i got the composite log and i found the problem we had was jumper conected on the megasquirt expansion "JP7 INPUT PULLUP JUMPER".
i got a a couple of question i dont know how to hook up the camsensor on the wiring diagram it shows that you got to conect it to main ground plug DB37
http://www.msextra.com/doc/ms3/hardware ... iring-ms3x so that means that i got to hook it up to the pin 14,15,16,17,18,19? the one that says good engine ground or the pin number 7 the one that goes to the tps wide band mat coolant sensor?
http://www.msextra.com/doc/ms3/hardware ... iring-ms3xand another thing i did the injector test and it did work but i try to do the coil test and had no luck so i was wondering do i have to conect the oem igniter? or probably the coils are not conected like they should,its a 2 wire coil and using the ms3x for the coil spk a spk b and spk c
