MS3 pre-1.4 alpha 1 released
Re: MS3 pre-1.4 alpha 1 released
I read this before, thanks.
I don't want help, I wanted to help you! If I had one, I would have posted it..............
Race car building documentation: www.kessel.tk (nice pics but only german laguage so far...)
I want to help you, but without the MSQ you are using I can't be sure I have exactly replicated your test conditions.
Would you prefer folks to be running the pre-1.4 or the ~mainline beta 1.3.x firmwares?
Whichever you prefer. We need testers of both.piledriver wrote:Would you prefer folks to be running the pre-1.4 or the ~mainline beta 1.3.x firmwares?
Is this the same issue?thokes82 wrote:I found a Problem with my pure Alpha N Setup.
I am taking Alpha N as primary load for fuel and ignition and taking the new setting mapport_t=Off. The Engineload does not change anymore when I am depressing the gas and engine is dying. If I enable a voltage or frequency in mapport_t, the engine works with alpha N as expected. (I do not have a map sensor connected).
http://www.msextra.com/forums/viewtopic ... 68#p405712
Yes, seems to be exactly the same...
Finally got a chance to test with MS3 and MS2. Both get crank wheel, 2nd trigger goes to MS2. MS2 sequential spark out B goes to MS3 cam in.jsmcortina wrote:Agreed - it is tough.Peter Florance wrote:One of the challenges is I have not worked out any easy way to bench test VVT
One method I have used is with two Megasquirts from a single tach source. I use the spark output from one as the cam input to the other. I can then use "Fixed Advance" to move the spark signal which the second Megasquirt sees as the cam moving position.
Set up trigger wheel in MS2 so 0 degrees advance reads 0 degrees cam advance on the MS3. These are the settings I use on the BMW M54
Using 1.3.4 Release works fine. I can change timing of the MS2 and the VVT 1 angle gauge tracks the value. This code also works on a running car.
MS3 pre-alpha 1 does not work. VVT Angle 1 reads the Min Absolute cam angle value regardless of the timing of the cam signal.
Attached are log and msq that I used in the MS3.
Thanks!
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
PF Tuning
Many moons have passed since a1.
Try it with b12?
Try it with b12?
I did on the car and it did not work.piledriver wrote:Many moons have passed since a1.
Try it with b12?
That's why I went back to earliest 1.4 to test.
Peter Florance
PF Tuning
PF Tuning
Sounds like I need to come up with a multi-channel VVT simulator.
I could have tested both channels the way you suggested.jsmcortina wrote:Sounds like I need to come up with a multi-channel VVT simulator.
Anything jump out at you?
Peter Florance
PF Tuning
PF Tuning
I won't be able to test until the weekend most likely.
Thanks. Took me 9 months to test my part; the weekend seems pretty quick.jsmcortina wrote:I won't be able to test until the weekend most likely.
Peter Florance
PF Tuning
PF Tuning
It's odd that no one else has complained. I'm guessing it is related to the half moon cam pattern and that most current VVT users have motors with multi tooth cam patterns.
Peter Florance
PF Tuning
PF Tuning
This appears to be related to the setting of "Timed" instead of "Synced to Cam".
Changing that setting gives me a working VVT1 angle.
I'm investigating why.
Thank you. Now I know I'm not crazy.jsmcortina wrote:This appears to be related to the setting of "Timed" instead of "Synced to Cam".
At least about this...
Peter Florance
PF Tuning
PF Tuning
I'll likely have one of these cars on the dyno Saturday if there is anything else I can look at
Peter Florance
PF Tuning
PF Tuning
The fix is now available in beta13.
Cheers, James. I'll give it a try.jsmcortina wrote:The fix is now available in beta13.
You around Saturday when we dyno?
Peter Florance
PF Tuning
PF Tuning
Is that now?Peter Florance wrote:Cheers, James. I'll give it a try.jsmcortina wrote:The fix is now available in beta13.
