Knock module for MS3 (beta test)
Re: Knock module for MS3 (beta test)
Post by Matt Cramer »
OliverH wrote:How about knock and EGT control? I just bought an EGT+ CAN board from jbperf. If knock retards the ignition EGT will rise and more advance/ more fuel will be good to control EGT. How will they both (knock/ EGT) interact?
The knock sensor does not currently interact with the fueling, but the EGT Safety feature can add additional fuel if the EGT temperatures rise too much.
Is it possible that knock control will also use "over fueling" to get control of knock?
Current knock code only adjusts spark timing.
Is a wide band knock sensor capable to detect knock in all rpm ranges?
That depends on whether the background noise gets to be too loud and interferes too much.
And what about knock contol on boost?
Is no different than knock control at lower kPa levels.
OliverH
Post by OliverH »
OK. I've to place an order in the next days. Should be the last big part missing in my MS setup/ build (a lot small parts following :o )
MS V3.00 DIY, MS3, MS3X, JimStim & StimX.
HOODEY
Post by HOODEY »
Good Job cortina I see you are using the ms to do the hard work. Good idea. Some day we will get to perform a
side by side comparison. The performance should be similar given we are using the same chip.
:shock:
Post by jsmcortina »
