To announce MS3 pre-1.3.3 beta 2.
This code is in the 1.3.x stream and follows pre-1.3.3 beta 1.
Who should use this code?
Users impacted by any of the bug-fixes are recommended to use this version.
Any Nissan CAS (RB25, SR20) or Optispark users are urged to upgrade immediately. The bug fixed here is present in all other MS3 firmware versions.
Main changes since 1.3.3
Bug fixes:
Apply timeout to SSEM.
Apply timeout to fire_n_check.
(Both of these changes were to fix/mitigate a lockup discovered in RB25 mode.
The code was getting stuck in fire_n_check waiting on the XGATE.)
Fix on/off idle output.
Modified features:
Minor/internal:
The zip file can be downloaded from:
http://www.msextra.com/doc/ms3/files/be ... 3beta2.zip
Some of the ini changes will result in harmless warnings when loading MSQs from 1.3.x
Users upgrading from 1.2.x or earlier codes need to pay more attention.
MS3 pre-1.3.3 beta 2 released
Re: MS3 pre-1.3.3 beta 2 released
Known bug:
SDcard readback does not work in this code release (due to the fix for Nissan CAS.)
Updated code due later today.
