In the drop-downs to choose how to incorporate secondary tables with primary, why can't I have multiple tables pointing at the same curve. I'd like my VE, spark, and AFR table blending all pointing at the same blend curve.
I'd like to be able to blend between TPS and MAP AFR tables, similar to VE and spark.
Also, can we incorporate VVT into table blending? Blend between two tables based on VVT position.
Thank you!
Feature request: blend curves, AFR load, and vvt blending
