Progressive Water Injection and MS3 without a fast valve.
Re: Progressive Water Injection and MS3 without a fast valve
It's no longer on my car as I rolled and totaled it back in January. However the system is up and running on my buddy's car, still being controlled by MS, still using the "fast" frequency setting to control the pump.
Support the developers!
Sorry for reactivating this thread again
But, I have a MS3X and would like to controll the pump via the MS3.
From what I have found so var is that the snow pump is being controlled with PWM - freq being 47hz
I also need to use a solenoid valve as the pump and tank is in the boot, after comunication with snow they advised to just connect it with the pump on PWM.
The pump is rated to 11amp at 220psi, plus what the solenoid vale draws.
I do not want to mod the msx3 - so can someone suggest a circuit that I can use as an external driver for this setup.
Mike
Mike
I use the main board injector driver to pwm the pump and nitrous 1 for the solenoid
Here is the settings I use I know it looks bacwards but this is how it needs to be
Thanks for the feedback, will run it that way
