MS3 pre-1.1 alpha 18 released
Re: MS3 pre-1.1 alpha 18 released
@ elaw
Thanks for the info. As it turns out, my idle map was not as good as it could be and EGO was having to do a bit more. Specifically, I adjusted the Kpa so that values where not getting interpolated into bins off idle. I turned EGO off and tuned the MAP at full temp in and around the IDLE regions. I also moved the idle region more toward the center if the IDLE VE table. After 2 days. I can say that I am all smiles. This is coming from someone who can be a bit picky and have been known to split hairs
Low Idle on non-sequential with large injectors is certainly asking a lot, but MS3 extra proved up to the challenge. ...to think I was satisfied for years with the idle on MS1 extra HR
One day, I may actually hook up the IAC/ISV
Thanks all
Thanks all
'90 Corrado G60 on MSns -e -> MS3 - '62 Harley Panhead
Supercharged 2L-20v Project Build -> https://forums.vwvortex.com/showthread.php?2805002
Making 02m 6speed Conversion Mounts for VW MKII and MKIII -> http://www.generalprinciple.com/02m
Duty cycle greater than about 85% is a problem. Greater than 100% isn't happening. 100% means the injector is open continuously. >100% means it is open MORE than continuously.
i just updated my ms III with alpha 18... it seems, that it is working just fine, also closed loop pwm idle is working now... on the 1.0.5 versioncouldn't make it work.... also have a question about temperature adjustments for lpg... is it computed for pw or reqfuel, does the pw gauge includes temperature adjustments??
I have problems with cranking. For some reason engine is hardly starting up. Sometimes (specially with hot engine and low battery voltage) it doesn't start up at all. 1.0.5 Works fine with same settings?
Ps. New loader doesn't work at all with my laptop
Opel Kadett C City 2.0 16V Turbo
Did you attach an MSQ and datalog ?teg wrote:I have problems with cranking. For some reason engine is hardly starting up. Sometimes (specially with hot engine and low battery voltage) it doesn't start up at all. 1.0.5 Works fine with same settings?
We need a lot more detail than that!Ps. New loader doesn't work at all with my laptop
Yep ;)jsmcortina wrote: Did you attach an MSQ and datalog ?
Sorry about that.. Here is more detail:We need a lot more detail than that!
Code: Select all
MegaSquirt-3 Firmware Loader 3.12 2012-01-23
Remove the fuse powering your ignition coils.
(Spark outputs may be undefined until you re-load your settings.)
Press enter to continue...
Ensure that your Megasquirt/Microsquirt/ECU is
-connected to your computer
-has fused 12V power connected.
Ensure that no tuning software is running.
Be sure to Quit the software, not just minimise it..
Debug message Level:
1: Normal
2: More detail
3: + serial comms
4: + the s19 file as parsed
Selection (default: 1): 2
Do you want to scan your serial ports automatically? (y/n default y)n
Serial device:
Enter a comm port number (default 1): 7
Scanning serial device: com7 ..#Opening comm port com7
Do you want to use com7 (y/n default = y)y
Found firmware files : ms3.s19
File to upload (default= ms3.s19):
Unable to open com7
Are you sure COM7 exists and is free?teg wrote:Sorry about that.. Here is more detail:jsmcortina wrote: (re loader) We need a lot more detail than that!
What happens if you allow it to scan with debug level 2?
When I'm not using scan feature of downloader, result is this:
When it scanned serial ports, it seems to be working. Thus I cancelled download before it started to flash:
Code: Select all
1: Normal
2: More detail
3: + serial comms
Serial device:
Unable to open com7
#Closing comm port
Scanning serial device: COM0 ..#Opening comm port COM0
couldn't open port
COM0 : MS3 detected
#Closing comm port
Do you want to use COM0 (y/n default = y)
Unable to open COM0
#Closing comm port
couldn't open port
COM0 : MS3 detected
#Closing comm port
Do you want to use COM0 (y/n default = y)n
Ignoring scan results and allowing user entry.
Serial device:
couldn't open port
WARNING!!!
No valid ports or ECUs found. Cannot load firmware without communications.
Common problems:
- Something is hogging the serial port.
e.g. TunerStudio, modem or mobile phone cable software.
Be sure to close/exit those applications.
- USB-serial cable on high COM port number, use Device Manager to re-assign
it to say COM1.
- ECU not powered up, be sure there is fused power applied. Use a mains
adapter or vehicle battery. PP9 batteries are too feeble.
- Serial cable not connected correctly
- Software driver problems
Check the above. Do you want to try probing again? (y/n default = y)
Code: Select all
1: Normal
2: More detail
3: + serial comms
couldn't open port
COM0 : #Closing comm port
Scanning serial device: COM1 ..#Opening comm port COM1
..Garbled reply..
COM1 : #Closing comm port
Scanning serial device: COM2 ..#Opening comm port COM2
couldn't open port
COM2 : #Closing comm port
Scanning serial device: COM3 ..#Opening comm port COM3
couldn't open port
COM3 : #Closing comm port
Scanning serial device: COM4 ..#Opening comm port COM4
COM4 : #Closing comm port
Scanning serial device: COM5 ..#Opening comm port COM5
..Garbled reply..
COM5 : #Closing comm port
Scanning serial device: COM6 ..#Opening comm port COM6
..Garbled reply..
COM6 : #Closing comm port
Scanning serial device: COM7 ..#Opening comm port COM7
COM7 : MS3 detected
#Closing comm port
Do you want to use COM7 (y/n default = y)
Fetching format
Checking serial format
No reply, assuming old style serial.
#Closing comm port
Preserve sensor calibrations,
and I/O pin states (y/n, default: y)?
That makes more sense. Looks to be a bug in the non-scan mode there. I think I always tested using "scan"teg wrote:When I'm not using scan feature of downloader, result is this:
with which version o megalogwiev i shuold open log from msIII with this code?? i can't open logs, that i made today.
Try 3.05 version, there was an error with the logs having a "mark" for the first line making on a few of the traces show up. Haven't seen that issue with this release.
later wd
later wd
I ran into the same issue. Below is a post from the prev page. In bold is what I had to do to correct this.teg wrote:I have problems with cranking. For some reason engine is hardly starting up. Sometimes (specially with hot engine and low battery voltage) it doesn't start up at all. 1.0.5 Works fine with same settings?
sdezego wrote:Upgraded from something like 1.04.
Other than small tweaks, One thing I had to revisit was Cranking/Priming PW. Would not immediate hot restart (turn off running engine and restart immediately) w/o giving pedal. I am not running any IAC (never have), etc so that may be why it is magnified on my setup, but I had to change the cranking PW at the high CLT range to essentially the ~idle PW.
Not sure if something changed along the way that would affect this or if I should look at some other aspect, but thought I would mention....
I tried to tune cranking pw up and down. It didn't help significantly.
hello,
i've loaded alpha 18 in my ecu...
now can i return back to stock settings? and how?
thanks
thanks
The stock settings are built into the firmware.
But why not load the current development firmware (beta 20) ?
because i think engine may not starts because of this alpha versions and wanna try configuring on stock firmware... not alpha versionsjsmcortina wrote:The stock settings are built into the firmware.
i dont think that it's real problem, but...
Go ahead and load the stock firmware then?
i cant find the guide how to load stock firmware that't why i'm herejsmcortina wrote:Go ahead and load the stock firmware then?
some hint please?
It is in the manual called "loading firmware to MS3" in the MS3 section.
http://www.msextra.com/doc/ms3/firmware.html
You will likely need to use the boot jumper to move back to the release code.
(If that's a pain, try installing 1.0.6 beta first, then installing 1.0.5)
