MS3 1.3 ChangeLog
MS3 1.3 ChangeLog
(Some of the early changes were applied to 1.2 also)
2012-12-22 JSM
Timed open-loop boost fix.
Fix knock (version checking logic error)
2012-12-23 JSM
Comms failure with internal knock module sets CEL
Only check battery after 5 seconds of runtime
In accelpump mode, still calc outpc.tpsaccel for user interface.
Add PPAGE F2 and re-arrange functions to use it.
2012-12-28 JSM
Fix overflow in flex% calc
Fix sensor16 on MS3.
Support ECU temp sensor in MS3pro.
2012-12-30 JSM
Improve dutycycle calcs in ini
Idle VE naming in ini
Remove non-functioning "green dots" from some curves. (DF + Tract.)
2013-01-13 JSM
Various ini tweaks.
Allow testmode via CAN.
CAN tweaks.
Serial side of 'f' and 'h'
Get serial+CAN 'f' working.
2013-01-15 JSM
Calibration tables now use 'w'. TS 2.1.13+ REQUIRED
Remove 't' command.
Revised MSG_PROT to allow long or short format
2013-01-16 JSM
Automatically scan CAN network for protocols.
memset outpc.
Add internal MSG_REQX CAN command.
Some code re-arrangement in CAN.
Calibration tables over CAN. Commonised somewhat with calibs via serial.
2013-01-17 JSM
Update firmware loader to support MS2 newserial.
Tooth loggers working over CAN.
Updated loaders
-- Alpha 1 --
2012-12-22 JSM
2012-12-23 JSM
2012-12-28 JSM
2012-12-30 JSM
2013-01-13 JSM
Various ini tweaks.
CAN tweaks.
2013-01-15 JSM
Remove 't' command.
2013-01-16 JSM
memset outpc.
2013-01-17 JSM
Updated loaders
-- Alpha 1 --
Re: MS3 pre-1.3 ChangeLog
2013-01-19 JSM
Disable CAN MSG_PROT auto-broadcast for now, causing problems.
-- Alpha 1a --
-- Alpha 1a --
2013-01-23 JSM
Improve "poll level" re-sync.
Ensure re-sync checks happen at high-speed re-sync during running.
Cleanup unused variables.
2013-01-25 JSM
Improve serial out of range size+offset test.
Same for CAN.
Test code to allow swapping batch/semi/seq.
Re-arrange outpc for more optimised reads.
Allow every-event cranking transitioning to seq.
2013-01-26 KWC
Fix Rotary COP mode so that it doesn't require the FC/FD selection.
2013-01-27 JSM
Newserial trap for out of range 'size' header.
Support hardware timer input for shaft speed. Allow up to 650,000rpm. Allow fractional tooth numbers.
Add VSS3 and VSS4. Re-arrange VSS page.
Shaft speed now used summed calculation like VSS.
2013-01-29 JSM
Remove SERIAL_TIMING debug code
Resolve potential bogus initial rpm during cranking.
Re-write cam-sync method for dual+missing and poll level.
Allow VVT table Y-axis to be TPS
2013-01-30 JSM
Default VVT duty set so that outputs are off when inactive.
Don't report config error if log crank+cam and VVT enabled.
Ensure Knock control initialised correctly.
ini tweaks
Implement can_err_cnt to detect dead devices.
2013-01-31 JSM
Add sanity check in gen_pwm rtc code to prevent infinite loop.
Fix genpwm/ALS
Support more frequencies in generic PWM.
2013-02-02 JSM
Optimise overdwell interrupt code. (~4% reduction in time)
2013-02-03 JSM
Minor optimisation in map sampling RTC code.
2013-02-04 JSM
Add in BMW/Siemens CAN broadcast messages from Peter Florance
Finish off ini changes for Gen PWM freq changes.
2013-02-11 JSM
generic_swpwm_setup()
ALS PWM has own channel
Move slow WI PWM to new PWM system.
Move boost1+2 slow PWM to new PWM system
Set too-cold O/L boost duty to zero.
Allow swpwm to flip two pins.
Convert nitrous PWM to new PWM system.
2013-02-17 JSM
ini greying for OL boost open/close duties
Optimisations in compress C/ASM and crc32.s
Optional SDcard readback timing. (currently enabled)
Allow any SCI baudrates.
2013-02-20 JSM
More SDcard readback optimisations
SCI baud switching commands
Allow config error message to be read back. (r <canid> 07 04 00 00 ff)
2013-02-21 JSM
RPM/TPS triggers to start SDlogs.
Option to light CEL until fully running.
2013-02-27 JSM
Fix Viper gen2 decoder (resync)
2013-02-28 JSM
Allow variable frequency on generic PWM outputs.
Reduce inprecision at higher frequencies by half a timer tick.
checkforpit0() to help flex.
Flex sampling changes to smooth outputs.
Mainloop time averaging (dev use only.)
Gen PWM curve option. (UI incomplete) Make load axis *1 instead of *0.1
2013-03-01 JSM
Gen PWM UI update from PT. Requires TS >= 2.1.31
SDcard debug code.
Resolve stepper idle not moving to cranking position in flood clear mode.
Allow stepper idle to home to open position.
ini tweaks. Requires TS >= 2.1.32
2013-03-02 JSM
Honda K24A2 as TSX offset by 40 degrees
2013-03-03 JSM
Minor stepper IAC warmup change.
2013-03-12 JSM
Allow 129 teeth / 6cyl in tri-tach. Untested.
Experimential staged injection relay output.
2013-03-15 JSM
Staged inj relay polarity flip.
2013-03-17 JSM
Add int_sqrt32() function.
Start of fuel pump/pressure code.
Implement fuel correction for GM fixed rail.
Implement OL PWM fuel pump control. (Limited bench testing, normal FP control re-written too.)
ms3loader change for enter_boot_command
2013-03-20 JSM
RTC idle bugfix.
Tiny speedup to init code.
Allow a gradual transition even with relay staging.
Stepper idle homing changes from MS2.
Apply cranking idle position when not running (instead of waiting until actually cranking.)
2013-03-21 JSM
Get rid of motor_reset
Show programmable on/off outputs in i/o pins list.
2013-03-24 JSM
EAE combi window. (testing.)
SDcard log FAT allocation bugfix.
2013-01-25 JSM
Same for CAN.
2013-01-26 KWC
2013-01-27 JSM
2013-01-29 JSM
2013-01-30 JSM
ini tweaks
2013-01-31 JSM
Fix genpwm/ALS
2013-02-02 JSM
2013-02-03 JSM
2013-02-04 JSM
2013-02-11 JSM
2013-02-17 JSM
2013-02-20 JSM
2013-02-21 JSM
2013-02-27 JSM
2013-02-28 JSM
2013-03-01 JSM
SDcard debug code.
2013-03-02 JSM
2013-03-03 JSM
2013-03-12 JSM
2013-03-15 JSM
2013-03-17 JSM
2013-03-20 JSM
RTC idle bugfix.
2013-03-21 JSM
2013-03-24 JSM
2013-03-25 JSM
Alternator UI.
2013-03-27 JSM
Fuel pressure/temperature.
-fuel_sensors()
-add pri temp/press corrections
-add outpc data for pri/sec temp/press
First draft of alternator control code. Most open-loop functionality in place.
2013-03-28 JSM
Add closed-loop fuel-pump and alternator.
-- Alpha 2 --
Alternator UI.
2013-03-27 JSM
-fuel_sensors()
2013-03-28 JSM
-- Alpha 2 --
2013-03-30 JSM
Fix int/uint comparison on log_trig_tps
2013-04-02 JSM
ini ranges for on/off outputs
MAP sample false error
2013-04-03 JSM
ini tweaks for idle
Alt control. More code for lamp output. More code for on/off mode.
pwmidle_dp_decay_factor defaults to zero
Pre-relay output for staging flaps.
2013-04-04 JSM
High power time enrichment.
Specific shift light incl. gear based
HPTE limits time to max in curve.
2013-04-05 JSM
Move glob_sequential initialisation to fix Subaru seq error.
ASE ini curve fix.
First draft LTT front end.
2013-04-06 JSM
Anti-lag correct input polarity on Nitrous-in pin.
Add fuel-pressure and alternator control fields to datalog.
Alternator TPS WOT wasn't signed.
2013-04-07 JSM
Remove "IAC cold position" feature. (Nobody understood it.)
Calculate Flex adjustment before starting too. Only calc flex on each pulse.
gen_pwm default Y axes /10 to match scaling.
Oil pressure monitoring.
Updated loaders to 3.26
-- alpha 3 --
2013-04-02 JSM
2013-04-03 JSM
ini tweaks for idle
2013-04-04 JSM
2013-04-05 JSM
ASE ini curve fix.
2013-04-06 JSM
2013-04-07 JSM
-- alpha 3 --
2013-04-11 JSM
Enable additional gcc warnings and address them.
Don't try to start wasted-COP on dual+missing for 3+ odd cylinders
2013-04-13 JSM
Fix page 0x7f CRC calc.
Rename AWC, AWEV
Flex% alters cranking PW.
Apply generic sensor naming ini file patch from PT.
2013-04-14 JSM
User settable fuel flow/economy calc interval
2013-04-19 KWC
Fix bug elaw found in idle where in certain circumstances, the the ramp to
target won't ramp.
Add PID sensitivity setting, get rid of several redundant or confusing settings
and do general cleanup of CL Idle.
2013-04-19 JSM
Reduce alternator PID sensitivity.
2013-04-20 KWC
Get PID sensitivity slider working, and non-linearity curve.
Still need to make it so adjusting sensitivity doesn't change duty.
2013-04-23 JSM
MAF logger and re-arrange some bits in flagbyte0
Fix CRC32 on calibration pages.
Apply some ini extensions from PT.
TPSautozero all the time (if on)
2013-04-24 KWC
Make it so adjusting alternator PID sensitivity doesn't change the output
duty.
2013-04-24 JSM
Resolve 1-cyl 2-stroke fuel output issue.
Rotary trailing spark works in test mode.
VVT allows exhaust to use a table of retard angles.
2013-04-26 JSM
Different implementation of VVT exhaust retard.
Add 80 more tooltips
Add ram27
2013-04-27 KWC
Add several tooltips for boost control and closed loop idle.
2013-04-29 JSM
Fix issue with zero PW during cranking in certain configs (egocor)
2013-04-30 JSM
Get Megaview working again (special case in serial range check)
2013-05-08 JSM
Fix LTT crash (only happened when first turned on and engine already running.)
Sort out RTC 10ms timer (observed as Seq-shift-cut problem)
2013-05-09 JSM
ini tweaks so fuel/spark/afr/eae tables show actual load axis units.
CL idle minvss setting
tool tips for sequential shift
Add hundreds more tool tips
2013-05-10 JSM
Fix potential bug in flex fuel timing addition.
Baseline ethanol% in flex-fuel.
-- Alpha 4 --
2013-04-13 JSM
Rename AWC, AWEV
2013-04-14 JSM
2013-04-19 KWC
target won't ramp.
2013-04-19 JSM
2013-04-20 KWC
2013-04-23 JSM
2013-04-24 KWC
duty.
2013-04-24 JSM
2013-04-26 JSM
Add ram27
2013-04-27 KWC
2013-04-29 JSM
2013-04-30 JSM
2013-05-08 JSM
2013-05-09 JSM
2013-05-10 JSM
-- Alpha 4 --
2013-05-12 JSM
On/off outputs allow negative thresh/hyst
2013-05-15 KWC
Start adding boost sensitivity slider
2013-05-16 JSM
Update ini to show "indicators" using decimal bitmasks.
Allow 2JZ mode for 8 cyl. Angles are an untested guess.
2013-05-20 JSM
Implement EGO authority table.
Don't allow overrun immediately afterstart (untested.)
Fixes to LTT. Allow it to work on a fresh flash. Change auto-burn behaviour.
2013-05-21 JSM
Re-write overrun fuel cut. Implement gradual retard and AE-event on return.
Re-arrange GM HEI,GMDIS, TFI mode options.
Add mode for C3I that should sync faster.
Experimental code to record time per cylinder event as %age.
2013-05-22 JSM
Disable over-dwell mode with fixed-duty dwell.
In next-cyl basic trigger, ensure coil is fired AT trigger always.
Apply correct bitmask to ram4.dwellmode
2013-05-25 KWC
Add boost control sensitivity code. (UNTESTED)
2013-05-29 JSM
Add boost duty to datalogs.
Rename SDcard "insertion" to "always"
Test code for SDcard baud rate. (Will be removed later.)
Revert "TPSautozero all the time (if on)"
2013-05-30 JSM
Work on implementing multi-block write for SDcard, but backed it out as one card tested cached too much data.
2013-06-01 JSM
Small code re-arrangement with cam init.
Fix PT5 Nissan CAS / tri-tach input bug.
Apply off/min/max duties to FP control.
Allow 360 +-20 in trigger angle/offset to swap phase on custom decoders.
2013-06-01 KWC
Fix up defaults for boost control sensitivity.
Fix potential overflows in boost, alt ctl, and FP ctl.
2013-06-01 JSM
Allow transbrake to work w/o launch or to share launch input. Respect polarity on 'nitrous' input.
Turbo Car Staging.
2013-06-02 JSM
Ungrey VVT exhaust tables.
2013-06-03 JSM
Loader tweaks for Mac
2013-06-05 JSM
Selective realtime data reads. 'g'. Not yet enabled in ini.
Add "TurboBaud" section to ini. TS now supports it.
2013-06-08 JSM
Update init to show allocation on all common pins. Fix lack of config error on MAP.
Allow TS to read 'portusage'
Extend ini file so TS can display usage of I/O pins. (MS3 names only)
Re-arrange pins by feature dialogue.
Make 'g' feature into 3 bit size.
2013-06-09 JSM
Add MS3-Pro names for I/O pins
-- Alpha 5 --
2013-05-15 KWC
2013-05-16 JSM
2013-05-20 JSM
2013-05-21 JSM
2013-05-22 JSM
2013-05-25 KWC
2013-05-29 JSM
2013-05-30 JSM
2013-06-01 JSM
2013-06-01 KWC
2013-06-01 JSM
Turbo Car Staging.
2013-06-02 JSM
2013-06-03 JSM
2013-06-05 JSM
2013-06-08 JSM
2013-06-09 JSM
-- Alpha 5 --
2013-06-20 JSM
Help entries for curves and tables. Believed that everything has a tool-tip entry now.
2013-06-28 JSM
Multi-period MAP sampling bugfix.
2013-06-29 JSM
Update ini per PT for scattered realtime data and portusage.
Update ini to show "indicators" using decimal bitmasks. (This change got lost)
Update ini for dual-fuel pressure limits.
Tweak a few defaults.
2013-07-03 JSM
Fix VSS2 digital sampling
2013-07-04 KWC
Add variable re-engagement of fuel based on RPMdot for overrun fuel cut.
(Untested).
2013-07-06 JSM
Megaview temp units conversion
2013-07-11 JSM
Sequenced batchfire bugfix (alienblood issue)
2013-07-12 JSM
Implement hold-current for stepper "moving only"
VVT minimum temperature
Overboost tolerance
Remove MPH and METRES from Project Properties, now set in Gauge/Settings limits.
Re-do ini entries for VSS to use calculated unit names per PT
Re-de ini entries for wheel dia likewise.
Allow VSS PPM upto 65535 (untested)
Rationalise setting of ENGINE_CRANK (was applied in some wheel modes)
Implement crank pulsewith taper curve
2013-07-13 JSM
Add/fix two CAN broadcast messages.
Optionally ignore knock during launch/flatshift
2013-07-14 JSM
Remove EXPANDED_CLT_TEMP from Project Properties, now set in Gauge/Settings limits.
Add wheel speed based launch control.
2013-07-15 JSM
Add Miata 36-2 wheel mode
2013-07-16 JSM
Add min/max DC limits to VVT
Fix 0x561 naming in ini
2013-07-17 JSM
Smoother disengagement of overrun.
Add VVT slew feature
2013-07-21 JSM
Re-arrange generic_digout options and include Spk A-H. (CANPWMx still needs checking)
2013-07-22 JSM
Tweak code order for VSS setup. No functional change.
2013-07-31 JSM
Allow fractional teeth for VSS.
ini fixes. Widen lower calibration points on batt, map. Ungrey wheel diameter for VSS/RPM
Tweak to map_local
2013-08-01 JSM
Correct interrupt masking for VSS2 with 32bit CAN PWM
2013-08-02 JSM
Port HD32-2 from MS2.
Implement skipdwell, skipinj.
Changes to MAP-phase sensing.
2013-08-03 JSM
Fix MAP/MAF loggers. (Earlier RTC optimisation caused problem.)
Change MAF sampling to event-average always.
Allow MAP sensor to be disabled.
Minor formatting change of config error message strings.
Add more CAN broadcast for Alfa/Lancia/Fiat (untested)
Add "Engine Logger" for diagnostics.
2013-08-04 JSM
More pins for PWM idle. (Uses generic setup.)
More formatting changes to config error message strings.
Allow PWMidle to be off during KOEO.
-- Alpha 6 --
2013-06-28 JSM
2013-06-29 JSM
2013-07-03 JSM
2013-07-04 KWC
(Untested).
2013-07-06 JSM
2013-07-11 JSM
2013-07-12 JSM
Overboost tolerance
2013-07-13 JSM
2013-07-14 JSM
2013-07-15 JSM
2013-07-16 JSM
2013-07-17 JSM
2013-07-21 JSM
2013-07-22 JSM
2013-07-31 JSM
Tweak to map_local
2013-08-01 JSM
2013-08-02 JSM
2013-08-03 JSM
2013-08-04 JSM
-- Alpha 6 --
2013-08-04 JSM
BMW S54 cam decoder. (untested) (Also touched sync method for dual+missing.)
Specific boost targets per gear.
Removed erronous debug code clobbering sensors1-5.
2013-08-07 JSM
Re-arrange launch/flat-shift activation code and implement flat-shift minimum VSS
Correct code checking for VSS available.
2013-08-08 KWC
Start of EGO looptime code (.h files mainly).
2013-08-08 JSM
Re-work rev-limiting incl. launch/flat-shift/overboost.
-Implement random progressive spark cut
-Implement non-rotational fuel cut
-Streamline settings
2013-08-09 JSM
Toothed wheel wasn't switching to Full-sync (typo)
Re-arrange/re-name idle control valve/algorithm settings.
ini tweak
Ensure "off" EGT channels really are.
Implement fuel pressure safety
Fix a bug from the 8th in AFRsafety that didn't cut spark.
2013-08-10 JSM
Bugfix for semi-seq 100% duty. (nismoautoxr)
Implement BMW S54 3-wire solenoid outputs.
2013-08-12 JSM
In S54 mode, VVT test operates both paired outputs.
2013-08-13 JSM
LTT was interfering with table blending.
Swap phase on Viper Gen1. (turbo355)
spk/inj dropping testmode
36-2-2-2 with cam - tougher resync check at and just after start
-- Alpha 7 --
2013-08-07 JSM
2013-08-08 KWC
2013-08-08 JSM
2013-08-09 JSM
ini tweak
2013-08-10 JSM
2013-08-12 JSM
2013-08-13 JSM
-- Alpha 7 --
2013-08-18 JSM
Change scaling on vss_out to whole numbers to allow up to 65535ppm
2013-08-20 JSM
Fix 710.1deg tooth#1 angle bug (Teg)
Comment out dupe code and initialise mid_last_tooth
2013-08-22 JSM
Add hyst to launch fuel-cut.
Only use boost tolerance in closed-loop.
Fix 32bit fields in qfrt
2013-08-30 JSM
Ensure CL idle target is looked up when not in CL mode too and curve ungreyed.
Ensure CL idle target is reported always and includes taper.
Ensure C2R taper works (sensitivity change altered behaviour.)
Add gauge for CL idle target.
Fix slow startup of VSS calcs.
Fix flat-shift advance / minvss
Overrun - progressive fuel cut/return
2013-09-01 JSM
Loader version 3.30 can use detected hardware type.
Added 'M' serial command to return MONVER.
2013-09-01 KWC
Added tooltips for new overrun fuel cut RPMdot based fuel return.
2013-09-02 JSM
Improve serial handling of noise/interference/corrupt data on one channel (MS3-Pro)
2013-09-03 JSM
Overrun progressive tweak
On-the-fly 1024 MAF transfer curve.
2013-09-04 JSM
Sum mafflow in isr (per S.Hauer work)
2013-09-06 JSM
Fix minor error in ini for mafflow.
Ensure negative summed MAF doesn't underflow.
ini tweak for SDcard console
2013-09-07 KWC
Add EGO delay table.
2013-09-07 JSM
Re-do BMW S54 VVT mode.
Fix bug with hold-duty that prevented higher VVT channels from calculating.
2013-09-09 JSM
Add fueltemp_cor, fuelpress_cor, ltt_cor to outpc.
Use correct signed interpolation routine for LTT lookup.
2013-09-17 JSM
Change WI fluid low to interact with AFR safety as EGT does.
Fix potential fuelcalc overflow in LTT
2013-09-19 JSM
Change TPS behaviour on CEL
maf_volts reflects instantaneous MAFv, not averaged.
Gen PWM can use field selector. (Mostly TS feature.)
2013-09-20 JSM
Disable sharing ADC0 in generic_adc_setup
Clear options to disable MAP and MAF sensor inputs.
Clarify MAP/baro page.
2013-09-22 JSM
ini fix. vetable4 uses fuelload2
2013-09-25 JSM
Gen PWM more ini changes
-- Alpha 8 --
2013-08-20 JSM
2013-08-22 JSM
2013-08-30 JSM
2013-09-01 JSM
2013-09-01 KWC
2013-09-02 JSM
2013-09-03 JSM
2013-09-04 JSM
2013-09-06 JSM
2013-09-07 KWC
2013-09-07 JSM
2013-09-09 JSM
2013-09-17 JSM
2013-09-19 JSM
2013-09-20 JSM
2013-09-22 JSM
2013-09-25 JSM
-- Alpha 8 --
2013-10-08 JSM
s19tail.inc preserves flash25,27,LTT also
2013-10-12 JSM
Add tc_retard, cel_retard, fc_retard, ext_retard to outpc.
Clean up WCOP handling for dual+missing.
2013-10-13 JSM
Add base_advance, idle_cor_advance, mat_retard, flex_advance, adv1-4
revlim_retard, als_timing, als_addfuel to outpc
Ensure ALS sets timing and addfuel to zero when off.
Fix bug where idle-assist timing timer didn't work.
ext_retard -> ext_advance
Add fuelcalc and sparkcalc summary pages to TS.
portb wasn't showing in PORT_STATUS correctly.
2013-10-14 JSM
Add bitmasks to gen PWM field selector variables.
2013-10-15 KWC
Add config data for generic PID.
2013-10-16 JSM
sci_baud actually sets lower rates (typo)
PW4X shown in status8
2013-10-18 JSM
Expose more internal spark calcs and set lsum in main.
Reduced CANMSG to 10 to solve stack overflow.
Implement CEL flash codes and other CEL code changes.
2013-10-19 JSM
Add stepper idle in/out cycle test.
2013-10-20 JSM
Tweak EGT shutdown behaviour.
Add timeout to vsslaunch
Add Nissan VK56 support to QR25DE decoder. Change expected phasing of cam pulses.
Extend VQ35DE to support VVT (untested)
Add Hemi VVT (as VVT option) (untested)
Add poll_level_tooth (should allow Rover 4.6)
Add tooltip and clarify greying on boost gear targets.
Clear up VVT data checks in wheeldecoder (BMW/Hemi)
2013-10-26 JSM
Fix coolant limiter spark cut
2013-10-27 JSM
Decrement can_err_cnt[] once per second
2013-10-29 JSM
Implement unsigned bit for on/off outputs
Fix ini errors that broke boost2 sensitivity, staged secondary enrichment and fuelcut rpmdot settings.
2013-10-30 JSM
Fix ini error on egomap
2013-11-02 JSM
Update LICENSEs
Change fan handling at crank/run and add delay.
Overrun changes. Ensure cyls aren't cut on return.
VVT hemi
2013-11-06 JSM
Overrun changes.
2013-11-07 JSM
Overrun
-Fix scaling on RPMdot
-Cancel prog return if RPMdot too much.
-Add in bitfield defines.
-fuel pulse counter debug in status4 remains
2013-11-10 JSM
Fix CAN1ST typo.
2013-11-11 JSM
Use datax1.IdleAdj in PWM warmup, Stepper warmup and add on delta in both closed-loop modes. (untested)
Rename some idle vars.
unsigned bit for genPWM (partially tested)
Add support for 36-2-2-2 VVT engines (untested) LH = main cam sensor, set VVT teeth=4
Alfa messages sent after initial message. (untested)
Chrysler 2.2/2.5 changes from MS2 (bench tested only)
2013-11-13 JSM
Remove dead code from misc
2013-11-15 JSM
ini tweaks
2013-11-16 JSM
Fix handling of CANPWMs in swpwm code.
Port Jean's outmsg handling from MS2.
Handle CANPWMs in mainloop and allow 0-255 scaling.
2013-11-17 JSM
Group code for CANin, CANout init.
2013-11-18 JSM
Correct type in second condition of on/off outputs.
Range check 'k' table size to prevent crash.
Add additional flash page.
Re-arrange init so that config error for flash erased error could be seen if it occurred.
2013-11-19 JSM
Don't do WCOP on >2cyl oddfire using even wheel.
Replace some RTC swpwm code that was deleted in error. Omission was causing a crash.
Change CAN_COMMANDS to default to enabled.
-- Alpha 9 --
2013-10-12 JSM
2013-10-13 JSM
2013-10-14 JSM
2013-10-15 KWC
2013-10-16 JSM
2013-10-18 JSM
2013-10-19 JSM
2013-10-20 JSM
2013-10-26 JSM
2013-10-27 JSM
2013-10-29 JSM
2013-10-30 JSM
2013-11-02 JSM
Update LICENSEs
VVT hemi
2013-11-06 JSM
Overrun changes.
2013-11-07 JSM
Overrun
2013-11-10 JSM
Fix CAN1ST typo.
2013-11-11 JSM
2013-11-13 JSM
2013-11-15 JSM
ini tweaks
2013-11-16 JSM
2013-11-17 JSM
2013-11-18 JSM
2013-11-19 JSM
-- Alpha 9 --
2013-12-01 KWC
Start adding code for generic PID. Add more flash data for generic PID. Compiles
but as yet not finished and untested.
2013-12-01 JSM
ini tweaks
wheelspeed launch
-Expose re-arm speed
-Provide maxgear setting
-indicators for ON and LockOut
2013-12-08 JSM
All flagbytes as volatile
2013-12-13 JSM
Some more atomic changes.
Rename 'flash' to 'dflash' to prevent problems with MS2 pasted code.
Oddfire/oddcyl wheel decoder changes from MS2.
-- Alpha 10 --
2013-12-01 JSM
ini tweaks
wheelspeed launch
2013-12-08 JSM
2013-12-13 JSM
-- Alpha 10 --
2013-12-15 JSM
Remove some debug lines.
Fix "stuck" fuel-cut in launch.
2013-12-18 JSM
Change Subaru 6/7 re-sync method during cranking.
Don't show config error for knock if already a config error.
2013-12-27 KWC
Finish C code part of Generic PID (PWM only to start). Still working on ini.
2013-12-28 (22) JSM
Add GPS data to outpc and datax1 and CAN capture.
Apply tc_retard to ign timing.
2013-12-29 KWC
Add Generic PID output polarity functionality.
Add min RPM for AC idleup activation. Allow it to activate even on crank.
Add tooltips for Generic PID.
2013-12-30 JSM
Add dwell table.
Add min/max limits to SpkAdj. (untested)
2013-12-31 JSM
Tweak to twin-trigger cam speed 2 cyl. (Should be no functional change.)
Add CAN MSG_SPND fix from Jean
(debug code for VVT - remove before flight)
2014-01-01 JSM
VVT angle calc, handle when min/max not set.
GPS reading from IO-extender. Add ini gauges, fix typo in code.
2014-01-02 JSM
CAN RTC was sometimes calling can_inc_ring() in error
CAN polling load balancing
2014-01-03 JSM
VVT angle calc for wraparound.
Add rev2 SDcard datalog mode for interleaved GPS data with 64 byte.
Allow sig-PIP to run COP (untested)
2014-01-04 JSM
Add engine shutdown feature. Send 0x8501 to table 7 offset 683
Apply {loadhigh} to various load gauges.
Send BCD encoded year to set RTC on Extender.
2013-01-04 KWC
Make Generic PID actually work.
2014-01-07 JSM
Crank pulsewidth taper can be in events.
genPID chan2 RTC section could be missed
2013-01-07 KWC
Make units for generic PID table and the upper and lower input limits use the same scaling as the
selection for the PV to use.
2013-01-08 JSM
Re-arrange, rename, update ini entries for Generic Closed Loop (PID). Add default data.
VSS2 uses correct bits to select sensor position.
2013-01-10 JSM
T/C retard set to zero when off.
Allow TFI sig-PIP to have >1 coil
2013-01-11 JSM
Remove RTC_TIMING, SDREAD_TIMING
Remove some debug snippets.
Master CAN polling/broadcast selector.
VVT subtract/add extra 5.0 deg for normalising calc.
-- Beta 11 --
2013-12-18 JSM
2013-12-27 KWC
2013-12-28 (22) JSM
2013-12-29 KWC
2013-12-30 JSM
Add dwell table.
2013-12-31 JSM
2014-01-01 JSM
2014-01-02 JSM
2014-01-03 JSM
2014-01-04 JSM
2013-01-04 KWC
2014-01-07 JSM
2013-01-07 KWC
2013-01-08 JSM
2013-01-10 JSM
2013-01-11 JSM
-- Beta 11 --
2014-01-12 JSM
Update engine shutdown feature. Send 0x8502 to table 7 offset 683 for spark cut. 0x8503 for fuel and spark cut
2014-01-17 JSM
Allow mafload to be zero.
ini tweaks
Change QR25DE 4cyl phase.
2014-01-20 JSM
Move Trigger Wizard to ignition menu in ini.
PWM warmup idle uses crank table when rpm==0
Boost duty set to 0% at power-on.
2014-01-22 JSM
Remove some dead code from isr_rtc
ini tweaks - make menu names match dialogues
Undo allowing COP with sig-PIP - it doesn't work.
2014-01-25 JSM
Reject 1 tooth.
Wait less time on low battery at init.
2014-01-27 JSM
triggerteeth range
Update GPS ini entries to match JBperf IO-extender 0.13 firmware.
-- Beta 12 --
2014-01-17 JSM
ini tweaks
2014-01-20 JSM
2014-01-22 JSM
2014-01-25 JSM
Reject 1 tooth.
2014-01-27 JSM
triggerteeth range
-- Beta 12 --
2014-01-30 JSM
Add facility to display sensor ADC counts in CEL system.
2014-02-01 JSM
CEL CLT max checks correct ADC port.
ini tweaks
2014-02-02 JSM
ini: 'divider' requires power cycle.
2014-02-09 KWC
Make the valve stay at 100% for closed loop boost until at target-delta load. Should spool faster this
way.
Fix CLT boost limit behavior so that we don't try to control boost AT ALL below the CLT limit. (i.e.
0% duty)
2014-02-10 JSM
Boost control, keep valve unpowered (open) until MAP>baro.
2014-02-14 JSM
GM bypass handling changed.
- CPU pin polarity matches main spark polarity - might require re-wiring on "LEDs" if using JS10
- Turn on Bypass output sooner (per user request)
Ensure spark output is reset on a stall with Fixed Duty
Revert QR25DE sync code for 4cyl.
Make MAF logger work for freq MAFs (calcs freq TS side)
-- RC 1 --
2014-02-01 JSM
ini tweaks
2014-02-02 JSM
2014-02-09 KWC
way.
0% duty)
2014-02-10 JSM
2014-02-14 JSM
-- RC 1 --
2014-02-15 JSM
Remove some unused sections from ini
2014-02-19 KWC
Remove dashpot decay. Causes more problems than it solves.
2014-02-21 JSM
Commonise NUM_CHANS, resolve egtport[] size.
2014-02-22 JSM
Add some missing tooltips to ini, tweaks.
2014-02-24 JSM
Fix error in VVT calc introduced on 2013-01-11
2014-02-26 JSM
Rotary trailing wasn't spark-cutting.
Put XGATE random_no table in the correct place.
Remove debug code from XGATE
2014-02-28 JSM
Fix egt_init bug.
-- RC 2 --
2014-02-19 KWC
2014-02-21 JSM
2014-02-22 JSM
2014-02-24 JSM
2014-02-26 JSM
2014-02-28 JSM
Fix egt_init bug.
-- RC 2 --
2014-03-01 JSM (Committed late)
Make EGT actually work again.
-- RC 3 --
-- RC 3 --
2014-03-01 KWC
Fix a bug in boost control where last error variable was always using first channel and never
second channel. Only breaks when using 2 channels.
Make boost PID init work again. Should avoid any weird behavior when PID first engages.
2014-03-05 JSM
Limit CAN EGO to 1023 counts.
2014-03-07 JSM
Rename not-synced and full-sync indicators.
-- 1.3.0 release --
2014-03-05 JSM
2014-03-07 JSM
-- 1.3.0 release --
2014-03-09 JSM
Handle another impossible tooth count with config error.
2014-03-10 JSM
Typo causing GPS to trigger single event fuel cut.
2014-03-14 JSM
Average 1-cyl RPMs over two revs.
Use "vvt_decoder" var in init.
2014-03-17 JSM
Use TS generated CLT, MAT GM calibrations. Use MAT for "GM calibration"
2014-03-22 JSM
Many after-launch features broken on 2014-08-07, STATUS2_LAUNCH was not being used.
Traction changes for perfect run and button modes.
2014-03-25 JSM
Fix timer rollover for boost delay.
2014-03-24 KWC (backport JSM)
Fix table blend behavior with boost initial values table.
Rename "closed/open" to "minimum/maximum" for boost and idle valve settings.
2014-03-28 JSM
Fix rogue pulses on MS3X secondaries for staging or dual-fuel.
MS3X non-sequential staging uses expected number of outputs.
Fix staging transition "saw-tooth" issue.
Re-do staging duty calcs to work with sequential.
2014-03-29 JSM
Extend vssout_scale to 32bit. (untested)
-- pre-1.3.1 beta 2 --
2014-03-10 JSM
2014-03-14 JSM
2014-03-17 JSM
2014-03-22 JSM
2014-03-25 JSM
2014-03-28 JSM
2014-03-29 JSM
2014-04-03 JSM
EGO "load above" setting allows negative numbers.
2014-04-04 JSM
Boost control "mid" output setting wasn't working.
2014-04-19 JSM
Alter phasing on 36-2+2 NGC 6-cyl
2014-04-24 JSM
Fix up ini bitfield errors (would have broken some settings on gen PWM, water inj)
Fix Time-After-Spark (same issue as MS2)
2014-04-25 JSM
Implement CAN TX timeout and reset.
2014-04-26 JSM
Fixed max VSS for launch and change logic for VSS flat-shift.
2014-05-02 JSM
Change NGC6 phasing again.
Fix MPG calc (off by factor of 10)
ini tweaks
2014-05-08 JSM
Allow up to 12 VVT teeth in ini.
-- pre-1.3.1 beta 3 --
2014-04-04 JSM
2014-04-19 JSM
2014-04-24 JSM
2014-04-25 JSM
2014-04-26 JSM
2014-05-02 JSM
ini tweaks
2014-05-08 JSM
