Feature request: Dual MAFS
winstonusmc
Post by winstonusmc »
I have an RB26 with dual MAFS. I know how the stock ECU simply adds the two together. I see the advantages to two MAFS on other applications that involve twin turbo. One turbo is always a little less efficient than the other. In my application the front is the efficient one due to the shorter piping. Is this doable?
Nissan Skyline R34 RB26DETT ran MS3/MS3X w/ factory Hitachi CAS (sold)
Nissan Silvia S14 RB25DE ITB/NA ran MS3/MS3X w/ factory Mitsubishi CAS (disassembled)
Datsun 240z RB25DE ITB/NA with MS3/MS3X
Mitch318i
Re: Feature request: Dual MAFS
Post by Mitch318i »
May I suggest that even if we cannot have 2 frequency type MAF inputs, if it is possible to impliment the Voltage type?
As covered above, for twin turbo applications, this would be great.
If not, to answer the guy above, It is possible to impliment a small microcontroller to add the signals (either voltage or frequency) together, then convert to one 0-5V signal, This was going to be my solution if they couldn't be added.
.Mitch
...Mitch
Turbo'd Bmw M10 engine, 18psi, stock internals.
Using V3 board, with Ms1, HR code.
4 LS-1 Coils, 36-1 VR setup, and 4G15 (optical) Cas Retrofit for 2nd Trigger.
jacky4566
Post by jacky4566 »
Bumping this very old thread. Also interested in this feature.
Additionally. in the meantime, It would be advised to take the higher voltage of the 2 mafs. That way one bank is always rich instead of lean should one maf read too low AND you have redundancy should one fail. Easy enough to implement with Schottky diodes.
Spiffy
Post by Spiffy »
Selin dual maf translator?
AbatelliCristian
Post by AbatelliCristian »
Dual MAFS for RB26 is good idea. with ITB is not simply tuner the engine in Speed density.. Is necessary dualtable.
News for dual MAF? is possible?
Reverant
Post by Reverant »
What problem exactly are you having on the RB?
The man behind MS Labs
AbatelliCristian
I worked a short time, but I noticed that the TPS % is very important for AFR. If I have 0,2 boost - 30%tps, or 0,2 boost - 100%TPS, the afr is very different. In the coming weeks, I'll be working and I think I will use dual table.
dual MAFS is good solution
Reverant
Post by Reverant »
AbatelliCristian wrote:I worked a short time, but I noticed that the TPS % is very important for AFR. If I have 0,2 boost - 30%tps, or 0,2 boost - 100%TPS, the afr is very different. In the coming weeks, I'll be working and I think I will use dual table.
The reason I asked because I have sort of the same problem on an R34 with RB30 engine, which can easily achieve 0.6bar-0.7bar at part throttle cruising/slow accelerating on a 70mm turbo. Our solution was to use dual tables and blend based on TPS.
jacky4566
Post by jacky4566 »
The RB26 MAFS are voltage based right? Why not use my suggested solution above?
Reverant
Post by Reverant »
Our application does not use MAFs, only MAP and a single turbo.
AbatelliCristian
I will check because I don't know.
I think I will use dualtable. Ve1 speeddensity and Ve2 alphan.
You use standard CAS with 360 trigger?
AbatelliCristian
RB26 MAF is voltage
