Page 3 of 3
Re: MS3 pre-1.1 beta 20 released
Posted: Mon Apr 23, 2012 12:38 pm
by MG four six eight
Are the extended (X2) injector trim tables still in the 1.1 beta releases? If I remember correctly, it seems like it was added in around beta 10, however searching through the change log I no longer see it listed?
I would like to change back to the 1.1 beta codes (for the extended trim range) from 1.0.6 once the new beta code is released for the WUE/ASE bug fix.
Bill
Edit: I just looked through the ini files for beta 20 and noticed that trim values are at 25.4!
Posted: Tue Apr 24, 2012 8:27 am
by y8s
I've noticed using I think this beta and the test code you gave me for the AE fix that my idle-up adders are not adding what I have in the settings.
example: cranking idle duty this morning. CLT temp was 15°C. nearest points for cranking duty are 50.4% at 60C and 53.9% at 0C. actual cranking duty was 72.7%
I'm using voltage compensation. at 9.9V when cranking it's at 10% duty adder. Total settings were around maybe 63%--a full 10% below what the valve was sitting at.
edit/update:
it's fine during cranking, but as soon as the rpm exceeds the cranking limit, 10% comes from somewhere unknown. I'm not using the initial value table.
Posted: Tue Apr 24, 2012 9:44 am
by SvenCS
The PID closed loop idle dashpot adder may contribute some. Although, 10% sounds high for this alone.
Posted: Tue Apr 24, 2012 9:55 am
by y8s
my fan and dashpot only add another 6-7% at most.
Posted: Tue Apr 24, 2012 11:34 am
by muythaibxr
Nothing has changed in that area, so not sure what you're seeing.
Posted: Tue Apr 24, 2012 6:19 pm
by y8s
I haven't been using voltage duty compensation very long.
I did two back-to-back startups this evening with it zeroed and with it enabled (linear 10V, 10% to 16V, -3%).
conditions were more or less equal.
with it zeroed, PWM frequency sits at a constant value from key on, through cranking, and until the post cranking timeout ends.
With the linear curve, it sits at about the same constant value with key on but then jumps up 10% during cranking. the duty only comes up when the engine starts turning (not when the voltage drops--which happens earlier). after exceeding the max cranking speed, duty jumps up another 10% before tapering down to normal PID levels.
So I'm wondering--is the voltage correction being added for cranking and then AGAIN to the current duty? It sure seems that way. That's the only change above. If one of the 10% increases was caused by something else, it would appear in both graphs.
Matt
Posted: Wed Apr 25, 2012 7:04 am
by y8s
Another thing I noticed while pouring over my latest logs...
tps Accel and map Accel (I thought) were supposed to display the currently added AE % from each category as set in the throttle pump AE graphs.
for example if I set 100 %/second TPSdot to add 10% and move the throttle at 100 %/second I should see "10" in tps Accel. Is this correct? (assume 100% tps based enrichment)
I'm actually seeing logged tps Accel numbers larger than have been set at various points in the curve which confuses me because I can't take those back to the curves and reduce them accordingly. In the above example, the log might show "15" for tps Accel. In some cases it's also undershooting. ie 300 %/sec set for 23 might show up as 18. It doesn't happen every time but as I was going through logs I was noticing this. And I am using 80% tps-map blend so I would expect to see values 80% of what I have in the curve, right?
Log and MSQ
http://y8spec.com/megasquirt/pre1.1preb ... .43.28.msq
http://y8spec.com/megasquirt/pre1.1preb ... .17.25.msl
Posted: Wed Apr 25, 2012 8:34 am
by muythaibxr
Are you logging with the SDCard? If not, what's logged might not line up with what actually happens during transients.
Posted: Wed Apr 25, 2012 8:35 am
by muythaibxr
y8s wrote: So I'm wondering--is the voltage correction being added for cranking and then AGAIN to the current duty? It sure seems that way. That's the only change above. If one of the 10% increases was caused by something else, it would appear in both graphs.
I'll take a look at this and see if that's what's happening.
Posted: Wed Apr 25, 2012 9:52 am
by y8s
muythaibxr wrote:Are you logging with the SDCard? If not, what's logged might not line up with what actually happens during transients.
computer logs. is the delay between tpsdot changes and tps accel calcs that significant? not criticizing, just curious.
Posted: Thu Apr 26, 2012 11:36 am
by braineack
I'm pretty happy with prebeta21 right now.
I noticed the idle pwm voltage correction at cranking like y8s noted, but i didn't notice the "double-dip", only that I needed to dial it back a bit, and reduce the cranking table a little. I had the voltage curve too aggresive at first, as I drop to 9v during cranking. Seems to be fine after a bit of tuning and lowering the cranking duty a bit.
The accel-pump is amazing. I'm currently struggling with an odd grounding issue where my enrichments had to be completely retuned and my tpsDOT was very noisy and required a high threshold. Coming from alpha11, the filtering improvements coupled with the accel-pump have results in the best throttle response and smoothness to date. (consider that I've been on MsI starting in 2006, then MS2, and now MS3).
The idle improvements (intial duty, timing and voltage correction) have improved the idle quality significantly, better than the stock ECU was ever able to.
Here's the results of my idle after about 10-20 minutes of fooling around, going straight off my alpha 11 map.
http://www.youtube.com/watch?v=aeSrl9EockA
Posted: Sat Apr 28, 2012 9:44 am
by ragepower
Last week load the beta 20 firmware. The engine seams to run better.
I notice a non-important "bug". The fuel economy l/km isn't working, i have the speed information on MS. Is anything more needed?
Another question in the accel enrichment. I noticed that i had this disable threshold to high, and started to play (trying to tune) with it. With the standard AE seams to a little confuse, so I tried the new accel pump feature and it seams more easy to tune. The accel enrich gauge doesn't move but is noticeable the enrichment, is normal?
And i didn't find this field in the datalog (done using computer), maybe i didn't search enough.
Now im testing CL idle initial values and it seams to work very well.
Posted: Sat Apr 28, 2012 9:47 am
by 93white3400z
ragepower wrote:I notice a non-important "bug". The fuel economy l/km isn't working, i have the speed information on MS. Is anything more needed?
In "Engine and sequential settings", make sure you have the "engine size" and "injector size each" filled up properly.
Posted: Sun Apr 29, 2012 8:39 am
by ragepower
I did notice that settings but didn't know what was they for. Thanks
Posted: Sun May 20, 2012 4:06 am
by kubeq_sq
hello, i am using beta 20 release and latly my engine started not smooth idle... i checked, ans in composite logger there is no trace of cam signal... everything is configured for seqential fuel and spark, but engine runs... i tried to disconnect the cam sensor and it made no diffrence... on earlier code versions everytnig was ok. i place here a composite log file.
what should i do?
