MS3 1.0 source code released
Post by jsmcortina »
To announce the long-awaited release of source code for MS3 1.0.
Be sure to read and respect the included README and LICENSE files.
http://www.msextra.com/doc/ms3/files/source
Reverant
Re: MS3 source code released
Post by Reverant »
Excellent, thank you James and Ken!
The man behind MS Labs
y8s
Post by y8s »
that's pretty cool. now I just have to learn to program.
gurov
Post by gurov »
wow...
thank you. i'll have to take a look at the things myself now.
2020 BMW X3M - bm3 - stage1
1994 Supra - ms3pnp pro - j&s
SymTech Laboratories
Post by SymTech Laboratories »
Will the source code for the MS3 Firmware Downloader be released as well?
SymTech Laboratories, LLC ----- MSQ File Repository: megasquirt.symtechlabs.com
SymTech Laboratories wrote:Will the source code for the MS3 Firmware Downloader be released as well?
At some point yes. It needs cleaning up somewhat and a few issues resolving when used in "developer mode".
David. A
Post by David. A »
Awesome news !
Does a changed and re-compiled code will be sign as version 1.03 ?
What about api for tunerStudio ?
Let's say i want to change the CL idle condition when using VSS.
Instead of VSS=0 i want it to be a value defined on tunerStudio and not hard coded.
And last question, what is the best flow to move from alpha 16 to release 1.03.
Thanks !
David
Car: BMW 318Ti 1995 1.8 M42 Engine.
Megasquirt 3.0 + MS3x board Code 1.3
4cyl Cop Ignition,crank+cam wheels based on vr sensors.
Ignition: full sequential
Fuel: full sequential
Bosch 3 wire pwm idle valve
muythaibxr
Post by muythaibxr »
David. A wrote: Instead of VSS=0 i want it to be a value defined on tunerStudio and not hard coded.
Thanks !
David
Alpha 17 will have some changes in it that make the VSS change unnecessary most likely.
I can easily add the setting too.
David. A
Post by David. A »
Sound interesting.
But i'm more interested coding my own changes.
The option to change the code is not enough if we can't change tunerStudio to match the change.
What about source code for the latest alpha versions ?
And what do i need to "downgrade" from alpha16 to release 1.03 code.
David
David. A wrote:Sound interesting.
Edit the ini file. Very little is "built-in" to TunerStudio, almost everything can be changed through the ini file - just like it has always been since Megatune.
That will be released some time after the 1.1 code is "release"
Load the firmware and load your MSQ, taking note of the warnings. Reconfirm your settings.
ScoobyCoder
Post by ScoobyCoder »
James,
Will the bootloader file be released? I use Codewarrior and after playing with the MS2 and knowing how easy it is to completely wipe the chip, (James you helped me out with this a while back now!) I would like to be able to upload my code changes without needing my BDM, as when playing in the car its just not practical. Ideally I would like to be able to reflash the chip back to purchase state at any time, just don't want to have to be sending it forwards and backwards to be rebootloaded, as when I use the BDM on a running chip CW sometimes erases the chip, as it did with my old MS2 board...
Of course, this begs the question, if I were to just load my newly compiled MS3 S19 onto the uP, would it work? And can I set codewarrior to not erase the chip before a burn?
Thanks,
Mark
ScoobyCoder wrote:James,
No, it will not be released.
You will not be able to use HIWAVE to load the s19 as the chip is in 'secure' mode.
ScoobyCoder
James,
Ok, thanks for the reply.
So its strictly compile and use the bootloader, thats fine, I'll go careful!
Thanks,
Mark
Bad bug
Post by Bad bug »
I haven't downloaded anything but programming language was used for the MS3.
ScoobyCoder
Its written in C :)
Bad bug
Post by Bad bug »
O.k. great i will have to do a course in C then to fully appreciate this ECU.
ScoobyCoder
Ok,
So I have codewarrior installed, and I want to open the source as a project, is here a project file, or do I need to start from scratch? The end reult is I can then compile and use the bootloader to download the S12, but as far as I can see there is no main project file, just the C code and headers etc?
Cheers
Mark
Codewarrior is untested. We use gcc. This is covered in the README-BUILDING.txt file.
ScoobyCoder
Ah ok,
In my silly hastiness I may of just broken something, tried using CW and the BDM, says no memroy at 100100 or something? NOt sure what I have done, should of stuck to the usual uploader but like my old tools lol!!
I'll see if I can revive it :D
And also I'll have a god read of the BULDING readme :)
Regards,
Mark
Don't try to use BDM. It will ask you to Unsecure, if you do that, you had better wrap it up and post it off for a reflash.
