here is a log showing the exact same thing
you can see in the start knockin stays at 18.9
after restart everything is normal.
Keithg wrote:Does the per cylinder knock work only with this module or with other modules? I have the Saab unit my car came with and get a pull to ground when knock is sensed. Will this also give per cylinder information?
Keith
Reverant wrote:I think that would require that the input pin is an interrupt source.
Zaphod wrote: are they working so flawless that there is nothing to write about?
