jsmcortina wrote:Even more strange. That suggests that something broke during the "new serial" changes, but they were supposed to be serial changes only.
I almost wonder if your settings aren't getting through correctly ?
TS is back to constantly dropping the connection if the ignition is on without the engine running. I don't think I ran into that problem with the new serial.
UnaClocker wrote:Key on, which makes the ignition on. Engine not running. TS will connect, stay connected for about 10-15 seconds, then drop the connection and go offline for a few seconds, comes back, does it again, two or three times later I get an error message and it stays offline till I close and re-open TS.
Like I said, this car and computer are a great candidate for the new serial code, I've always had issues with it staying connected. I've seen other people report this issue in the past, it's a bug that I've had for a long long time. I could shoot some video of it happening..
LT401Vette wrote:It sounds like what your guys are talking about is different from UnaClocker. His issue is only happening when it the key is on but the engine is off and he is doing nothing else. After about 5 seconds he gets this message:
Warning!!
Communication Established!
However, there is a configuration error with your firmware.
As I understand it, this is happening with either the released TunerStudio or 1.074, but not with the new serial.
Now if you are getting an error message new to 1.074 and against released firmware, please go ahead and open a new report in the TunerStudio forum describing what actions cause it. It is not a known issue.
LT401Vette wrote:If it is that exact error message then it is the same error.
UnaClocker said that went away with the new Serial, but it sounds like elaw is still seeing it?
If nobody else has by then, I'll start a thread in the TS forum this evening after I've had time to test more and try and narrow down when this does and does not occur. I posted here mainly to point out that this doesn't just happen with the "new serial" code on the MS side.
Users browsing this forum: Sam280Z and 3 guests
