S54 dual VANOS VVT
AbatelliCristian
Re: S54 dual VANOS VVT
Post by AbatelliCristian »
Ok, I understand, you use MS3PRO.
Question,
MS3PRO have highside circuit? if yes, you are sure the out is correct?
exhaust vvt1 open solenoid charge oil
exhaust vvt3 open solenoid discharge oil
Intake vvt2 open solenoid charge oil
Intake vvt4 open solenoid discharge oil
Post by jsmcortina »
MS3-Pro doesn't have high-side drivers. An external adapter is required.
I already changed the user-interface.
ragepower
Post by ragepower »
jsmcortina wrote:Does the cam _really_ move that much? On all other systems I've seen, there is enough leeway in the signal that the phase can still be identified whether the cam is in the full advance or full retard position.
However, the suggestion to discharge the hydraulics makes good sense also. Do you still have access to the test car? I'm guessing that the customer has taken it away by now.
About this I can give you information about how OEM ecu control
Check the last 10sec. The upper line is the charge valve, and the botton is the discharge.
https://www.youtube.com/watch?v=lZ-XaPr ... e=youtu.be
Mario
Post by Mario »
AbatelliCristian wrote:Ok, I understand, you use MS3PRO.
Question,
Yes, the diodes have been switched so we can control with the negative outputs.
1967 Beetle My test mule
The Dub Shop
Facebook
Megasquirt for life!
AbatelliCristian
ok, do you have tested the output in vvt test mode?
To simplify the test, you can disabled vvt and enabled generic output and make test in order to understand if the outputs work well and to understand the order of the output
Mario
Post by Mario »
AbatelliCristian wrote:ok, do you have tested the output in vvt test mode?
I will reverse the cam inputs and do the generic PWM testing to verify proper operation then move onto the VVT menu again.
Cheers!
The Dub Shop
Facebook
Mario
Post by Mario »
Still can't get this stuff to work. I loaded alpha 9 today and it seems that vvt3 and vvt4 duty do not output.
Also without VT enabled, I don't have a Cam Fault indicator. With VVT It lights right up. I'll post some data as soon as the files get transferred from the laptop.
The factory hall sensors have inverted signals as well, could this be causing an issue since "falling edge" is greyed out in the CAM1 dialog and I cannot chance it?
The Dub Shop
Facebook
You can change it... there's a new-ish setting that allows you to "flip cam polarity."
Mario
Post by Mario »
Here is my my scope traces,
Top - Exhaust Cam - Main Cam
Middle - Crank
Bottom - Intake Cam
The Dub Shop
Facebook
ragepower
Post by ragepower »
Do you have all OK with the exhaust cam? That signal don't seams to be a hall sensor.
Mario
Post by Mario »
James, is the code S54 code intended for 8-1 on the Cam? If I set it for 7 teeth the exhaust EGT angle goes haywire, if I set for 8 it stays steady but non very controllable, it will stay static until I change the target extreme to one end or the other.
Cam Fault with VVT.msq
Running cam fault vvt no 3 or 4 outputs _modified.msl
Is the red reference line that goes from top to bottom in the engine log a sync error?
running vtt cam fault no 3 and 4 movmnet.csv
The Dub Shop
Facebook
AbatelliCristian
The code is for 8-1. Insert 8 tooth in the setting.
I see your msq. Decrese frequency solenoid. Use 20hz.
Mario
Post by Mario »
AbatelliCristian wrote:The code is for 8-1. Insert 8 tooth in the setting.
When it was on 20hz, I couldn't get any changes to happen. I incresed it back to 200hz and the intake cam hit target right after startup. :cry:
The Dub Shop
Facebook
AbatelliCristian
You have tried to reduce P I ?
can you make composite log?
Mario
Post by Mario »
I will try to get a composite log in the next day. I need to return to his shop.
I did change the numbers slightly but with the other issues I was just running in circles.
But I don't know why Duty 3 and 4 have no movement, only 1 and 2.
Are you using Alpha 1.4.9 on your engine now?
The Dub Shop
Facebook
AbatelliCristian
I noticed that vvt3 and vvt4 is 0.
But I saw that VANOS intake reaches target. I thought it was an error log.
I was with previous versions because the customer has withdrawn the machine.
I will update it at the first opportunity
AbatelliCristian
The signal in the exaust sensor is the signal is abnormal.
which circuit uses ms3pro for it? and is equal circuit of the intake?
Mario
Post by Mario »
AbatelliCristian wrote:The signal in the exaust sensor is the signal is abnormal.
Yes, I think I had the probe in the CMP- instead of CMP+. I need to revisit that as well.
jsmcortina wrote:You can change it... there's a new-ish setting that allows you to "flip cam polarity."
The greyed out feature?
The Dub Shop
Facebook
Mario
Post by Mario »
Abatelli did you have all VR sensors? Or Crank VR with hall sensors on the cams?
The Dub Shop
Facebook
Mario wrote:The greyed out feature?
You don't need it here with "Toothed wheel"... just change the second trigger polarity.
