MS3 source code - building
James,
I tried following the instructions included in the zip files. I was able to extract the tools.tar.gz file in the C:/ dir but I was not able to create the ./buildit dir. Also when I go to the shell command line and in the source dir, I type 'make' and I get an error. Not sure exactly what to do from there. Any suggestions?
Re: MS3 source code - building
Why are you trying to recompile the build tools? Precompiled versions are included for Windows and Linux.
You'll have to post more information (screen shots, messages etc.) for any real help.
This is the error that I am getting
I got it to work. I was extracting the files to the wrong directory. I was able to build the .S19 file successfully.
Im having a bit of a problem also , here is my cygwin screen after i type make .
2000 Suzuki Hayabusa turbo MS3 beta testing Plug and Play standalone
http://interfacepnp.webs.com/
http://www.youtube.com/Busams
You don't have the build tools installed or they aren't where the Makefile is looking.
The output from 'which' tells you where it was looking.
You will have to give me the guide for dummies .
Where do the build tools go ?
Do i unzip the build tools and manually put them into a directory ?
Follow the install instructions that code with the build tools.
Tried to follow that. It's not easily understandable. Still stuck with it.jsmcortina wrote:Follow the install instructions that code with the build tools.
So is MS2.
(4G63T - MSIIextra) (4G13 - MS3-beta testing)
What happens exactly ? Pretty difficult to help you without more information.Gokart wrote:Tried to follow that. It's not easily understandable. Still stuck with it.jsmcortina wrote:Follow the install instructions that code with the build tools.
So is MS2.
I tried to build my source code for MS2, but I am stuck...
I work with window7 in 64bit, is it a problem? So I work with sigwin64.
When I unzip :s12buildtools-win32-2012-10-24.zip, where should I put it?
If I put: tools.tar in C:/cygwin64/
I am not able to do:
cd C:/
tar xfz <path>/tools.tar.gz
I can only unzipp manually or without <path> in command line
Should folder ''usr'' be in C:/ or in C:/cygwin64?
And also the command ''make'' doesn't works
cd C:/
You need to replace <path> with the actual path of the tar file.
I have done a new instal on a 32bits windows
During ''untar'' I get some errors
And when I use ''make'' too
I am stuck.. If someone can help me?
Code: Select all
Admin@xpsp2-cdd0fae6a /cygdrive/c
$ tar xfz /tools.tar.gz
tar: usr/bin/m68hc11-elf-gcc.exe: Cannot hard link to `usr/bin/m68hc11-elf-gcc-3.3.6-9s12x-20120502.exe': Operation not permitted
tar: usr/bin/m68hc11-elf-ld.exe: Cannot hard link to `usr/bin/m68hc11-elf-ld.bfd.exe': Operation not permitted
tar: usr/m68hc11-elf/bin/ar.exe: Cannot hard link to `usr/bin/m68hc11-elf-ar.exe': Operation not permitted
tar: usr/m68hc11-elf/bin/as.exe: Cannot hard link to `usr/bin/m68hc11-elf-as.exe': Operation not permitted
tar: usr/m68hc11-elf/bin/ld.bfd.exe: Cannot hard link to `usr/bin/m68hc11-elf-ld.bfd.exe': Operation not permitted
tar: usr/m68hc11-elf/bin/ld.exe: Cannot hard link to `usr/bin/m68hc11-elf-ld.bfd.exe': Operation not permitted
tar: usr/m68hc11-elf/bin/nm.exe: Cannot hard link to `usr/bin/m68hc11-elf-nm.exe': Operation not permitted
tar: usr/m68hc11-elf/bin/objcopy.exe: Cannot hard link to `usr/bin/m68hc11-elf-objcopy.exe': Operation not permitted
tar: usr/m68hc11-elf/bin/objdump.exe: Cannot hard link to `usr/bin/m68hc11-elf-objdump.exe': Operation not permitted
tar: usr/m68hc11-elf/bin/ranlib.exe: Cannot hard link to `usr/bin/m68hc11-elf-ranlib.exe': Operation not permitted
tar: usr/m68hc11-elf/bin/strip.exe: Cannot hard link to `usr/bin/m68hc11-elf-strip.exe': Operation not permitted
tar: usr/m68hc11-elf/lib/fshort-double/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/fshort-double/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/fshort-double/mlong-calls/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/fshort-double/mlong-calls/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/m68hc12/fshort-double/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/m68hc12/fshort-double/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/m68hc12/fshort-double/mlong-calls/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/m68hc12/fshort-double/mlong-calls/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/m68hc12/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/m68hc12/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/m68hc12/mlong-calls/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/m68hc12/mlong-calls/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/m68hc12/mshort/fshort-double/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/m68hc12/mshort/fshort-double/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/m68hc12/mshort/fshort-double/mlong-calls/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/m68hc12/mshort/fshort-double/mlong-calls/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/m68hc12/mshort/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/m68hc12/mshort/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/m68hc12/mshort/mlong-calls/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/m68hc12/mshort/mlong-calls/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/m9s12x/fshort-double/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/m9s12x/fshort-double/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/m9s12x/fshort-double/mlong-calls/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/m9s12x/fshort-double/mlong-calls/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/m9s12x/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/m9s12x/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/m9s12x/mlong-calls/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/m9s12x/mlong-calls/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/m9s12x/mshort/fshort-double/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/m9s12x/mshort/fshort-double/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/m9s12x/mshort/fshort-double/mlong-calls/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/m9s12x/mshort/fshort-double/mlong-calls/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/m9s12x/mshort/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/m9s12x/mshort/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/m9s12x/mshort/mlong-calls/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/m9s12x/mshort/mlong-calls/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/mlong-calls/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/mlong-calls/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/mshort/fshort-double/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/mshort/fshort-double/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/mshort/fshort-double/mlong-calls/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/mshort/fshort-double/mlong-calls/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/mshort/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/mshort/libc.a': Operation not permitted
tar: usr/m68hc11-elf/lib/mshort/mlong-calls/libg.a: Cannot hard link to `usr/m68hc11-elf/lib/mshort/mlong-calls/libc.a': Operation not permitted
tar: Exiting with failure status due to previous errors
Code: Select all
Admin@xpsp2-cdd0fae6a /cygdrive/c/usr/ms2extra_3.3.1_release/ms2extra
$ make
which: no m68hc11-elf-gcc in (/usr/local/bin:/usr/bin:/cygdrive/c/WINDOWS/system32:/cygdrive/c/WINDOWS:/cygdrive/c/WINDOWS/System32/Wbem:/usr/bin)
ls: cannot access /usr/bin/m68hc11-elf-gcc: No such file or directory
ls: cannot access c:/usr/bin/m68hc11-elf-gcc: No such file or directory
make make_megasquirt2
make[1]: Entering directory '/cygdrive/c/usr/ms2extra_3.3.1_release/ms2extra'
echo '// setup for Megasquirt' > us_opt_c.h
echo '; setup for Megasquirt' > us_opt_asm.inc
grep -v "^#[12345]" ms2extra.ini | sed 's/^#0//' > megasquirt2.ini
echo "/* DO NOT EDIT - this file is automatically generated during build */" > ms2_extra_defines.h
grep "^#define" ms2_extra_vars.h >> ms2_extra_defines.h
echo "; DO NOT EDIT - this file is automatically generated during build" > ms2_extra_defines.inc
grep "^#define" ms2_extra_vars.h | awk '{print ".equ",$2,",",$3};' >> ms2_extra_defines.inc
echo "/* DO NOT EDIT - this file is automatically generated during build */" > ms2_extra_main_vars.h
cat ms2_extra_vars.h | sed 's/extern //' | grep -v "^#" >> ms2_extra_main_vars.h
m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m68hcs12 -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -c ms2_extra_main.c
make[1]: m68hc11-elf-gcc: Command not found
Makefile:149: recipe for target 'ms2_extra_main.o' failed
make[1]: *** [ms2_extra_main.o] Error 127
make[1]: Leaving directory '/cygdrive/c/usr/ms2extra_3.3.1_release/ms2extra'
Makefile:47: recipe for target 'megasquirt' failed
make: *** [megasquirt] Error 2
Possibly a permissions issue with your cygwin install?
Until the tar xvf works, you cannot proceed.
On my W7 64bits, tar xvf works.
I add C:/usr/bin in windows path configuration
But I still have a problem with ''make''
Regards,
Caporiacco.
Code: Select all
adu@IO-580 /cygdrive/c/ms2extra_pre3.3rc1/ms2extra
$ tar xvf /tools.tar.gz
usr/
usr/bin/
usr/bin/m68hc11-elf-addr2line.exe
usr/bin/m68hc11-elf-c++filt.exe
usr/bin/m68hc11-elf-cpp.exe
usr/bin/m68hc11-elf-elfedit.exe
usr/bin/m68hc11-elf-gccbug
usr/bin/m68hc11-elf-gcov.exe
usr/bin/m68hc11-elf-gprof.exe
usr/bin/m68hc11-elf-readelf.exe
usr/bin/m68hc11-elf-size.exe
usr/bin/m68hc11-elf-strings.exe
usr/include/
usr/info/
usr/info/configure.info
usr/info/cpp.info
usr/info/cppinternals.info
usr/info/gcc.info
usr/info/gccint.info
usr/info/standards.info
usr/lib/
usr/lib/gcc-lib/
usr/lib/gcc-lib/m68hc11-elf/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/cc1.exe
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/collect2.exe
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/fshort-double/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/fshort-double/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/fshort-double/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/fshort-double/mlong-calls/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/fshort-double/mlong-calls/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/fshort-double/mlong-calls/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/include/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/include/fixed
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/include/float.h
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/include/iso646.h
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/include/limits.h
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/include/README
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/include/stdarg.h
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/include/stdbool.h
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/include/stddef.h
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/include/syslimits.h
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/include/unwind.h
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/include/varargs.h
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/install-tools/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/install-tools/fix-header.exe
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/install-tools/fixinc.sh
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/install-tools/fixincl.exe
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/install-tools/fixproto
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/install-tools/gsyslimits.h
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/install-tools/include/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/install-tools/include/float.h
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/install-tools/include/iso646.h
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/install-tools/include/limits.h
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/install-tools/include/README
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/install-tools/include/stdarg.h
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/install-tools/include/stdbool.h
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/install-tools/include/stddef.h
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/install-tools/include/unwind.h
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/install-tools/include/varargs.h
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/install-tools/mkheaders
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/install-tools/mkheaders.conf
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/install-tools/mkinstalldirs
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/fshort-double/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/fshort-double/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/fshort-double/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/fshort-double/mlong-calls/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/fshort-double/mlong-calls/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/fshort-double/mlong-calls/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/mlong-calls/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/mlong-calls/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/mlong-calls/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/mshort/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/mshort/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/mshort/fshort-double/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/mshort/fshort-double/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/mshort/fshort-double/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/mshort/fshort-double/mlong-calls/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/mshort/fshort-double/mlong-calls/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/mshort/fshort-double/mlong-calls/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/mshort/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/mshort/mlong-calls/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/mshort/mlong-calls/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m68hc12/mshort/mlong-calls/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/fshort-double/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/fshort-double/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/fshort-double/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/fshort-double/mlong-calls/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/fshort-double/mlong-calls/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/fshort-double/mlong-calls/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/mlong-calls/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/mlong-calls/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/mlong-calls/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/mshort/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/mshort/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/mshort/fshort-double/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/mshort/fshort-double/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/mshort/fshort-double/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/mshort/fshort-double/mlong-calls/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/mshort/fshort-double/mlong-calls/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/mshort/fshort-double/mlong-calls/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/mshort/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/mshort/mlong-calls/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/mshort/mlong-calls/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/m9s12x/mshort/mlong-calls/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/mlong-calls/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/mlong-calls/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/mlong-calls/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/mshort/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/mshort/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/mshort/fshort-double/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/mshort/fshort-double/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/mshort/fshort-double/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/mshort/fshort-double/mlong-calls/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/mshort/fshort-double/mlong-calls/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/mshort/fshort-double/mlong-calls/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/mshort/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/mshort/mlong-calls/
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/mshort/mlong-calls/crt1.o
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/mshort/mlong-calls/libgcc.a
usr/lib/gcc-lib/m68hc11-elf/3.3.6-9s12x-20120502/specs
usr/lib/libiberty.a
usr/m68hc11-elf/
usr/m68hc11-elf/bin/gcc.exe
usr/m68hc11-elf/include/
usr/m68hc11-elf/include/alloca.h
usr/m68hc11-elf/include/ar.h
usr/m68hc11-elf/include/argz.h
usr/m68hc11-elf/include/assert.h
usr/m68hc11-elf/include/bits/
usr/m68hc11-elf/include/ctype.h
usr/m68hc11-elf/include/dirent.h
usr/m68hc11-elf/include/envz.h
usr/m68hc11-elf/include/errno.h
usr/m68hc11-elf/include/fastmath.h
usr/m68hc11-elf/include/fcntl.h
usr/m68hc11-elf/include/getopt.h
usr/m68hc11-elf/include/grp.h
usr/m68hc11-elf/include/iconv.h
usr/m68hc11-elf/include/ieeefp.h
usr/m68hc11-elf/include/inttypes.h
usr/m68hc11-elf/include/langinfo.h
usr/m68hc11-elf/include/libgen.h
usr/m68hc11-elf/include/limits.h
usr/m68hc11-elf/include/locale.h
usr/m68hc11-elf/include/machine/
usr/m68hc11-elf/include/machine/ansi.h
usr/m68hc11-elf/include/machine/endian.h
usr/m68hc11-elf/include/machine/fastmath.h
usr/m68hc11-elf/include/machine/ieeefp.h
usr/m68hc11-elf/include/machine/malloc.h
usr/m68hc11-elf/include/machine/param.h
usr/m68hc11-elf/include/machine/setjmp-dj.h
usr/m68hc11-elf/include/machine/setjmp.h
usr/m68hc11-elf/include/machine/stdlib.h
usr/m68hc11-elf/include/machine/termios.h
usr/m68hc11-elf/include/machine/time.h
usr/m68hc11-elf/include/machine/types.h
usr/m68hc11-elf/include/machine/_default_types.h
usr/m68hc11-elf/include/machine/_types.h
usr/m68hc11-elf/include/malloc.h
usr/m68hc11-elf/include/math.h
usr/m68hc11-elf/include/newlib.h
usr/m68hc11-elf/include/paths.h
usr/m68hc11-elf/include/process.h
usr/m68hc11-elf/include/pthread.h
usr/m68hc11-elf/include/pwd.h
usr/m68hc11-elf/include/reent.h
usr/m68hc11-elf/include/regdef.h
usr/m68hc11-elf/include/sched.h
usr/m68hc11-elf/include/search.h
usr/m68hc11-elf/include/setjmp.h
usr/m68hc11-elf/include/signal.h
usr/m68hc11-elf/include/stdint.h
usr/m68hc11-elf/include/stdio.h
usr/m68hc11-elf/include/stdlib.h
usr/m68hc11-elf/include/string.h
usr/m68hc11-elf/include/sys/
usr/m68hc11-elf/include/sys/cdefs.h
usr/m68hc11-elf/include/sys/config.h
usr/m68hc11-elf/include/sys/custom_file.h
usr/m68hc11-elf/include/sys/dirent.h
usr/m68hc11-elf/include/sys/errno.h
usr/m68hc11-elf/include/sys/fcntl.h
usr/m68hc11-elf/include/sys/features.h
usr/m68hc11-elf/include/sys/file.h
usr/m68hc11-elf/include/sys/iconvnls.h
usr/m68hc11-elf/include/sys/lock.h
usr/m68hc11-elf/include/sys/param.h
usr/m68hc11-elf/include/sys/queue.h
usr/m68hc11-elf/include/sys/reent.h
usr/m68hc11-elf/include/sys/resource.h
usr/m68hc11-elf/include/sys/sched.h
usr/m68hc11-elf/include/sys/signal.h
usr/m68hc11-elf/include/sys/stat.h
usr/m68hc11-elf/include/sys/stdio.h
usr/m68hc11-elf/include/sys/string.h
usr/m68hc11-elf/include/sys/syslimits.h
usr/m68hc11-elf/include/sys/time.h
usr/m68hc11-elf/include/sys/timeb.h
usr/m68hc11-elf/include/sys/times.h
usr/m68hc11-elf/include/sys/types.h
usr/m68hc11-elf/include/sys/unistd.h
usr/m68hc11-elf/include/sys/utime.h
usr/m68hc11-elf/include/sys/wait.h
usr/m68hc11-elf/include/sys/_default_fcntl.h
usr/m68hc11-elf/include/sys/_types.h
usr/m68hc11-elf/include/tar.h
usr/m68hc11-elf/include/termios.h
usr/m68hc11-elf/include/time.h
usr/m68hc11-elf/include/unctrl.h
usr/m68hc11-elf/include/unistd.h
usr/m68hc11-elf/include/utime.h
usr/m68hc11-elf/include/utmp.h
usr/m68hc11-elf/include/wchar.h
usr/m68hc11-elf/include/wctype.h
usr/m68hc11-elf/include/_ansi.h
usr/m68hc11-elf/include/_syslist.h
usr/m68hc11-elf/lib/crt0.o
usr/m68hc11-elf/lib/fshort-double/crt0.o
usr/m68hc11-elf/lib/fshort-double/libbcc.a
usr/m68hc11-elf/lib/fshort-double/libm.a
usr/m68hc11-elf/lib/fshort-double/libnosys.a
usr/m68hc11-elf/lib/fshort-double/mlong-calls/crt0.o
usr/m68hc11-elf/lib/fshort-double/mlong-calls/libbcc.a
usr/m68hc11-elf/lib/fshort-double/mlong-calls/libm.a
usr/m68hc11-elf/lib/fshort-double/mlong-calls/libnosys.a
usr/m68hc11-elf/lib/fshort-double/mlong-calls/sim-valid.ld
usr/m68hc11-elf/lib/fshort-double/sim-valid.ld
usr/m68hc11-elf/lib/ldscripts/
usr/m68hc11-elf/lib/ldscripts/m68hc11elf.x
usr/m68hc11-elf/lib/ldscripts/m68hc11elf.xbn
usr/m68hc11-elf/lib/ldscripts/m68hc11elf.xn
usr/m68hc11-elf/lib/ldscripts/m68hc11elf.xr
usr/m68hc11-elf/lib/ldscripts/m68hc11elf.xu
usr/m68hc11-elf/lib/ldscripts/m68hc11elfb.x
usr/m68hc11-elf/lib/ldscripts/m68hc11elfb.xbn
usr/m68hc11-elf/lib/ldscripts/m68hc11elfb.xn
usr/m68hc11-elf/lib/ldscripts/m68hc11elfb.xr
usr/m68hc11-elf/lib/ldscripts/m68hc11elfb.xu
usr/m68hc11-elf/lib/ldscripts/m68hc12elf.x
usr/m68hc11-elf/lib/ldscripts/m68hc12elf.xbn
usr/m68hc11-elf/lib/ldscripts/m68hc12elf.xn
usr/m68hc11-elf/lib/ldscripts/m68hc12elf.xr
usr/m68hc11-elf/lib/ldscripts/m68hc12elf.xu
usr/m68hc11-elf/lib/ldscripts/m68hc12elfb.x
usr/m68hc11-elf/lib/ldscripts/m68hc12elfb.xbn
usr/m68hc11-elf/lib/ldscripts/m68hc12elfb.xn
usr/m68hc11-elf/lib/ldscripts/m68hc12elfb.xr
usr/m68hc11-elf/lib/ldscripts/m68hc12elfb.xu
usr/m68hc11-elf/lib/libbcc.a
usr/m68hc11-elf/lib/libm.a
usr/m68hc11-elf/lib/libnosys.a
usr/m68hc11-elf/lib/m68hc12/crt0.o
usr/m68hc11-elf/lib/m68hc12/fshort-double/crt0.o
usr/m68hc11-elf/lib/m68hc12/fshort-double/libbcc.a
usr/m68hc11-elf/lib/m68hc12/fshort-double/libm.a
usr/m68hc11-elf/lib/m68hc12/fshort-double/libnosys.a
usr/m68hc11-elf/lib/m68hc12/fshort-double/mlong-calls/crt0.o
usr/m68hc11-elf/lib/m68hc12/fshort-double/mlong-calls/libbcc.a
usr/m68hc11-elf/lib/m68hc12/fshort-double/mlong-calls/libm.a
usr/m68hc11-elf/lib/m68hc12/fshort-double/mlong-calls/libnosys.a
usr/m68hc11-elf/lib/m68hc12/fshort-double/mlong-calls/sim-valid.ld
usr/m68hc11-elf/lib/m68hc12/fshort-double/sim-valid.ld
usr/m68hc11-elf/lib/m68hc12/libbcc.a
usr/m68hc11-elf/lib/m68hc12/libm.a
usr/m68hc11-elf/lib/m68hc12/libnosys.a
usr/m68hc11-elf/lib/m68hc12/mlong-calls/crt0.o
usr/m68hc11-elf/lib/m68hc12/mlong-calls/libbcc.a
usr/m68hc11-elf/lib/m68hc12/mlong-calls/libm.a
usr/m68hc11-elf/lib/m68hc12/mlong-calls/libnosys.a
usr/m68hc11-elf/lib/m68hc12/mlong-calls/sim-valid.ld
usr/m68hc11-elf/lib/m68hc12/mshort/crt0.o
usr/m68hc11-elf/lib/m68hc12/mshort/fshort-double/crt0.o
usr/m68hc11-elf/lib/m68hc12/mshort/fshort-double/libbcc.a
usr/m68hc11-elf/lib/m68hc12/mshort/fshort-double/libm.a
usr/m68hc11-elf/lib/m68hc12/mshort/fshort-double/libnosys.a
usr/m68hc11-elf/lib/m68hc12/mshort/fshort-double/mlong-calls/crt0.o
usr/m68hc11-elf/lib/m68hc12/mshort/fshort-double/mlong-calls/libbcc.a
usr/m68hc11-elf/lib/m68hc12/mshort/fshort-double/mlong-calls/libm.a
usr/m68hc11-elf/lib/m68hc12/mshort/fshort-double/mlong-calls/libnosys.a
usr/m68hc11-elf/lib/m68hc12/mshort/fshort-double/mlong-calls/sim-valid.ld
usr/m68hc11-elf/lib/m68hc12/mshort/fshort-double/sim-valid.ld
usr/m68hc11-elf/lib/m68hc12/mshort/libbcc.a
usr/m68hc11-elf/lib/m68hc12/mshort/libm.a
usr/m68hc11-elf/lib/m68hc12/mshort/libnosys.a
usr/m68hc11-elf/lib/m68hc12/mshort/mlong-calls/crt0.o
usr/m68hc11-elf/lib/m68hc12/mshort/mlong-calls/libbcc.a
usr/m68hc11-elf/lib/m68hc12/mshort/mlong-calls/libm.a
usr/m68hc11-elf/lib/m68hc12/mshort/mlong-calls/libnosys.a
usr/m68hc11-elf/lib/m68hc12/mshort/mlong-calls/sim-valid.ld
usr/m68hc11-elf/lib/m68hc12/mshort/sim-valid.ld
usr/m68hc11-elf/lib/m68hc12/sim-valid.ld
usr/m68hc11-elf/lib/m9s12x/crt0.o
usr/m68hc11-elf/lib/m9s12x/fshort-double/crt0.o
usr/m68hc11-elf/lib/m9s12x/fshort-double/libbcc.a
usr/m68hc11-elf/lib/m9s12x/fshort-double/libm.a
usr/m68hc11-elf/lib/m9s12x/fshort-double/libnosys.a
usr/m68hc11-elf/lib/m9s12x/fshort-double/mlong-calls/crt0.o
usr/m68hc11-elf/lib/m9s12x/fshort-double/mlong-calls/libbcc.a
usr/m68hc11-elf/lib/m9s12x/fshort-double/mlong-calls/libm.a
usr/m68hc11-elf/lib/m9s12x/fshort-double/mlong-calls/libnosys.a
usr/m68hc11-elf/lib/m9s12x/fshort-double/mlong-calls/sim-valid.ld
usr/m68hc11-elf/lib/m9s12x/fshort-double/sim-valid.ld
usr/m68hc11-elf/lib/m9s12x/libbcc.a
usr/m68hc11-elf/lib/m9s12x/libm.a
usr/m68hc11-elf/lib/m9s12x/libnosys.a
usr/m68hc11-elf/lib/m9s12x/mlong-calls/crt0.o
usr/m68hc11-elf/lib/m9s12x/mlong-calls/libbcc.a
usr/m68hc11-elf/lib/m9s12x/mlong-calls/libm.a
usr/m68hc11-elf/lib/m9s12x/mlong-calls/libnosys.a
usr/m68hc11-elf/lib/m9s12x/mlong-calls/sim-valid.ld
usr/m68hc11-elf/lib/m9s12x/mshort/crt0.o
usr/m68hc11-elf/lib/m9s12x/mshort/fshort-double/crt0.o
usr/m68hc11-elf/lib/m9s12x/mshort/fshort-double/libbcc.a
usr/m68hc11-elf/lib/m9s12x/mshort/fshort-double/libm.a
usr/m68hc11-elf/lib/m9s12x/mshort/fshort-double/libnosys.a
usr/m68hc11-elf/lib/m9s12x/mshort/fshort-double/mlong-calls/crt0.o
usr/m68hc11-elf/lib/m9s12x/mshort/fshort-double/mlong-calls/libbcc.a
usr/m68hc11-elf/lib/m9s12x/mshort/fshort-double/mlong-calls/libm.a
usr/m68hc11-elf/lib/m9s12x/mshort/fshort-double/mlong-calls/libnosys.a
usr/m68hc11-elf/lib/m9s12x/mshort/fshort-double/mlong-calls/sim-valid.ld
usr/m68hc11-elf/lib/m9s12x/mshort/fshort-double/sim-valid.ld
usr/m68hc11-elf/lib/m9s12x/mshort/libbcc.a
usr/m68hc11-elf/lib/m9s12x/mshort/libm.a
usr/m68hc11-elf/lib/m9s12x/mshort/libnosys.a
usr/m68hc11-elf/lib/m9s12x/mshort/mlong-calls/crt0.o
usr/m68hc11-elf/lib/m9s12x/mshort/mlong-calls/libbcc.a
usr/m68hc11-elf/lib/m9s12x/mshort/mlong-calls/libm.a
usr/m68hc11-elf/lib/m9s12x/mshort/mlong-calls/libnosys.a
usr/m68hc11-elf/lib/m9s12x/mshort/mlong-calls/sim-valid.ld
usr/m68hc11-elf/lib/m9s12x/mshort/sim-valid.ld
usr/m68hc11-elf/lib/m9s12x/sim-valid.ld
usr/m68hc11-elf/lib/mlong-calls/crt0.o
usr/m68hc11-elf/lib/mlong-calls/libbcc.a
usr/m68hc11-elf/lib/mlong-calls/libm.a
usr/m68hc11-elf/lib/mlong-calls/libnosys.a
usr/m68hc11-elf/lib/mlong-calls/sim-valid.ld
usr/m68hc11-elf/lib/mshort/crt0.o
usr/m68hc11-elf/lib/mshort/fshort-double/crt0.o
usr/m68hc11-elf/lib/mshort/fshort-double/libbcc.a
usr/m68hc11-elf/lib/mshort/fshort-double/libm.a
usr/m68hc11-elf/lib/mshort/fshort-double/libnosys.a
usr/m68hc11-elf/lib/mshort/fshort-double/mlong-calls/crt0.o
usr/m68hc11-elf/lib/mshort/fshort-double/mlong-calls/libbcc.a
usr/m68hc11-elf/lib/mshort/fshort-double/mlong-calls/libm.a
usr/m68hc11-elf/lib/mshort/fshort-double/mlong-calls/libnosys.a
usr/m68hc11-elf/lib/mshort/fshort-double/mlong-calls/sim-valid.ld
usr/m68hc11-elf/lib/mshort/fshort-double/sim-valid.ld
usr/m68hc11-elf/lib/mshort/libbcc.a
usr/m68hc11-elf/lib/mshort/libm.a
usr/m68hc11-elf/lib/mshort/libnosys.a
usr/m68hc11-elf/lib/mshort/mlong-calls/crt0.o
usr/m68hc11-elf/lib/mshort/mlong-calls/libbcc.a
usr/m68hc11-elf/lib/mshort/mlong-calls/libm.a
usr/m68hc11-elf/lib/mshort/mlong-calls/libnosys.a
usr/m68hc11-elf/lib/mshort/mlong-calls/sim-valid.ld
usr/m68hc11-elf/lib/mshort/sim-valid.ld
usr/m68hc11-elf/lib/sim-valid.ld
usr/man/
usr/man/man1/
usr/man/man1/cpp.1
usr/man/man1/gcov.1
usr/man/man1/m68hc11-elf-gcc.1
usr/man/man7/
usr/man/man7/fsf-funding.7
usr/man/man7/gfdl.7
usr/man/man7/gpl.7
usr/share/
usr/share/info/
usr/share/info/as.info
usr/share/info/bfd.info
usr/share/info/binutils.info
usr/share/info/configure.info
usr/share/info/dir
usr/share/info/gprof.info
usr/share/info/ld.info
usr/share/info/standards.info
usr/share/locale/
usr/share/locale/be/
usr/share/locale/be/LC_MESSAGES/
usr/share/locale/be/LC_MESSAGES/gcc.mo
usr/share/locale/bg/
usr/share/locale/bg/LC_MESSAGES/
usr/share/locale/bg/LC_MESSAGES/binutils.mo
usr/share/locale/bg/LC_MESSAGES/gprof.mo
usr/share/locale/bg/LC_MESSAGES/ld.mo
usr/share/locale/ca/
usr/share/locale/ca/LC_MESSAGES/
usr/share/locale/ca/LC_MESSAGES/gcc.mo
usr/share/locale/da/
usr/share/locale/da/LC_MESSAGES/
usr/share/locale/da/LC_MESSAGES/bfd.mo
usr/share/locale/da/LC_MESSAGES/binutils.mo
usr/share/locale/da/LC_MESSAGES/gcc.mo
usr/share/locale/da/LC_MESSAGES/gprof.mo
usr/share/locale/da/LC_MESSAGES/ld.mo
usr/share/locale/da/LC_MESSAGES/opcodes.mo
usr/share/locale/de/
usr/share/locale/de/LC_MESSAGES/
usr/share/locale/de/LC_MESSAGES/gcc.mo
usr/share/locale/de/LC_MESSAGES/gprof.mo
usr/share/locale/de/LC_MESSAGES/opcodes.mo
usr/share/locale/el/
usr/share/locale/el/LC_MESSAGES/
usr/share/locale/el/LC_MESSAGES/gcc.mo
usr/share/locale/eo/
usr/share/locale/eo/LC_MESSAGES/
usr/share/locale/eo/LC_MESSAGES/gprof.mo
usr/share/locale/es/
usr/share/locale/es/LC_MESSAGES/
usr/share/locale/es/LC_MESSAGES/bfd.mo
usr/share/locale/es/LC_MESSAGES/binutils.mo
usr/share/locale/es/LC_MESSAGES/gas.mo
usr/share/locale/es/LC_MESSAGES/gcc.mo
usr/share/locale/es/LC_MESSAGES/gprof.mo
usr/share/locale/es/LC_MESSAGES/ld.mo
usr/share/locale/es/LC_MESSAGES/opcodes.mo
usr/share/locale/fi/
usr/share/locale/fi/LC_MESSAGES/
usr/share/locale/fi/LC_MESSAGES/bfd.mo
usr/share/locale/fi/LC_MESSAGES/binutils.mo
usr/share/locale/fi/LC_MESSAGES/gas.mo
usr/share/locale/fi/LC_MESSAGES/gprof.mo
usr/share/locale/fi/LC_MESSAGES/ld.mo
usr/share/locale/fi/LC_MESSAGES/opcodes.mo
usr/share/locale/fr/
usr/share/locale/fr/LC_MESSAGES/
usr/share/locale/fr/LC_MESSAGES/bfd.mo
usr/share/locale/fr/LC_MESSAGES/binutils.mo
usr/share/locale/fr/LC_MESSAGES/gas.mo
usr/share/locale/fr/LC_MESSAGES/gcc.mo
usr/share/locale/fr/LC_MESSAGES/gprof.mo
usr/share/locale/fr/LC_MESSAGES/ld.mo
usr/share/locale/fr/LC_MESSAGES/opcodes.mo
usr/share/locale/ga/
usr/share/locale/ga/LC_MESSAGES/
usr/share/locale/ga/LC_MESSAGES/gprof.mo
usr/share/locale/ga/LC_MESSAGES/ld.mo
usr/share/locale/ga/LC_MESSAGES/opcodes.mo
usr/share/locale/id/
usr/share/locale/id/LC_MESSAGES/
usr/share/locale/id/LC_MESSAGES/bfd.mo
usr/share/locale/id/LC_MESSAGES/binutils.mo
usr/share/locale/id/LC_MESSAGES/gas.mo
usr/share/locale/id/LC_MESSAGES/gprof.mo
usr/share/locale/id/LC_MESSAGES/ld.mo
usr/share/locale/id/LC_MESSAGES/opcodes.mo
usr/share/locale/it/
usr/share/locale/it/LC_MESSAGES/
usr/share/locale/it/LC_MESSAGES/binutils.mo
usr/share/locale/it/LC_MESSAGES/gprof.mo
usr/share/locale/it/LC_MESSAGES/ld.mo
usr/share/locale/it/LC_MESSAGES/opcodes.mo
usr/share/locale/ja/
usr/share/locale/ja/LC_MESSAGES/
usr/share/locale/ja/LC_MESSAGES/bfd.mo
usr/share/locale/ja/LC_MESSAGES/binutils.mo
usr/share/locale/ja/LC_MESSAGES/gas.mo
usr/share/locale/ja/LC_MESSAGES/gcc.mo
usr/share/locale/ja/LC_MESSAGES/gprof.mo
usr/share/locale/ja/LC_MESSAGES/ld.mo
usr/share/locale/ms/
usr/share/locale/ms/LC_MESSAGES/
usr/share/locale/ms/LC_MESSAGES/gprof.mo
usr/share/locale/nl/
usr/share/locale/nl/LC_MESSAGES/
usr/share/locale/nl/LC_MESSAGES/gcc.mo
usr/share/locale/nl/LC_MESSAGES/gprof.mo
usr/share/locale/nl/LC_MESSAGES/opcodes.mo
usr/share/locale/pt_BR/
usr/share/locale/pt_BR/LC_MESSAGES/
usr/share/locale/pt_BR/LC_MESSAGES/gprof.mo
usr/share/locale/pt_BR/LC_MESSAGES/opcodes.mo
usr/share/locale/ro/
usr/share/locale/ro/LC_MESSAGES/
usr/share/locale/ro/LC_MESSAGES/bfd.mo
usr/share/locale/ro/LC_MESSAGES/binutils.mo
usr/share/locale/ro/LC_MESSAGES/gprof.mo
usr/share/locale/ro/LC_MESSAGES/opcodes.mo
usr/share/locale/ru/
usr/share/locale/ru/LC_MESSAGES/
usr/share/locale/ru/LC_MESSAGES/bfd.mo
usr/share/locale/ru/LC_MESSAGES/binutils.mo
usr/share/locale/ru/LC_MESSAGES/gas.mo
usr/share/locale/ru/LC_MESSAGES/gprof.mo
usr/share/locale/rw/
usr/share/locale/rw/LC_MESSAGES/
usr/share/locale/rw/LC_MESSAGES/bfd.mo
usr/share/locale/rw/LC_MESSAGES/binutils.mo
usr/share/locale/rw/LC_MESSAGES/gas.mo
usr/share/locale/rw/LC_MESSAGES/gcc.mo
usr/share/locale/rw/LC_MESSAGES/gprof.mo
usr/share/locale/sk/
usr/share/locale/sk/LC_MESSAGES/
usr/share/locale/sk/LC_MESSAGES/binutils.mo
usr/share/locale/sr/
usr/share/locale/sr/LC_MESSAGES/
usr/share/locale/sr/LC_MESSAGES/gprof.mo
usr/share/locale/sv/
usr/share/locale/sv/LC_MESSAGES/
usr/share/locale/sv/LC_MESSAGES/bfd.mo
usr/share/locale/sv/LC_MESSAGES/binutils.mo
usr/share/locale/sv/LC_MESSAGES/gcc.mo
usr/share/locale/sv/LC_MESSAGES/gprof.mo
usr/share/locale/sv/LC_MESSAGES/ld.mo
usr/share/locale/sv/LC_MESSAGES/opcodes.mo
usr/share/locale/tr/
usr/share/locale/tr/LC_MESSAGES/
usr/share/locale/tr/LC_MESSAGES/bfd.mo
usr/share/locale/tr/LC_MESSAGES/binutils.mo
usr/share/locale/tr/LC_MESSAGES/gas.mo
usr/share/locale/tr/LC_MESSAGES/gcc.mo
usr/share/locale/tr/LC_MESSAGES/gprof.mo
usr/share/locale/tr/LC_MESSAGES/ld.mo
usr/share/locale/tr/LC_MESSAGES/opcodes.mo
usr/share/locale/uk/
usr/share/locale/uk/LC_MESSAGES/
usr/share/locale/uk/LC_MESSAGES/bfd.mo
usr/share/locale/uk/LC_MESSAGES/binutils.mo
usr/share/locale/uk/LC_MESSAGES/gprof.mo
usr/share/locale/uk/LC_MESSAGES/ld.mo
usr/share/locale/uk/LC_MESSAGES/opcodes.mo
usr/share/locale/vi/
usr/share/locale/vi/LC_MESSAGES/
usr/share/locale/vi/LC_MESSAGES/bfd.mo
usr/share/locale/vi/LC_MESSAGES/binutils.mo
usr/share/locale/vi/LC_MESSAGES/gprof.mo
usr/share/locale/vi/LC_MESSAGES/ld.mo
usr/share/locale/vi/LC_MESSAGES/opcodes.mo
usr/share/locale/zh_CN/
usr/share/locale/zh_CN/LC_MESSAGES/
usr/share/locale/zh_CN/LC_MESSAGES/bfd.mo
usr/share/locale/zh_CN/LC_MESSAGES/binutils.mo
usr/share/locale/zh_CN/LC_MESSAGES/ld.mo
usr/share/locale/zh_CN/LC_MESSAGES/opcodes.mo
usr/share/locale/zh_TW/
usr/share/locale/zh_TW/LC_MESSAGES/
usr/share/locale/zh_TW/LC_MESSAGES/binutils.mo
usr/share/locale/zh_TW/LC_MESSAGES/ld.mo
usr/share/man/
usr/share/man/man1/
usr/share/man/man1/m68hc11-elf-addr2line.1
usr/share/man/man1/m68hc11-elf-ar.1
usr/share/man/man1/m68hc11-elf-as.1
usr/share/man/man1/m68hc11-elf-c++filt.1
usr/share/man/man1/m68hc11-elf-dlltool.1
usr/share/man/man1/m68hc11-elf-elfedit.1
usr/share/man/man1/m68hc11-elf-gprof.1
usr/share/man/man1/m68hc11-elf-ld.1
usr/share/man/man1/m68hc11-elf-nlmconv.1
usr/share/man/man1/m68hc11-elf-nm.1
usr/share/man/man1/m68hc11-elf-objcopy.1
usr/share/man/man1/m68hc11-elf-objdump.1
usr/share/man/man1/m68hc11-elf-ranlib.1
usr/share/man/man1/m68hc11-elf-readelf.1
usr/share/man/man1/m68hc11-elf-size.1
usr/share/man/man1/m68hc11-elf-strings.1
usr/share/man/man1/m68hc11-elf-strip.1
usr/share/man/man1/m68hc11-elf-windmc.1
usr/share/man/man1/m68hc11-elf-windres.1
Code: Select all
$ make ms2
make[1]: Entering directory '/cygdrive/c/ms2extra_pre3.3rc1/ms2extra'
/cygdrive/c/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m68hcs12 -mshort -msoft-reg-count=5 -mauto-incdec -fsigned-char -c ms2_extra_main.c
make[1]: Leaving directory '/cygdrive/c/ms2extra_pre3.3rc1/ms2extra'
Caporiacco.
Adding "C:\usr\bin" to your Windows path is not the same as adding "/usr/bin" to cygwin. It is also not the same directory. You need to add the correct path to your cygwin setup.
Also, in the example you posted, you weren't in / when you were able to get tar xvf to work. There's still a permissions problem there.
In this post they talk about changing the make file?
https://gcc.gnu.org/ml/gcc-help/2000-10/msg00078.html
If I change in the make file: ''/usr/bin'' for ''C:/usr/bin'' ,
like:
I get this error:
What is a normal message after command ''make'' in Cygwin?
Regards,
Caporiacco
like:
Code: Select all
BINDIR:=$(shell ls c:/usr/bin/m68hc11-elf-gcc c:/usr/bin/m68hc11-elf-gcc `which m68hc11-elf-gcc` | head -1 | sed -e's,m68hc11-elf-gcc,,g' 2> /dev/null)
Code: Select all
$ make
/cygdrive/c/usr/bin/m68hc11-elf-gcc -g -Wall -Werror -Wsign-compare -Wshadow -O -fomit-frame-pointer -m68hcs12 -mshort -msoft-reg-count=5 -mauto-incdec -fsigned -char -c ms2_extra_main.c
Regards,
Caporiacco
After many different test without success, on Windows 64bits and Mac with Windows 32bits by bootcamp.
I succeed on Windows 32 bits on my old PentiumIII, doing exctally what is on Jame's attached README.
Thanks to James and Jean,
Regards,
Caporiacco.
Regards,
Caporiacco.
