Opti spark
Opti spark
I've written an XGATE based wheel decoder for the Opti-spark that uses the hi-res wheel signal and should allow sequential fuel and COP on an optispark equipped engine.
However, I've come to try out the actual optispark I have and I can't get it to put out any signal at all. My first stumbling block is whether I've got it wired the right way around. All the diagrams on the 'net helpfully refers to pins A,B,C,D or the wire colours. That doesn't really help me as I have a bare opti and no pigtail.
Which pin is A ?
If this code works it should be fairly easy to adapt to the other 360 tooth CASes and also possibly the flywheel tooth triggering installs.
Which pin is A ?
Re: Opti spark
Looks like the red/black wire is pin A. This diagram is for a 96 Chevy Camaro 5.7.
2000 Suzuki Hayabusa turbo MS3 beta testing Plug and Play standalone
http://interfacepnp.webs.com/
http://www.youtube.com/Busams
Re: Opti spark
He doesn't have any wiring.... so he can't tell which wire is the red/black one. And he doesn't know which end is pin a...
Re: Opti spark
Does this help?
Re: Opti spark
We'll have to ask him, but that'll probably work.
Re: Opti spark
Looks like mine is broken then. I had pins ABCD the right way around but can't get any output on A or B even with a 12V pullup. A is stuck at 0.5V and B at 3.3V.
Re: Opti spark
If I recall correctly pins B & C need a 5v pullup-
Joe
Joe
78 Chev 4x4 MS3. Microsquit 4l80E (Toy Hauler/Beta test rig )
70 AAR Cuda -Hanger queen- 340 MS3 Seq- XV Level II
Re: Opti spark
I had used the pullup in the tests.
Re: Opti spark
This is probably silly to ask, but have you grounded the housing of the unit?
Looking at the schematic you'd intuitively think pin D is connected to power supply negative, but they went to a lot of trouble to label it "reference low"... mabye the actual negative connection is the housing?
Eric Law
Re: Opti spark
The optical module appears to be insulated from the housing.
Re: Opti spark
A correction of my above post.
Pin A 5v pullup
Pin b 5v pullup
Pin C 12v Ignition(Straight battery)
Pin D Ground
Joe
Pin A 5v pullup
Pin b 5v pullup
Pin D Ground
Joe
Re: Opti spark
James,
If you end up having a bad opti module and cant find one local PM me your address. I think I have one at work I'd be willing to send you.
(I'll check Monday)
Joe-
(I'll check Monday)
Joe-
