ms3pro with 'A' command..
Re: ms3pro with 'A' command..
Dear All:
It's mid night here....
Got to go to bed!!!
Good night! ;)
Got to go to bed!!!
Good night! ;)
results from an A dump using mini terminal in tuner studio.
EDIT: scrub that, I have reproduced it.
Turn Megaview temperature units to degF.
Also, I suggest that you re-write your code to use the CRC checked "newserial" protocol instead of the old dumb protocol.
that has done it.jsmcortina wrote:EDIT: scrub that, I have reproduced it.
i will look in to it but not sure i have the ability to do this yet.jsmcortina wrote:Also, I suggest that you re-write your code to use the CRC checked "newserial" protocol instead of the old dumb protocol.
So u24=55 and u25= 3, That's (55x256+3)x0.1=1408.3 --- Still not a correct tps value!grom_e30 wrote:results from an A dump using mini terminal in tuner studio.
That's the exact situation I meet now.
Dear James:jsmcortina wrote:Also, I suggest that you re-write your code to use the CRC checked "newserial" protocol instead of the old dumb protocol.
A dumb question:
How I add crc check to 'A' command?
Can you write a sample VB program for A command?
Cheers
Howard
I don't think I've used VB.
Have a look at this: http://www.msextra.com/doc/pdf/ms3_seri ... l_0.07.pdf
funny that i changed the setting James said and bam was all working correct for me, i am using a ms3 though not a pro.
