To announce MS3 pre-1.3.2 beta 1.
This code is in the 1.3.x stream and follows pre-1.3.2 beta1.
Who should use this code?
Existing users of 1.3.x are encouraged to validate this code. Users impacted by any of the bug-fixes are recommended to use this version.
Main changes since 1.3.1
Bug fixes:
Fix rotary trailing calculation error (evident near 0deg advance)
Allow spark 45deg ATDC. (Was limited to 10ATDC in Oct'13)
Fixed zero sized extended CAN packets xmit in error.
Assign correct config error numbers for VSS2.
Fuel pump (O/L or C/L) sets correct portusage.
3-cyl single-coil allowed
Fix to oddfire custom angles (accumulate odd_trig_offset)
Allow fuel calcs to run w/o MAP or MAF sampling.
Don't flag VVT error for on/off output.
Fix typo nitrous / 3step.
Powercycle required for nitrous.
Modified features:
Minor/internal:
Tweak CAN VSS defaults.
The zip file can be downloaded from:
http://www.msextra.com/doc/ms3/files/be ... 2beta2.zip
Some of the ini changes will result in harmless warnings when loading older MSQs.
MS3 pre-1.3.2 beta 2 released
Re: MS3 pre-1.3.2 beta 2 released
I just had a look and there's no setting for the CAN offset or data size (8bit/16bit) for VSS3 and VSS4. Are there hardcoded defaults or this is just a omission?
Thanks!
Thanks!
The man behind MS Labs
They follow VSS1 and VSS2 respectively.Reverant wrote:I just had a look and there's no setting for the CAN offset or data size (8bit/16bit) for VSS3 and VSS4. Are there hardcoded defaults or this is just a omission?
What exactly do you mean? If vss1 is at offset 0 and vss2 is at offset 2, is vss3 at offset 4 and vss4 at offset 6? 16bit values.jsmcortina wrote:They follow VSS1 and VSS2 respectively.Reverant wrote:I just had a look and there's no setting for the CAN offset or data size (8bit/16bit) for VSS3 and VSS4. Are there hardcoded defaults or this is just a omission?
I need to re-check the code on this. It looks like I made some changes between 1.3 and 1.4 and might be thinking of 1.4.
I didn't get chance to check this VSS query for 1.3.2, will look for 1.3.3.
"1.3.2 release" now posted.
