Vvt, fuel and timing resolution
Postby jsimmons » Thu Apr 20, 2017 7:03 pm
Any chance we could get some larger tables? Especially on the vvt tables? The 8x8 table for vvt on my coyote doesnt have enough resolution for the rpm im running and im having to make compromises on the table with such large rpm gaps. Same goes for fuel and ignition but is less of a problem. The issue is only going to get worse as i contiune to build on my combo and spin it up to 10k rpm eventually
jsimmons
Re: Vvt, fuel and timing resolution
Postby Matt Cramer » Fri Apr 21, 2017 6:32 am
Can you post a copy of the tune file you have now? A data log could also give a better idea if there are points where the resolution is hurting accuracy.
Postby jsimmons » Fri Apr 21, 2017 1:07 pm
sure, ill email them to you matt.
jsimmons
Postby Matt Cramer » Mon Apr 24, 2017 7:04 am
Posting the files here in the thread would let the code team see them directly.
Return to MS3 Development
