Hi devs,
I have backported the 36-2 wheel decoder from the MS2 code (3.3.2 beta 5) to my MS3, which is running 1.2.4.
I'm running 1.2.4 as I have patched it to include more ADCs, inputs, outputs and several other features I need (second cooling fan, etc).
The car runs well with the backported code, minus VVT of course, where I couldn't find anything obvious as to what needs to be done to make it work.
Is there any chance one of the devs can give me a pointer or a code patch?
Thank you in advance gentlemen!
VVT code for Miata 36-2 wheel decoder
The man behind MS Labs
Re: VVT code for Miata 36-2 wheel decoder
Miata 36-2 VVT is already supported in the current MS3 firmware.
36-2 is not supported in 1.2.4, which is what I am running, as I have patched the source for additional features.
I would love to run 1.3.0, however the source for that is not available yet.
I've found I need to change ms3_init.c to allow VVT on the wheel without a config error, isr_ign.s to capture the cam teeth and ms3_ign.c to calculate the actual vvt angle.
If one of the devs could share the code (or just give the source for 1.3.0 stable since the first 1.4 alpha is already released?) I would be most grateful.
The source for 1.3.x is not yet ready for release.
Any chance you can email me just the few bits of code I need to make VVT work with my 36-2 wheel? That's all I need really from 1.3.0.
