ms3x trans control
ms3x trans control
Is it possible to incorporate the megashift code along side the engine code.
I have so much in/out connections available, and features I will never use. Table switching, launch control, among other things.
Is there anyway to do this and how can I help?
Re: ms3x trans control
It is not possible currently, and has been asked for multiple times before. Your cheapest option would probably be get a Microsquirt module and connect it to MS3 via CAN
I had another quick look at this the other day. While there might just be enough inputs and outputs for the gear-pos switches and solenoids on a 4L80E, there isn't a suitable spare input for the VR speed sensor or input shaft speed sensor.
The last run I had with the ms3 controlling the engine i was using the speed sensor pickup for a speed display in TS. Could this be used for a simplified trans controller based on throttle position,load,and rpm with a brake switch input added to lock/unlock the converter on decel and braking .
is there a hardware change i can make to the ms board for the extra vr pickups needed or possibly an external solution. i still have the zeal board but dont see any room for it in the ms3x box. but i do have a proto area on the ms (3.0) board.
also is there a safe way to convert the spare outputs to positive switching instead of negative. i understand there are PNP and NPN transistors but i dont fully understand how to incorporate that into my MS
The trans im using is an A341. It utilizes a tcc speed sensor (VR), tail shaft speed sensor (vr) and another tailshaft speed sensor (hall?) this is a 20 pulse per revolution converted to a 4 pulse per revolution at the instrument cluster. the 2 shift solenoids are positive switched while the tcc lockup and line pressure are pwm grounds
I have been driving it around with a 4 position rotary switch and a spst switch for lock up this all works well but i was hoping i could use the programmable outputs to operate the three solenoids based on the data that ms uses to control fuel and spark in addition to the speed and brake inputs.
Could you use something like a HEI module as a conditioner and wire it to PT4?jsmcortina wrote:I had another quick look at this the other day. While there might just be enough inputs and outputs for the gear-pos switches and solenoids on a 4L80E, there isn't a suitable spare input for the VR speed sensor or input shaft speed sensor.
Of course, if the car is using a HEI distributor and non-sequential injection, you could just use the cam input for VSS.
This is very interesting, will it help if not using the 4L80E pressure switch but rather using a 0-5v input like Ford trannys for gear lever positioning?jsmcortina wrote:I had another quick look at this the other day. While there might just be enough inputs and outputs for the gear-pos switches and solenoids on a 4L80E, there isn't a suitable spare input for the VR speed sensor or input shaft speed sensor.
Will free up 2 inputs.....
BR//Tobmag
Jaguar XJ12 MS2 V3
XJS V12 MS3/MS3X + GPIO Trans cntrl over CAN
(Google translate will be your friend )
This interests me. I picked up my next project and it will be using a 5.3 LS truck motor and 4l80e in a boosted application. I haven't read fully into the best option for controlling the transmission but this would be a nice feature. It will be on ms3pro.
This makes me smile! I'm using the bare minimum wiring for my 4R70W trans. I don't care about shift position as long as its in drive all the forward gears will work like there supposed to. My code only uses TPS and vehicle speed to shift points and TCC lock up.
Subscribing!Matt Cramer wrote:Could you use something like a HEI module as a conditioner and wire it to PT4?jsmcortina wrote:...there isn't a suitable spare input for the VR speed sensor or input shaft speed sensor.
Assuming that the signal could be conditioned in the way Matt suggested here, would this be applicable for any non-sequential injection/wasted spark setup?
But is there still one signal that can't be accommodated even with Matt's idea?
How's it going James!
I just spent a few minutes digging and rummaging and looking at the MicroSquirt Trans Controller wiring. The MS3 is already reading things like CLT, TPS, and RPM, so all that's needed is the transmission-specific inputs and outputs. A TinyIOx should be able to handle those with no difficulty, leaving all the MS3/x inputs available for engine and chassis control.jsmcortina wrote:I had another quick look at this the other day. While there might just be enough inputs and outputs for the gear-pos switches and solenoids on a 4L80E, there isn't a suitable spare input for the VR speed sensor or input shaft speed sensor.
