2014-05-09 JSM
Fix CL idle getting "stuck" just after cranking.
Fix flex fuel temperature calculation.
Add config error for unsupported 36-2-2-2 combinations
Change defaults for ITB load.
Swap phase on GM7X 6cyl.
Remove "ability" to use +360 on trigger angle/offset to swap phase - not working.
2014-05-12 JSM
Fix a couple of ini error that TS missed.
2014-05-17 JSM
Fix TPSdot limits in ini.
2014-05-19 JSM
Extend AFR table limits in ini.
2014-05-20 JSM
ini - capitalisation and consistency
- some units standardisation (gives some warnings on old MSQ load)
- remove GridHeight
Experimental non-linear spk cut for launch.
-- pre-1.3.1 beta 4 --
MS3 1.3 ChangeLog
Re: MS3 pre-1.3 ChangeLog
2014-05-23 JSM
Reduce serial timeout to 25ms.
2014-05-25 JSM
VSS and SS sampled every 50ms instead of 100ms
2014-05-28 JSM
EDIS sets "Full RPM sync"
-- pre-1.3.1 beta 5 --
-- 1.3.1 release --
2014-05-25 JSM
2014-05-28 JSM
-- 1.3.1 release --
Re: MS3 1.3 ChangeLog
2014-05-30 JSM
Fix timing issue with 36-2-2-2 (4cyl) running COP or seq fuel.
2014-06-02 JSM
Clarify error 71.
Backport Miata alternator control from 1.4.x
2014-06-03 JSM
ini tweaks from 1.4 (units on tables/gauges)
Add AEM 3.5 bar and 5.0 bar MAP sensors to dropdown.
-- pre-1.3.2 beta 1 --
2014-06-02 JSM
Clarify error 71.
2014-06-03 JSM
2014-06-04 JSM
Fix rotary trailing calculation error (evident near 0deg advance)
2014-06-06 JSM
Allow spark 45deg ATDC. (Was limited to 10ATDC in Oct'13)
Fixed zero sized extended CAN packets xmit in error.
2014-06-08 JSM
Assign correct config error numbers for VSS2.
Fuel pump (O/L or C/L) sets correct portusage.
2014-06-09 JSM
3-cyl single-coil - beware of possible side effects
2014-06-24 JSM
Fix to oddfire custom angles (accumulate odd_trig_offset)
2014-06-26 JSM
Allow fuel calcs to run w/o MAP or MAF sampling.
Don't flag VVT error for on/off output.
Tweak CAN VSS defaults.
2014-06-27 JSM
Fix typo nitrous / 3step.
Powercycle required for nitrous.
-- pre-1.3.2 beta 2 --
2014-06-06 JSM
2014-06-08 JSM
2014-06-09 JSM
2014-06-24 JSM
2014-06-26 JSM
2014-06-27 JSM
2014-07-08 JSM
Fix MS3Pro HEI bypass polarity issue.
2014-07-09 JSM
Tooltip tweak.
2014-07-11 JSM
Roving idle only works if anti-lag on.
-- 1.3.2 release --
2014-07-09 JSM
Tooltip tweak.
2014-07-11 JSM
-- 1.3.2 release --
