MS3 Gold - Potential Bug? TC Reactions
goodysgotacuda
Post by goodysgotacuda »
I am getting into setting up my traction control and I can't quite get a handle on the reactions. MS3 Gold Box. MSQ and log attached in second post.
As you can see my (Slip x Time) pegs out at 110, my Spark: Traction Retard pegs at 13.0°
Where I am misaligned is how the (Slip x Time) is correlating to my reaction plot. As you can see, 13.0° of retard would be about 12-13 (Slip x Time) according to my plot.
Screen Shot 2017-11-06 at 5.48.21 PM.png (29.68 KiB) Viewed 381 times
Where is it getting the 13.0° of retard from at 100 (Slip x Time)? I would expect it to react "off the charts" and respond at 25° of retard....what am I missing?
Last edited by goodysgotacuda on Sun Nov 12, 2017 7:17 pm, edited 1 time in total.
MS3 Gold Box, TunerStudio MS/MegaLogViewerHD user
goodysgotacuda
Re: MS3 Gold - Potential Bug? TC Reactions
MSQ and Datalog attached
upload2017-11-06_17.45.24.msq
(266.58 KiB) Downloaded 22 times
2017-11-06_11.42.28.msl
(144.31 KiB) Downloaded 22 times
This appears to be a display issue, slipxtime is showing up 10x the value it should. So in your case it is really 10, not 100.
goodysgotacuda
jsmcortina wrote:This appears to be a display issue, slipxtime is showing up 10x the value it should. So in your case it is really 10, not 100.
Thanks James, how did you determine that?
I checked the code and the scalings in the ini file.
goodysgotacuda
jsmcortina wrote:I checked the code and the scalings in the ini file.
Sorry but is that something that I could somewhat easily remedy?
Rescaling the amount in my head while looking at a log by 10 isn’t too hard to do however.
goodysgotacuda
Would the change be here?? :RTFM:
Screen Shot 2017-11-13 at 9.08.05 PM.png (95.92 KiB) Viewed 331 times
BLR
Post by BLR »
I don't know if you got it already and I'm on my phone so if can't look at your log but I had the same problem.
Ended up the X axis on my T/C reations needed to be multiplied be 10 to correlate to my log. So a time x slip of 25 on reactions would be a 250 on the log.
Sent from my SM-G930F using Tapatalk
