1.2.3. 60-6 2 stroke?
Re: 1.2.3. 60-6 2 stroke?
Tried to assemble the 1.4.0 code with the 60-6 wheel and ran into an issue?
- Attachments
- 2018-01-23 16.57.00.png (485.08 KiB) Viewed 2510 times
one of the other things i am working on is how to let megasquirt know the oil pump is working
and if not, to take action on that
since obviously a oil pressure sensor will not work here and flow senors will add serious cost
i thought about using the fly-back of the oil pump as a trigger for oil pump operation
now i am not an electronics engineer so serious fault can be expected
in the 1.4.0 code a PWM ouput can be variable frequency or duty cycle
which one is of no importance but i used variable frequency here with a minimum of 10 hertz
with the very rudimentary circuit i used here
flyback from turning off the oil pump would break through the zener voltage turn on the npn transistor giving a digital low on a frequency input of megasquirt
and turn off once the flyback dissipates
next we have the settings for the flex fuel input normally this would add ignition advance based on the ethanol content
but now we are removing it
with the PWM minimum of 10 herz everything below that would mean a non working oil pump and therefore remove ignition advance from the engine
any ideas comments very appreciated
- Attachments
- flyback coil.jpg (82.96 KiB) Viewed 2497 times
- PWM_output.PNG (155.91 KiB) Viewed 2497 times
- Frequency_input.PNG (227.59 KiB) Viewed 2497 times
1. The compile error is that your code is too large to fit in that memory region. You'll have to delete some other stuff or shuffle things around into different sections.
2. For schematics, consider using a programme like Eagle or KiCad.
Ok i completely deleted the ngc wheel from the code
And we had succes
With circuit yes i know ihave eagle installed aas thierry from transmic does not like my scribbelings either
I was hoping by putting out there for my holiday so people could chime in
I will put some effort into it when i get back
Meanwhile wat are the chances of the wheel getting included in the ultimate code?
I have one here i can use for bench testing as it is not yet installed on my other engine!
And we had succes
- Attachments
- 2018-01-25 15.07.54.jpg (145.43 KiB) Viewed 2491 times
doing some testing with my pwmA looped back into flex fuel
as i could not get the reaction i wanted with the settings
i used sensor failure
halfway in the log i disconnect the flex fuel input (sensor failure)
creating a continuous high on the flex fuel input
but the ignition advance stays the same
so am a little puzzled here
- Attachments
- 2018-02-05_12.46.56.msl
- (202.53 KiB) Downloaded 81 times
- 2018-02-05_12.48.50.msq
- (274.61 KiB) Downloaded 72 times
- ms3_flex_input_small.PNG (268.86 KiB) Viewed 2458 times
it looks like mega-squirt only recognizes a failed sensor on start up
in the next log i disconnected flex fuel input when mega-squirt was turned on
and went from 0 rpm to high and back to 0 with no advance adjustment
halfway through the log i cycled mega-squirt power and now the ignition advance stays at the sensor failure setting
- Attachments
- 2018-02-05_13.07.14.msl
- (484.65 KiB) Downloaded 85 times
So the quistion is
Is this by design? Only looking for a failed senor on start up
Or should this be continously checking for a failed sensor!
The Flex input handling has been changed in recent releases although I've still yet to receive any feedback at all on whether customers see an improvement.
tried out 1.5.1 with a 60-2 wheel
it takes about 50 seconds before a flex fault is declared
in the log after i reach 3000rpm to when you see the advance drop offcourse
50 seconds without oil on a 3 liter v6 two stroke spinning at 7000 rpm
would it be very code intensive to make that user adjustable?
around 20 seconds after reconnecting flex input before the fault is cleared
i would definitely say flex fuel seems more responsive compared to 1.4
0 herz is zero herz now instead off 1 herz
- Attachments
- 2018-02-17_14.07.30.msq
- (284.27 KiB) Downloaded 111 times
- 2018-02-17_14.09.36.msl
- (526.57 KiB) Downloaded 86 times
well i promised a schematic but fighting all the way
could not get the npn to synch up jumps over the correct place
- Attachments
- Oil Pump Feedback2.png (8.78 KiB) Viewed 2401 times
Change your Grid to be finer (e.g. from 0.1 inch to 0.05 inch)
You'll also find GND and +5V symbols in "supply1" or similar library.
i made this in 7.7.0 which somehow seemed to work easier
but i guess you just need more time working with it
- Attachments
- electronic distributor.png (29.07 KiB) Viewed 2398 times
well finally had some time to pick this up after i bought a new boat
after doing some testing and reading about snubbers
i came up with this
the opto coupler is not installed so this is the pickup between the diode and the zener
would it be a problem to feed this directly into the megasquirt flex fuel input
or would the opto coupler be mandatory?
i came up with this
- Attachments
- megasquirt_mercury_oilpump_feedback.png (6.29 KiB) Viewed 2146 times
- oil pump feedback pulse.jpg (268.93 KiB) Viewed 2146 times
slightly revised as the flex fuel sensor would pull a 5 volt signal to ground
- Attachments
- megasquirt_mercury_oilpump_feedbackB.png (6.81 KiB) Viewed 2138 times
FYI, I've been seeing a bit more interest in this wheel lately. Matt Blasco dropped off one of these wheels with me at Drag Week, saying he's been getting customers wanting to run this pattern.
well it,s working live test with the last mentioned circuit
https://www.youtube.com/watch?v=53xOtUgEMac
the only thing i am not so happy with is the slow ignition de-advance after feedback is lost
- Attachments
- 2018-09-23_17.50.16.msq
- (274.24 KiB) Downloaded 71 times
- 2018-09-23_17.48.21.msl
- (677.87 KiB) Downloaded 70 times
is there any progress in adding this wheel to the code!?
the maxx ecu already seems to have support
i can buy an original flywheel of ebay and setup a Hall/flywheel combination to make a tooth time .csv!?
- Attachments
- maxx_ecu_mercury_marine.jpg (91.51 KiB) Viewed 1671 times
tested the 60_6 code on a genuine mercury flywheel
a mercury 135 optimax motor this is a 2.5 liter v6 two stroke
https://youtu.be/vl8cfhz2zBk
i have an ultimate to test this on!
Code: Select all
/************ Rover 36-1-1-1-1 mode3 - do not know application *************/
SPKMODE24:
//initial sync
if (!(synch & SYNC_SYNCED)) {
if ((!tooth_diff_this) || (!tooth_diff_last)
|| (!tooth_diff_last_1)) {
return(0); // only sync when there's enough data
// when unsynced we wait until we see a missing tooth and then another one
// and count the teeth in-between
if (!(synch & SYNC_SEMI)) { // just starting
temp1 = tooth_diff_last + (tooth_diff_last >> 1); // 1.5*
if (tooth_diff_this > temp1) {
tooth_no = 0;
synch |= SYNC_SEMI; // started sync sequence
return(0);
} else { // started sequence, check possible sync points
tooth_no++;
if (!(synch & SYNC_SEMI2)) { // just starting
if (tooth_no == 4) {
tooth_no = 0; // tooth 1
goto WHL_ROV3_OK;
} else if (tooth_no == 16) {
tooth_no = 16; // tooth 17
goto WHL_ROV3_OK;
} else if (tooth_no == 2) {
tooth_no = 18; // tooth 19
goto WHL_ROV3_OK;
} else if (tooth_no == 15) {
tooth_no = 33; // tooth 34
goto WHL_ROV3_OK;
} else if (tooth_no == 3) {
tooth_no = 36; // tooth 37
goto WHL_ROV3_OK;
} else if (tooth_no == 14) {
tooth_no = 50; // tooth 51
goto WHL_ROV3_OK;
} else {
tooth_no = 0; // doesn't make sense, so try again from this missing tooth
return(0);
WHL_ROV3_OK:
synch &= ~SYNC_SEMI;
synch &= ~SYNC_SEMI2;
synch |= SYNC_SYNCED;
} else {
// recheck for sync
if ((tooth_no == 16) || (tooth_no == 18) || (tooth_no == 33) || (tooth_no == 36) || (tooth_no == 50) || (tooth_no == 54)) { // (one less)
if (tooth_diff_this <= temp1) {
outpc.syncreason = 50;
ign_reset();
return(0);
if (tooth_no == 54) {
tooth_no = 0;
goto common_wheel;
Code: Select all
/* ---------------------- Rover 36-1-1-1-1 type '3' (??) -------------------- */
// this one has 4 and 5 teeth between the gaps
} else if (spkmode == 24) {
no_teeth = 54; // for single coil or wasted spark
last_tooth = no_teeth;
deg_per_tooth[0] = 60;
deg_per_tooth[1] = 60;
deg_per_tooth[2] = 60;
deg_per_tooth[3] = 60;
deg_per_tooth[4] = 60;
deg_per_tooth[5] = 60;
deg_per_tooth[6] = 60;
deg_per_tooth[7] = 60;
deg_per_tooth[8] = 60;
deg_per_tooth[9] = 60;
deg_per_tooth[10] = 60;
deg_per_tooth[11] = 60;
deg_per_tooth[12] = 60;
deg_per_tooth[13] = 60;
deg_per_tooth[14] = 60;
deg_per_tooth[15] = 120;
deg_per_tooth[16] = 60;
deg_per_tooth[17] = 120;
deg_per_tooth[18] = 60;
deg_per_tooth[19] = 60;
deg_per_tooth[20] = 60;
deg_per_tooth[21] = 60;
deg_per_tooth[22] = 60;
deg_per_tooth[23] = 60;
deg_per_tooth[24] = 60;
deg_per_tooth[25] = 60;
deg_per_tooth[26] = 60;
deg_per_tooth[27] = 60;
deg_per_tooth[28] = 60;
deg_per_tooth[29] = 60;
deg_per_tooth[30] = 60;
deg_per_tooth[31] = 60;
deg_per_tooth[32] = 120;
deg_per_tooth[33] = 60;
deg_per_tooth[34] = 60;
deg_per_tooth[35] = 120;
deg_per_tooth[36] = 60;
deg_per_tooth[37] = 60;
deg_per_tooth[38] = 60;
deg_per_tooth[39] = 60;
deg_per_tooth[40] = 60;
deg_per_tooth[41] = 60;
deg_per_tooth[42] = 60;
deg_per_tooth[43] = 60;
deg_per_tooth[44] = 60;
deg_per_tooth[45] = 60;
deg_per_tooth[46] = 60;
deg_per_tooth[47] = 60;
deg_per_tooth[48] = 60;
deg_per_tooth[49] = 120;
deg_per_tooth[50] = 60;
deg_per_tooth[51] = 60;
deg_per_tooth[52] = 60;
deg_per_tooth[53] = 120;
smallest_tooth_crk = 60;
smallest_tooth_cam = 0;
if (num_cyl == 4) {
no_triggers = 2;
trigger_teeth[0] = 2;
trigger_teeth[1] = 30;
trig_angs[0] = -100 + tmp_offset; // to be determined
trig_angs[1] = -100 + tmp_offset; // to be determined
} else if (num_cyl == 6) {
no_triggers = 3;
trigger_teeth[0] = 1;
trigger_teeth[1] = 19;
trigger_teeth[2] = 37;
trig_angs[2] = -100 + tmp_offset; // to be determined
} else if (num_cyl == 8) {
no_triggers = 4;
trigger_teeth[0] = 7;
trigger_teeth[1] = 20;
trigger_teeth[2] = 34;
trigger_teeth[3] = 48;
trig_angs[3] = -100 + tmp_offset; // to be determined
} else if (num_cyl == 12) {
no_triggers = 6;
trigger_teeth[1] = 11;
trigger_teeth[2] = 19;
trigger_teeth[3] = 29;
trigger_teeth[4] = 37;
trigger_teeth[5] = 47;
trig_angs[4] = -100 + tmp_offset; // to be determined
trig_angs[5] = -100 + tmp_offset; // to be determined
} else {
conf_err = 17;
- Attachments
- mercury_60_6.jpg (120.51 KiB) Viewed 1462 times
