CAN LOTUS BROADCAST
flycat
Re: CAN LOTUS BROADCAST
Post by flycat »
Hi James, sorry for retard, yesterday i have tested the car.
Result:
-CLT Ok
-RPM Ok
-KMH Not work (why? in the first test has good)
-Fuel level OK
-SHIFT LIGHT OK
- OIL WARNING LAMP OK
- MIL/CHECK LAMP tested status when engine not running and it's OK
The msq:
lotus_test2.msq
(273.44 KiB) Downloaded 94 times
Bye, Luca
Something strange with the speed calc, the broadcast testing results don't match up with the reverse engineered spec for the speed.
Test code sent.
AbatelliCristian
Post by AbatelliCristian »
I James,
I see your txt. I think there is a error in the conversion.
My idea is:
kph = (unsigned int) ((outpc.vss1 * 530538ul) / 10000ul);
From outpc.vss1 = 100, we get kph = 5305
vssout=(unsigned int) ((kph*912)/1000) //***** 100*912/1000 = 91= 5b
data[0] = vssout
data[1] = NOT USED
Did you test the latest code I sent? It was similar to the first version with the scaling factor set to 92% of the original.
AbatelliCristian
kph = (unsigned int) ((outpc.vss1 * 3312ul) / 10000ul);
From outpc.vss1 = 100, we get kph = 33
(36 * 92% = 33)
data[0] = 0
data[1] = 33
The error is in data1... data1 NOT USED
That's not what code I sent looks like though?
Code: Select all
  	kph = (unsigned int) ((outpc.vss1 * 530538ul) / 10000ul); /* Tweaked scaling based on 'flycat' feedback */
data[0] = (kph >> 8) & 0xff;
For 10.0 ms-1 that gives data[0]=20 (20mph ?)
One of the data sources said that the speed was in mph.
Be aware that the test code I sent is clobbering "Sensors 5" with the raw value of "kph"
flycat
Post by flycat »
Hi James, sorry for retard, i have tested the last code, now all fuction are active :yeah!: , kmh value isn't correct :oops: , but i have "calibrated" with a gps...with 1.35m of wheel diameter the value of instrument is correct :mrgreen:
Now we need only a correct scaling factor :RTFM:
Bye, Luca
