gearpos function.
Code: Select all
if (launchin_count == 2)
if((outpc.gear >= 1) && (outpc.vss1 >= 5))
else
if (launchin_count < 3)
launchin_count = launchin_count + 1;
if ((!(flagbyte21 & FLAGBYTE21_FLATS_ARM)) && (launchin_count == 3))
unsigned int RevLimDownshift = (unsigned int)(((ram4.gear_ratio[outpc.gear - 1] * (unsigned long)outpc.vss1 * gear_scale) / 10000) + 200); // last addition is to bump up rpm for smoother shift.
RevLimRpm1 = RevLimDownshift - ram4.RevLimNormal2_hyst;
else
launchin_count = 0;
I think the code is getting good now. I've changed it to cancel rev limiting at about 3 seconds. Now the idle valve opens fully to rev the engine. Unfortunately it can only get the rpms up around 3500rpm. I even ported the valve which was a waste. Also I set the alternator low to take load off the engine. I need a solenoid that will open the throttle a bit, which means another output on the cpu. If anyone has an idea for a solenoid, I'd like to hear it.
Code: Select all
if ((launchin_count > 0) && (!(outpc.status2 & STATUS2_LAUNCHIN))) // cases where launchin_count never made it to 300
if (throttle_blip == 1)
IACmotor_pos = als_iacstep; // restore target that was saved previously in launch function
throttle_blip = 0;
launchin_count = 0;
if ((outpc.status2 & STATUS2_LAUNCHIN) && (launchin_count < 300)) // clutch in and ~3 seconds
if((outpc.gear >= 1) && (outpc.vss1 > 5))
else
if ((!(flagbyte21 & FLAGBYTE21_FLATS_ARM)) && (launchin_count >= 2) && (outpc.gear >= 1) && (outpc.vss1 > 150) && (outpc.rpm > 1500) && ((((*port_n2oin & pin_n2oin) == pin_match_n2oin) && pin_n2oin) || (throttle_blip == 1))) // brake pedal is activating nitrous in
if ((RevLimDownshift < RevLimRpm2) && (RevLimRpm1 > 1500)) // make sure down shift rev limit doesn't exceed normal limit
IACmotor_pos = 255;
throttle_blip = 1;
else if (launchin_count == 300)
throttle_blip = 0;
launchin_count = 301;
return;
else if (launchin_count == 301)
return;
I like this idea for replacing the throttle stop screw by a vacuum driven actuator.
https://grassrootsmotorsports.com/forum ... 068/page1/
I do not know how to build a universal system though. It will allways be a custom setup for your throttle body. Something cable-based could also be interesting. Aren't there these vacuum actuators for cruise-controll? Would they work?
btw: I like your code. Will try it.
Race car building documentation: www.kessel.tk (nice pics but only german laguage so far...)
Thanks.
Try it at your risk. Let me know how it goes.
I found a potential solenoid. It's an oem woodward 1502 made for fuel shutoff. I'll see if I can adapt it somehow.
Cool one. Powerless it is pulled in or out? can't figure it out.
It is out normally and in when powered.
Built a little development unit based on an Arduino see it at https://youtu.be/yNAnTdoznBI
Still needs a little development but as you can see the small pneumatic kicker will suit for your system
Very nice. I thought about using my vacuum pump to do the same thing. What is that little cylinder called so I can search for something like it?
It's a 6mm Bore 15mm Stroke CJPB6-15 Model Pneumatic Components Air Cylinder from Ebay number 291505674928 only £4.08 from China
Works very well
Works very well
So one (or even two) of these Bosch 2 wire IACs wouldn't be large enough?
They are the largest idle solenoid ive seen, and they are very easy to get and control.
It would be far simpler than some kind of pneumatic or otherwise throttle kicker.
Toyota Celica GT4/Alltrac with 5S-GTE stroker (2.2L I4 turbo, high CR) on E85 w/FlexFuel.
MS3 + MS3X + KnockBoard + RTC + BT + DIY CAN-IO-Board + DIY CAN Digital Dash.
This looks like a good option. I wonder really how much air those flow. How big are the hose fittings on there?
After receiving the solenoid I was planning to use, I can see it will be too bulky to make it work in a practical manner.
my car uses a valve like that the barbed ends go in to a 19mm (3/4 inch) pipe
For ITBs this will definitely not work. The bypass channels are to small.
On top with a blipper you are not needing additional mapping and tuning. I think the use of these valves require additional fuel adjustment possibilities
I hooked up a bosch two wire valve. It should do the trick. By itself it will rev the engine to 4500 rpm. It will even run the car at 60 mph with nothing else. Cruise control anyone? Hopefully both valves together will be enough. I played with it using generic pwm output. It is connected to js11. I need to figure out how to code the output now.
outpc.duty_pwm = duty;
Simple enough way to set the bosch idle valve to a duty cycle.
Now one thing I'm confused about is how outpc.vss1 works. I thought outpc.vss1 > 150 would mean greater than 15 mph. It seems to be acting like 30 mph though. Can anyone explain how the conversion from outpc.vss1 to mph works?
