MS3 1.3.2 source code released
To announce the release of source code for MS3 1.3.2
Be sure to read and respect the included README and LICENSE files.
http://www.msextra.com/doc/ms3/files/so ... -1.3.2.zip
You'll need the 2012 build tools available from http://www.msextra.com/tools
If you don't know what source is... this file isn't for you!
Regular users should go to the Downloads page for pre-compiled code instead.
MWPau
Re: MS3 1.3.2 source code released
Post by MWPau »
Great to see this have been made availiable.
Thanks James & co :yeah!:
Reverant
Post by Reverant »
Great news, thank you!
Quite some time ago (October?) I emailed you a patch to additional CAN I/O (more ADCs, digital inputs and outputs) as I need these for my car.
Is there any chance that if I update the patch to make it work with 1.3.2 you'll merge the patch with the next release (whether the stable 1.3.x or the development 1.4.x branch)?
The man behind MS Labs
I uploaded a patch file to take the source to 1.3.3
EDIT: http://www.msextra.com/doc/ms3/files/so ... -patch.zip
Post by racingmini_mtl »
It seems that I can no longer access the online files directory so without a direct link there is no way to get the patch.
racingmini_mtl wrote:It seems that I can no longer access the online files directory so without a direct link there is no way to get the patch.
I added a direct link. However, you can still browse the directory tree, by following the "Old versions" link on the Downloads page.
kyle_b
Post by kyle_b »
Quick question, I get errors when applying the patches from 1.3.2>1.3.3 and from 1.3.3>1.3.4.
Patch command is complaining about different line endings of the core.ini file. All other source files
patch successfully. Is there a way to fix this? Or can you post a 1.3.4 core.ini file?
esso
Post by esso »
you can find the .ini file in the firmware .zip itself , just skip this file and use the one with the firmware
