MAP Sampling Strategy
Tjabo
Post by Tjabo »
Hey guys,
Carrying this over from the MS2/Extra forum, I was wondering why you chose not to incorporate a window size parameter in the MS3 code?
Thanks!
Thad
muythaibxr
Re: MAP Sampling Strategy
Post by muythaibxr »
I didn't choose not to, it is in there although I might not have put it in an easy place to find.
Tjabo
Post by Tjabo »
Ahhhh, okay, I hadn't seen it. I saw the degrees at RPMs, and that's it. I'll have to look around a bit in the setup option windows and and see if I can find the MAP sampling window size somewhere (I take it by your statement Ken that you think you did put the parameter in there?).
So Ken, I take it that I have missed some discussions about this stuff that I could read up and kind of be up to speed? Other than that, this is all seeming like a bit of an inscrutable riddle to me! :lol:
Thad
muythaibxr
I am not sure I understand what it is you are missing. The setting is definitely there, although off the top of my head I do not remember where I put it.
It is just a timing in degrees btdc in the curve that tells the code where to start sampling, and a single window variable that tells the code how many degrees to sample over. Once the code starts sampling it will pass the lowest value sampled back to the main loop.
Tjabo
Post by Tjabo »
I just didn't see the window size parameter in there when I was messing with it before, and the addition of the window size parameter really makes this strategy a lot more logical to me.
I can't check on it right now, since my daughter has taken my tuning computer hostage to play some crazy kid's game on the internet, and I'm busy soldering in an attempted launch diode. I'll get back into it later this morning!
Thanks Ken, and sorry for the dumb questions!
Thad
muythaibxr
Your questions aren't dumb, I just didn't understand where the disconnect was.
