External advance?
Reverant
External advance?
Post by Reverant »
Looking through the outpc variables in firmware 1.3.0, I see a variable named "ext_advance" at offset 454.
I was really hoping that I could put any ignition offset I wanted in that variable, to arbitrarily alter the engine's timing through CAN, however the final timing advance didn't change and on top of that, my value was getting overwritten anyway. Searching the forums doesn't yield any results - just that it was originally named ext_retard, and no results on that either.
So, what does ext_advance do and how could I manipulate the timing like I thought I could?
Thanks!
The man behind MS Labs
Re: External advance?
ext_advance is an outpc output of any external advance adjustment. The input is sent to datax1.SpkAdj and usually comes from a trans controller.
From ms3.h:
Code: Select all
    int FuelAdj, SpkAdj, IdleAdj, SprAdj; // allow other devices to change our behaviour. Published offsets of 512+118 = 630 et seq. AVOID MOVING
Hopefully that should get you going.
Reverant
Post by Reverant »
Exactly what I was looking for, thanks!
Reverant
Post by Reverant »
Any chance the code ignores negative values on timing? 40 adds 4.0 degrees, -40 does nothing (ext_advance is 0 degrees instead of -4.0).
