From time to time I've seen people ask here to have individual P/I/D values for things like idle and boost control logged. And I understand that's a lot of work for the coders and would take up a lot of space in a log.
But here's an idea: how about an option to log the PID values for any one control?
For example: reserve a byte in memory somewhere. If the value stored is 0, log no PID data. If it's 1, log PID for idle control only. If it's 2, log PID for boost control (only), and so on. Obviously then you'd expose that value in TS somehow so people could select what to log.
It wouldn't be any less work to write the code, but it would save log space.
PID logging idea
PID logging idea
Eric Law
Re: R: PID logging idea
Maybe a screen like the tooth log, that show current signal, output of pid, and p i d components. Will help a lot tuning pid.
Enrico
Opel/Vauxhall Corsa GSi MS2
Subaru v4 EJ20 MS3
Subaru v4 EJ20 MS3
Id love to see something like that and was thinking of requesting it.masterx81 wrote:Maybe a screen like the tooth log, that show current signal, output of pid, and p i d components. Will help a lot tuning pid.
Re: PID logging idea
I also would like to see this
x2lagos wrote:Id love to see something like that and was thinking of requesting it.masterx81 wrote:Maybe a screen like the tooth log, that show current signal, output of pid, and p i d components. Will help a lot tuning pid.
Megasquirted engines: 4g63, k24a2, b16-b18, duratec, ecotec, fiat 8v-16v, modular 4.6 32v, 1fz-fe, fiat 5cil 20v, Opel corsa, G54B, VW AG, 2ZZ-GE.
https://www.facebook.com/Bartonefi
instagram: @bartonefi
