Toyota pnp ms3-pro?
TOYJOETA
Toyota pnp ms3-pro?
Post by TOYJOETA »
I've got a Cressida that will evetually get a heart transplant. Still on the fence between either a 2jz-nat or 1uz-nat. The biggest thing holding back from the 1uz is the lack of info I can find on standalone Ecu's. I know there are a few people out there who are running them with the ms3x. I read a while back that there was going to be a ms3-pro pnp for the supra which uses the same ecu plugs as the later 1uz. So I don't see why there couldn't be one for the 1uz even though the Pinout isn't the same. Wouldn't be to difficult to re-pin the conversion harness for the 1uz. Is there an eta on the supra pnp?
Joe
quark2501
Re: Toyota pnp ms3-pro?
Post by quark2501 »
Hi
Look at diyautotune.com they have all you need for PNP
TOYJOETA wrote:I've got a Cressida that will evetually get a heart transplant. Still on the fence between either a 2jz-nat or 1uz-nat. The biggest thing holding back from the 1uz is the lack of info I can find on standalone Ecu's. I know there are a few people out there who are running them with the ms3x. I read a while back that there was going to be a ms3-pro pnp for the supra which uses the same ecu plugs as the later 1uz. So I don't see why there couldn't be one for the 1uz even though the Pinout isn't the same. Wouldn't be to difficult to re-pin the conversion harness for the 1uz. Is there an eta on the supra pnp?
Joe
We expect a Supra MSPNP to be ready by the end of the year - most of the hard work is done; the last hurdle is getting the case into production (it's a fairly complicated folded steel design; Toyota didn't do us any favors when they spec'ed a connector that has two bends in its sealing surface!). And once it's out, we will do a bit of testing on a 1UZ - we set it up so that it should work with this engine on paper if it is backed by a manual transmission, but it needs some testing to be sure. Although Toyota never put a stick shift behind a 1UZ, there's enough examples running around that this could be an interesting secondary target. Haven't had a chance to confirm it works yet though.
Suprazz
Post by Suprazz »
If you decide to go with a 1jzgte I made a plug and play ecu. 6 car working with it right now and one made over 500whp with this ecu. (1.5jz)
nathaninwa
Post by nathaninwa »
That's pretty dang cool. I just rewired a 1j for a universal application Pro. This would have come in handy.
TOYJOETA
Post by TOYJOETA »
Matt Cramer wrote:We expect a Supra MSPNP to be ready by the end of the year - most of the hard work is done; the last hurdle is getting the case into production (it's a fairly complicated folded steel design; Toyota didn't do us any favors when they spec'ed a connector that has two bends in its sealing surface!). And once it's out, we will do a bit of testing on a 1UZ - we set it up so that it should work with this engine on paper if it is backed by a manual transmission, but it needs some testing to be sure. Although Toyota never put a stick shift behind a 1UZ, there's enough examples running around that this could be an interesting secondary target. Haven't had a chance to confirm it works yet though.
This is awesome news, and yes I wouldn't run anything but a manual.
TOYJOETA
Post by TOYJOETA »
Any updates?
Had a couple snafus with the shop that's making the prototype faceplate - it's been a bit tricky to get all the bends exactly right. The main cases are due in late January, but we may need a couple iterations of prototyping up the faceplate to be sure everything fits.
arjay
Post by arjay »
Suprazz wrote:If you decide to go with a 1jzgte I made a plug and play ecu. 6 car working with it right now and one made over 500whp with this ecu. (1.5jz)
That's got to be the nicest looking module I've ever seen. A real work of art :yeah!:
Suprazz
Post by Suprazz »
Thanks! I'm preparing a new groupbuy.
TOYJOETA
Post by TOYJOETA »
Updates?
Final design of the prototype faceplate has been approved. We're waiting on them to get back from the powder coater and for the silk screen company to fix a mistake they made with putting the logo on the case.
Suprazz
Post by Suprazz »
There is a new group buy for the Plug and play ms3pro based ecu for toyota supra 89-92 with 7mgte or 1jzgte engine! Work great for a 1jz swap with JZA70 wiring harness!
More info here: http://www.supraforums.com/forum/showth ... 28JZA70%29!
