Launch control rewording/greying out
Its been since January that I last used Launch Control. I reneabled it and wanted to work with lowering the rpm at which I launch. I setup the LC page with a 3000 revlimit and 200rpm soft limit and would rev right past. After getting home and viewing the datalog, I realized that the VSS/launch is on and the revlimit is overridden by the curve rpm limit. Maybe when Vss/launch is enable there is a note or the main LC setting is greyed out with the same little note that's on the vss/launch page on how its taken from the curve.
