To announce MS3 pre-1.3.1 beta 2.
This code is in the 1.3.x stream and follows 1.3.0. It is expected to be promoted to "1.3.1 release" shortly.
Who should use this code?
Existing users of 1.3.0 are encouraged to validate this code. Users impacted by any of the bug-fixes are recommended to use this version.
Main changes since 1.3.0
Bug fixes:
Typo causing GPS to trigger single event fuel cut.
Re-do staging duty calcs to work with sequential.
Many after-launch features broken on 2014-08-07, STATUS2_LAUNCH was not being used.
Traction changes for perfect run and button modes.
Fix timer rollover for boost delay.
Fix table blend behavior with boost initial values table.
Fix rogue pulses on MS3X secondaries for staging or dual-fuel.
MS3X non-sequential staging uses expected number of outputs.
Fix staging transition "saw-tooth" issue.
Modified features:
Average 1-cyl RPMs over two revs.
Rename "closed/open" to "minimum/maximum" for boost and idle valve settings.
Extend VSSout to allow larger scaling numbers. (untested.)
Minor/internal:
Handle another impossible tooth count with config error.
Use "vvt_decoder" var in init.
Use TS generated CLT, MAT GM calibrations. Use MAT for "GM calibration"
The zip file can be downloaded from:
http://www.msextra.com/doc/ms3/files/be ... 1beta2.zip
MS3 pre-1.3.1 beta 2 released
Re: MS3 pre-1.3.1 beta 2 released
11:24 BST Sunday 30th March
I spotted that I hadn't raised the vssout_scale limit in the ini file. I've fixed that and re-uploaded the zip.
Thanks a lot James. I'll try to test the VSS out over the weekend. I'm having issues with my USB connection so I hope being able to load the firmware.
Very pleased with this release. I had been behind the 8Ball on prev versions, then upgraded to 1.2.4 a little while back and had lots of quirky issues that seemed to be introduced with IDLE, WB EGO Control when using PID, etc. Did retune, but did not have time to isolate issues.
Upgraded to this release and did have to retune again to refine, but this version appears to be very stable. IDLE is rock stable and not even using IDLE MAP Switching (42# injectors, alt batch on a Supercharged 2valve 4 cyl with Dist).
I didn't happen to check to see if VSS was correct, but will. Somewhere along the line 9since introduction) I had to change the pulses from 6 to 4 which was very peculiar.
One thing I noticed, but I am pretty sure this may be a TunerStudio Issue, is that when switching between using an EGO Authority Map, VE analyze live appears to crap out and can not be made to work unless a full Recycle. Maybe this is just the way it is, when switching between the Authority MAP which kind of makes sense.
Speaking of which, I must have missed when this feature was introduced, but I absolutely love it as now I can prevent over correction at IDLE, etc!
Keep up the good work gentlemen.
'90 Corrado G60 on MSns -e -> MS3 - '62 Harley Panhead
Supercharged 2L-20v Project Build -> https://forums.vwvortex.com/showthread.php?2805002
Making 02m 6speed Conversion Mounts for VW MKII and MKIII -> http://www.generalprinciple.com/02m
Work fine to me, but my megaview still showing temperatures in Fahrenheit and don't change to Celsius.
A big hug.
A big hug.
Zamora running at Renault Clio mk2 ph2 1.0L 16v ms3/ms3x...
2.0L supercharged comming soon...
