On the other hand, it would be far easier to implement a means to detect tampering that would thwart someone who can't be bothered to read normal instructions, than to achieve a total lockout. As others had noted, the password protected Motec and Haltech systems don't have a total lockout, either, so asking for a truly secure system would be to ask for something well beyond what is currently available in aftermarket ECUs.AbatelliCristian wrote:The problem is "when engine is broken.... is broken...." then it does not matter who is responsible.
The objective is not to break the engine.....
If you eliminate the problem (damage engine), no discussion with proprietary of vehicle....
And I should add that any decent tune encryption is going to be immune to normal cryptography attacks - if all you have is the tune file. Suppose I took an MSQ file and added the same integer from 0 to 15 to every value in the VE and spark table. That's a FOUR BIT encryption key. If it had been applied to a text message, it would be easy for a codebreaker to break it by hand, let alone a computer based attack. But when it's pure numbers that have no pattern, figuring out the key is going to be nearly impossible. However, if you are able to access the processor or a data log, that's another story...
