I don't know what you mean by fixed , but to be clear every solenoid has 2 pin : one is 15+ 12v from a relay and the other go to the vanos ecu (i think 99% its pwm grounding ,not full sure) unlike the s54 and the s50b32 it has 3 pin for every 2 solenoids , one pin is grounding to the block and the other 2 is from the ecuAbatelliCristian wrote:are you sure do you have 12v fixed and ground pwm?
notice that this engine is EURO s50b30 has 2 ecu : one for vanos control and the other for engine, this system called DME 3.3 and its Continuously adjust ,not on/off
in this case, can we use 2 medium or high current outputs to adjust them depending on the load??
anyway if anyone has experience with this system, using the last 1.2.4 frimware, i will be appreciate
thanx
