VVT ideas and testers
AbatelliCristian
Re: VVT ideas and testers
Post by AbatelliCristian »
AbatelliCristian wrote:Hi, James, I have tried your code. Is all ok, but there is a bug on cam4 read angle. The sensor input not read.
I'll try this out later. Developing and testing the 4 channel VVT is rather tricky as I don't have an easy means to generate the signals.
Hi James, You have testing channel 4 vvt?
Next week (28) I return in my city and I`ll try other test.
thanks
Post by jsmcortina »
I did do some testing and I was getting readings on VVT4 angle.
AbatelliCristian
mmmhh.... I will try reload the firmware and I`ll try new test.
AbatelliCristian
Hi James, I have reloaded your last code and the chanel 4 vvt not read.
I reload previus code and is all Ok. In the previus code the problem is if the angle read negative. Normaly work.
AbatelliCristian
In all alpha code I have I have a big problem with idle controll (drive fan). The signal out isn't pwm. Not work. I test with oscilloscope. For me is very important. If you can check it I will glad because in 8 july I have a race and the fan is necessary....
AbatelliCristian
Yesterday I have tried the car with vvt. Is all ok, but from 6500rpm to 7500 I have a misfire. Oly map100%. If test with minum throttle not problem.
In datalog is all ok. Afr ok, angle cam ok, pwm seq ok, sinc ok....
I have test <> vvt angle but misfire...
Idea? :?
Is possible skip iniection? or timing?
As I said before I don't think anything changed with PWM idle that should impact you between alpha 9 to alpha 11.
What changed for you from when alpha10 VVT4 didn't work and then alpha10 VVT4 did work ? Are these the posted releases or an intermediate test code I emailed ?
VVT4 ought to be working in alpha11, but there was a bug in alpha10. I sent you a fixed version that is partway between 10 and 11. (Check the date in the TunerStudio header.)
alpha10 ~ 2011-06-04
alpha 11 ~ 2011-07-02
AbatelliCristian
In alpha10 there was the bug. You send me alpha 10 correct and it is ok. Then you send me other alpha10 with correction for controll vvt angle on-off, but this not run input chan 4 vvt.
Have you enabled the VVT error indicators? Is it lighting up for VVT4 ?
The angle error checking looks to be the only change made since the first code I sent.
AbatelliCristian
mmmm.. I have tried on and off, but not read....
not remembar the light vvt error.
After race I reload alpha 11 and check
AbatelliCristian
Idea fo upgrade the vvt system.
Is possible change the PID parameter when oil temperature and pressure change?
AbatelliCristian
Hi, I see othe small bug in alpha10
In my car I have One switch for power ms3 and one botton for start engine
If the engine shutoff and I press start botton for restart engine vvt chanell2 not read. If power off ms3 and restart, all vvt read well...
AbatelliCristian
Today I reload the firmware alpha11. VVt4 chanel not read and vvt light is off. I tried with controll"on" and controll "off". I tried with reasing and falling.
I have notate in the test with alpha10 one condiction. The neutral duty is <> from right and left bank. For fine setting I think need select neutre duty for single channel...
AbatelliCristian
I have other IDEA.
When I start the engine I listen the metal rumor because the high pressur oil vvt not load immediately and solenoid work. After one or two second the rumor ending. If possible select a time for start the vvt system?
AbatelliCristian
AbatelliCristian
I see alpha 12.... You have check for vvt chanell4?
In the next week I test it....
AbatelliCristian wrote:I see alpha 12.... You have check for vvt chanell4?
No changes. We focussed on just the serial changes for Alpha12.
Just tested out VVT cam 4 input on alpha 14. It is working for me using PT4.
This is with "dual wheel with missing tooth" type of wheel though. I don't have the ability to test the BMW decoder.
busher06
Post by busher06 »
James,
Happy to report that we got the VVT up and running on alpha 14 with no real worries. I will probably come running for some help with the PID settings though.
Where do I find the details of injector trim other than the dead time adjustments?
David
AbatelliCristian
I don' t have idea where is the problem. With alpha10a is all ok.
In my configuration I use pt6 for vvt4 and use 6 teeth for intake.
thanks for your work
